Tutorial, step by step, for Auto Tool Measurement
7 years 10 months ago #123165 by Leon82
I haven't used the tool offset yet on mine because I'm waiting for my r8-er32 holders to come but on some controls like even the fanuc a g54 value affects the tool height input.
Where is g54 value?is it the amount you are off
7 years 10 months ago #123167 by Karri
Hi
I think that the measurent function is ok, because its the same which comes with the Linuxcnc and the tool lenght what it shows are correct.
It just change the G43 mode to G49, if the code is containing another G43 when it is allready on.
7 years 10 months ago - 7 years 10 months ago #123171 by Karri
Ok, i got it working - well atleast for my current needs :dry:
Thx for Leon82, i put G49 to manual_change.ngc subroutine.
But the problem was still that every new G43 cancelled previous G43 - So i edited the Autodesk inventor Cam postscript according to this
forums.autodesk.com/t5/fusion-360-comput...om-post/td-p/7168904 and it removed all g43 from codes, because that subroutine will turn those G43 on everytime it runs.
and now it goes through 5 tool change and measurement between.
Thx for all of your help :)
Last edit: 7 years 10 months ago by Karri. Reason: typos
4 years 9 months ago #232761 by Karri
Hey
Could you edit your answer that:
-you allso need to update python paths to ini file, and probe location etc ...
BR. some clever one who just spent 10h fighthing with the system and then looked down of the example ini file :side:
The following user(s) said Thank You: johnbump
Time to create page: 0.289 seconds
