Problem with amplifier enable
01 Jan 2017 11:52 #85029 by Holzwurm56
Problem with amplifier enable was created by Holzwurm56
Hello,
every of my servoamplifiers has a 24Volt output. This voltage must be switched to the enable input of the amplifier, for this i will use a relais. Can I switch powersupply5 or 24V > relais > ENAN+ > ENAN- > Ground? Its necessary to switch every amplifier seperate with EN0 - EN2, or can i switch on all three amplifiers with one enable output?
Hans
01 Jan 2017 12:36 #85032 by PCW
Replied by PCW on topic Problem with amplifier enable
normally you would not use relays but wire
+SERVO24V --> ENA+ --> ENA- --> SERVO-ENABLE (per axis)
01 Jan 2017 13:22 #85034 by Holzwurm56
Replied by Holzwurm56 on topic Problem with amplifier enable
Hello PCW,
many thanks for your answer. The relais will be a protection for the 7I77. I will measure the current from 24V to enable.
Hans
01 Jan 2017 14:21 #85035 by PCW
You may find that the servo enable current is quite a bit lower than the relay coil current
so you are better off driving the servo enables directly from the 7I77
Also, if you drive (small) relays from the ENA outputs you need to have a flyback diode across the relay coil
(and test the relay/flyback diode by hand wiring first, as a backwards flyback diode will damage the
7I77 OPTO isolator ENA driver)
01 Jan 2017 14:39 #85036 by Holzwurm56
Hello PCW,
thanks for your answer. The amplifiers have normally open contact that closes when the amplifier is ready to work. Can Linuxcnc with 5I25 and 7I77 read this signal and show on the display "amplifier not working" and stop the job?
Hans
01 Jan 2017 14:42 #85037 by PCW
yes, normally this get wired to axis.N.amp-fault-in in the hal file
02 Jan 2017 02:08 #85063 by Holzwurm56
Hello PCW,
I have some pneumatic valves and motor driver relais, some of these parts need more than 500mA. Can I switch them and the amplifier enable with solid state relais? I mean they do not have a back electromagnetic impuls?
Hans
02 Jan 2017 14:59 #85119 by Todd Zuercher
Replied by Todd Zuercher on topic Problem with amplifier enable
Yes, you can use a solid state relay to control them.
Time to create page: 0.874 seconds
