Tutorial, step by step, for Auto Tool Measurement
10 years 3 months ago #77994 by kylotron
I LinuxCNC, i have my small CNC and i have a number of tools.
Now i have the need to realize the machining with different tools and i homemade 2 sensors connected to the input PROBE-IN, one mobile, the 1.33 mm thick, and a fixed, positioned at X741 Y102 coordinates.
I can manually reset the workpiece or the tool relative to the fixed sensor.
But how can i automate the tool zero with respect to the workpiece?
Bernardo
P.S.: sorry for my English, it is generated using google translator.
10 years 3 months ago - 10 years 3 months ago #78003 by andypugh
If you start LinuxCNC and look in the sample configs:
sim/axis/remap/manual-toolchange-with-tool-length-switch
You will find a simulated config that does what you want.
You should just need to copy the nc_subroutines and python folders from that configuration to your configuration and then add the relevant section to your INI file:
[RS274NGC] ... SUBROUTINE_PATH = nc_subroutines:../../nc_files/remap_lib/common_nc_subs ... ON_ABORT_COMMAND=O <on_abort> call # # ------ remapping toolchange - related codes ---------------------- # # see python/remap.py for the prolog and epilog handlers # see nc_files/remap-subroutines for the NGC procedures # # the prepare_min.ngc and change_min.ngc are templates - fill in as needed REMAP=M6 modalgroup=6 prolog=change_prolog ngc=manual_change epilog=change_epilog
(edit} And connect your tool-length switch to motion.probe-input
Last edit: 10 years 3 months ago by andypugh.
7 years 10 months ago #123112 by Karri
Hey
Does anyone have idea why my machine doesn't care of the "Current Z length",
I'm able to use this example config to measure the tool height, but the machine goes as deep as g-code says, without any matter how long the tool is.
I make first tool measurement with "reference tool" button pressed and second tool measurement unpressed, but second tool goes too deep, like it would be as long as reference tool.
7 years 10 months ago #123139 by andypugh
Does the G-code contain a G43 to apply tool geometry corrections?
7 years 10 months ago #123162 by Karri
Thx for fast reply.
There is g43 in code, but i found out that if there is allready g43 in the "Active g-codes:" -window, the new G43 turns it to G49 and doesn't allow to turn it on again. G43 comes back in active after re-entering "t4 m6" to MDI and going through the lenght measurement.
If i manually enter to MDI new z position it works, but if i enter g43 z100 then it turns g49 mode, and goes to "absolute" value.
7 years 10 months ago - 7 years 10 months ago #123164 by Leon82
Use g49g53z0 to return before the tool change.
Or g49
G91g28z0
You should cancel the offset before Channing tools.
Last edit: 7 years 10 months ago by Leon82.
Time to create page: 0.343 seconds
