Why does external switch not work?
- Holzwurm56
- Thank you received: 6
17 Jan 2017 11:04 #85900
by Holzwurm56
Replied by Holzwurm56 on topic Why does external switch not work?
Hallo Norbert,
vielen Dank für deine Hilfe. So hat es funktioniert. Ob ich jemals begreife warum der Startbefehl funktioniert hat aber der Stopbefehl nicht,
das weiß ich nicht.
Dazu noch eine kleine Frage: Kann man es irgendwie machen das die Spindel nach dem Stopbefehl an eine bestimmte Position fährt?
MfG
Hans
das weiß ich nicht.
MfG
Hans
- Holzwurm56
17 Jan 2017 17:34 #85968
by Holzwurm56
Hello Norbert,
i am thinking wrong, when there is horizontal driller or a saw in the spindle there is a crush, when moving automaticly to a parkposition
when i push the stop switch, but is it possible an extra switch with i can move the spindle to a park position.
Hans
Habs in englisch probiert, da verstehen es vielleicht noch ein paar mehr.
Hans
- bevins
- Thank you received: 338
18 Jan 2017 21:08 #86093
by bevins
I am not 100% sure what your asking but i will take a stab at it.
You can use a physical button to move the xyz to where ever you want with mdi commands in your hal. Is that what your trying to do
And what machine is this on? By the sounds of it, it is a point to point router.......
Bob
Replied by bevins on topic Why does external switch not work?
Hello Norbert,
Hans
Bob
- Holzwurm56
18 Jan 2017 23:09 #86103
by Holzwurm56
Hello Bevins,
it's a maching center for wood, with vertikal and horizontal milling and drilling spindles. You are right, i looking for a physikal switch to move the axis to a definied xyz position.
Hans
Hans
- BigJohnT
- Thank you received: 994
18 Jan 2017 23:36 #86106
by BigJohnT
Replied by BigJohnT on topic Why does external switch not work?
Create a MDI command to move to the location you want and connect it to your switch in hal.
linuxcnc.org/docs/2.7/html/config/ini-co...ml#sec:halui-section
First add the MDI command then run your config and look at the show hal to see the pin name then connect it up in hal to your switch.
JT
JT
- bevins
19 Jan 2017 02:22 #86119
by bevins
Is it a Biesse by chance?
Hello Bevins,
Hans
- Holzwurm56
19 Jan 2017 08:30 #86133
by Holzwurm56
Hello Bevins,
it's a BIMA600U, Manufacturer IMA.
Hans
Hans
- bevins
19 Jan 2017 10:50 #86138
by bevins
WOW, Nice. Now thats some serious mortise horizontal milling.
I have the capabilities similar but not that robust of horizontal milling.
Good luck. How far have you got with the retrofit?
Bob
Hello Bevins,
Hans
Bob
- Holzwurm56
19 Jan 2017 11:27 #86140
by Holzwurm56
Hello Bevins,
the machine works in a basic job. The axis are moving, homing and running a g-code program. I have buy a new(used) drilling head with spindle distance from 32mm. The originial had 50mm. When the mechanical work of the machine is complete, i will test to write some subroutines for my furnituremaker job. I do not now of i am able to do this sucsessful, but i hope with help i can do it.
Hans
Hans
- bevins
19 Jan 2017 12:42 #86143
by bevins
Did you get your stop button working?
Hello Bevins,
Hans
Time to create page: 0.144 seconds
