hitachi wj200
9 years 9 months ago - 9 years 9 months ago #87087 by cmtunnel
Replied by cmtunnel on topic hitachi wj200
Awesome. How about the drive settings....should I just mimick what was done with the HY or are there more things to be concerned with. I just want to get the machine back online now and worry about the fancy stuff later...I'm just apprehensive after blowing the hy. I've got an ac reactor on the way also.
edit: also, should the motor be run in constant torque mode for a router?
Last edit: 9 years 9 months ago by cmtunnel.
9 years 9 months ago #87103 by andypugh
Replied by andypugh on topic hitachi wj200
I imagine the manual will take you through the setup? It helps if you have nameplate data from the motor, though
(Maybe write that in the manual)
9 years 9 months ago #87105 by cmtunnel
Yeah I've been working through it. I didn't know how many poles the spindle was so I used 4 and it seems to be running as it should. I'll get the analogue working tomorrow.
9 years 9 months ago #87116 by andypugh
cmtunnel wrote: Yeah I've been working through it. I didn't know how many poles the spindle was so I used 4 and it seems to be running as it should. I'll get the analogue working tomorrow.
You can figure out the pole count from the rated speed @ frequency.
3000 rpm @ 50 hz = 2 pole, 1500 rpm @ 50 Hz = 4 pole. etc.
9 years 8 months ago - 9 years 8 months ago #87272 by cmtunnel
is the water pump turned on by the relay on the vfd?
Last edit: 9 years 8 months ago by cmtunnel.
Time to create page: 0.139 seconds
