How to setup a 4axis gantry plasma machine using gmoccapy?
09 Dec 2016 19:28 #83838 by emad
I like the Gmoccapy GUI but I still have some problems with installing Linuxcnc.I used buildbot but still have scripts and authentication errors. I followed www.wiki.eusurplus.com/index.php?title=LinuxCNC_Run_In_Place but runtests script results in errors.can you please help me with installing the master branch step by step?
09 Dec 2016 19:36 #83839 by andypugh
I am slightly confused because run-in-place and buildbot are two different ways to install LinuxCNC (and, in fact, you can use both, to have several versions of linuxCNC on the same machine)
Buildbot should be easiest and you get updates just like with any other software.
Errors with runtests might just be problems with your system that have no effect on the running of LinuxCNC.
So, let's try Buildbot again. What operating system are you using?
09 Dec 2016 19:40 #83840 by emad
Hi andy. Thanks for paying attention. I use debian wheezy. I follow these steps :
wget gemmei.acc.umu.se/mirror/cdimage/archive....0-i386-standard.iso
Don't set the Root password-I'm not sure about it-while installing the system and use a mirror.
Enter the recovery mode after the installer is finished.
sudo apt-get lightdm
sudo apt-get install libgl1-mesa-dri x11-xserver-utils gnome-session gnome-shell gnome-themes gnome-terminal gnome-control-center nautilus gnome-icon-theme nautilus mousepad --no-install-recommends
sudo rebooot
Adding the Linuxcnc
sudo apt-key adv --keyserver hkp://keys.gnupg.net --recv-key 3cb9fd148f374fef
sudo apt-get update
sudo apt-get install linux-image-3.4-9-686-pae
sudo update-grub
sudo reboot
sudo nano /etc/apt/sources.list
#add the line to get the Rtai kernel:
deb linuxcnc.org wheezy base
sudo apt-get update
sudo apt-get install linux-image-3.4-9-rtai-686-pae linux-headers-3.4-9-rtai-686-pae rtai-modules-3.4-9-rtai-686-pae
sudo update-grub
sudo reboot
sudo apt-get update
#Adding Buildbot archive signing key:
sudo apt-key adv --keyserver hkp://keys.gnupg.net --recv-key E0EE663E
sudo apt-get update
sudo apt-get install linuxcnc-dev linuxcnc
09 Dec 2016 19:43 #83841 by emad
There is a typo
Adding the Linuxcnc Rtai
09 Dec 2016 19:52 #83842 by emad
$uname -a
Linux Control 3.4-9-rtai-686-pae #1 SMP PREEMPT Debian 3.4.55-4linuxcnc i686 GNU/linux
09 Dec 2016 20:08 #83843 by andypugh
That all seems _very_ complicated.
Are you using any ethernet-controlled motion control hardware?
Your uname suggests that you are not currently running from the realtime kernel. You may have to select it from the Grub menu at boot. I think you hold down the shift key to force that to appear.
The easy way should be:
1) Install LinuxCNC and the realtime kernel and Debian Wheezy from the live-cd:
2) Add the buildbot to the package sources
3) Use Synaptic to get Master / 2.8
The following user(s) said Thank You: emad
09 Dec 2016 20:15 #83844 by emad
No, I don't use ethernet-controlled motion control hardware. Indeed I boot the RTAI kernel image. I'll make a new install as you said. I hope it works. Thanks for giving help, andy.
09 Dec 2016 21:26 #83846 by andypugh
With a fresh liveCD install, check that LinuxCNC works, then once that is going we can look at updating to 2.8
09 Dec 2016 21:52 #83848 by emad
I made a new install using the LiveCD. Linuxcnc is a live and working.
09 Dec 2016 22:03 #83849 by andypugh
OK, so, to get 2.8: (I will try to describe the GUI way).
System->Synaptic Package Manager
Settings-Repositories
(TAB)Other Software -> (Button)Add
Put in (as suggested by the buildbot at buildbot.linuxcnc.org)
deb buildbot.linuxcnc.org/ wheezy master-rt
Click "Add"
Now, close the dialog and press the "reload" button in Synaptic
There will be a complaint about keys. I think you can actually ignore that for the moment.
Now click the "search" button and look for linuxCNC. You should see a version 1:2.8.0_ja....
Select and install that.
Time to create page: 0.568 seconds
