Super slow velocity issues....
9 years 5 months ago #93249 by rodw
Replied by rodw on topic Super slow velocity issues....
Also after reviewing the thread again and what Tommy said, review your homing setup. Here's mine
HOME_OFFSET = 45 HOME_SEARCH_VEL = 0 HOME_FINAL_VEL = 100 HOME_USE_INDEX = NO HOME_SEQUENCE = -1
See
linuxcnc.org/docs/html/config/ini-homing.html
Running a 7i76e
9 years 4 months ago #94411 by nigel-tufnel
Thanks Rod. I increased the STEPLEN value and I was able to make slow movements. However, this one axis is not as smooth as the other axes at slow speeds so it seems like there is more options for tuning. Below are my settings before increasing the STEPLEN.
DIRSETUP = 1000
DIRHOLD = 5000
STEPLEN = 500
STEPSPACE = 4500
If I increase the STEPLEN, do any of the other corresponding variables need to change accordingly? I'm using a Gecko G202. www.geckodrive.com/g202.html
Any suggested values appreciated. Thanks
9 years 4 months ago - 9 years 4 months ago #94418 by PCW
Replied by PCW on topic Super slow velocity issues....
Unless the settings are limiting your maximum speed there's usually no reason not to use longer step timings
in addition, long direction setup and hold times have very minimal effect on performance so
DIRSETUP = 20000
DIRHOLD = 20000
STEPLEN = 5000
STEPSPACE = 5000
is a good starting point that will work with almost all drives.
Note the this will limit you to 100 KHz maximum step rate
Last edit: 9 years 4 months ago by PCW.
Time to create page: 0.087 seconds
