jerky motion only in ramp movement
9 years 11 months ago - 9 years 11 months ago #82374 by b2unit
I have jerky motion only in ramp path movement.
actual cutting path movement is smooth.
I had tried changing max acceleration of each axis, adding g64 p0.005(or p0.01)
but those tries failed in vain...
I found some strange point.
in the images actual cutting path is curved line but ramp path is polygon line.
I think this differences make some jerky motion only in ramp path movement
Is this logical conclusion??
if then please let me know how to fix it.
thanks,
Byoungil Choi
here's images and my ini file.
* those diameters of holes are 10mm(left), 6mm(right)
File Name: gmoccapy_2...1-03.ini
File Size:6.1 KB
Last edit: 9 years 11 months ago by b2unit.
9 years 11 months ago #82376 by Todd Zuercher
What's the G-code look like?
9 years 11 months ago #82378 by b2unit
here's the gcode file
File Name: 4holes-d2.ngc
File Size:35.01 KB
9 years 11 months ago #82379 by Todd Zuercher
I'll guess that you created your code with some cam program. Linuxcnc does support helical arcs, so you could change your ramp from a series of linear segments to an arc move. The trick might be convincing your cam program to do it that way.
The G64 settings you tried looked more appropriate for a machine set up for inches. Try G64 P0.05 or P0.1 or even straight G64, but that may not follow your paths close enough.
The following user(s) said Thank You: b2unit
9 years 11 months ago #82380 by b2unit
the file was created by nx cam in ug nx 11.
can i have some hint for that?
do i have to edit post processor or some setting option in nx11?
i don't know where to start from..
thanks,
Byoungil Choi
9 years 11 months ago #82382 by Todd Zuercher
To some extent because of the inherent jerking programed into your tool path, it may never be completely smooth (the poly line ramp) compaired to the true arc of the cut.
Time to create page: 0.129 seconds
