Lathe tool changer turret - DC motor based
27 Sep 2017 10:47 #99514 by pippin88
I'm retrofitting a small CNC lathe (Hercus PC200) and I need some pointers on getting the turret going with Linuxcnc.
It's an 8 position tool turret driven by a DC gearmotor.
When the motor is rotating forward, the turret rotates.
There is a position sensor for each tool position (actually a single NC switch with a dimple causing switch trip near each tool position)
There is an index sensor (NC switch).
To lock, the motor is reversed, this drives 3 locking pins backwards. These have to line up with a plate which holes in it. The pins hit a plate when fully out, completing a circuit (locking sensor).
(Thus the turret can only rotate in one direction)
So it's a similar turret to many others that use a rotate then reverse onto a pawl. The difference is that the locking requires the locking pins to line up with the lock holes. The pins do have a taper on them to deal with some misalignment.
So far:
I have all the sensors detected in linuxcnc (index, locking, position).
I have a L298N H bridge driving the motor.
I have outputs from my 7i43 setup, such that I can turn the motor forward or reverse (0 0 = off, 1 0 = forward, 0 1 = reverse, 1 1 = off).
Difficulties:
The position switch does not line up exactly with where the tool should actually be and thus where the locking holes are. The turret will need to rotate a set distance or time past the position sensed point before the motor can reverse and lock.
I've been reading the documentation / forums and there are a number of ways to approach this:
Classicladder.
Adapt a user component.
Write a new component.
Can someone point me towards which would be the best starting point? I have a basic working understanding of LinuxCNC / hal, but no programming background.
Many thanks.
Locking plate/holes - behind the plate is a brass plate with a wire connected. The plate is otherwise isolated until the pins touch it.
Locking pins partially deployed
27 Sep 2017 13:32 #99518 by johnmc1
Replied by johnmc1 on topic Lathe tool changer turret - DC motor based
Good day,
Why is the centre pin tapered, maybe it is has something to do with helping centre the lock pins?
john
27 Sep 2017 20:34 #99528 by pippin88
Replied by pippin88 on topic Lathe tool changer turret - DC motor based
John,
It may be for that reason. That pin seems to come further out and appears to be the one that makes contact with the brass plate.
28 Sep 2017 07:06 #99540 by johnmc1
Good Day
Some of the hercus lathes were fitted with ANCA 2000 controllers that used resolver feed back on the servo motors.
Was your hercus fitted with a ANCA controller and what controller system are you going to use with your refit?
I have a hercus computurn lathe fitted with a anca controller that one day I will refit.
john
28 Sep 2017 07:27 #99541 by pippin88
John,
I believe mine was a DOS machine but did not come with the computer. The servos had encoders and what I think are tachometers.
I've removed the original electronics and motors.
For X and Z I'm using 381oz.in steppers driven by Leadshine DM856 drivers. Motion controller is LinuxCNC and Mesa 7i43 with 7i76.
Spindle will be a largish servo.
30 Sep 2017 12:29 #99676 by pippin88
I had not realised how the hal component system worked. Based on the excellent contributions of ArcEye (wiki.linuxcnc.org/cgi-bin/wiki.pl?ContributedComponents), I think I have something resembling a working component for my tool changer.
This is purely tested in simulation, but works as expected when I use a PYVCP to simulate the sensor inputs. I will have to work out the timing to get the locking right.
LinuxCNC HAL component to implement ATC toolchanging on Hercus PC200 Lathe
Based on "EMC2 HAL component to implement ATC toolchanging in Denford ORAC CNC lathes" (c) ArcEye 01122011 schooner30@tiscali.co.uk
Modified by pippin88 - 30/09/2017
All values are metric
Version 0a -  The PC200 toolchanger has an 8 position unidirectional turret. There is an index sensor (PC200changer.index),
              and a position sensor (PC200changer.pocket) that pulses once per tool position.
  			      When the motor moves forwards, the turret rotates. When the motor is reveresed, locking pins deploy, interfacing with a locking disc.
              When the locking pins are fully deployed, they close a circuit (PC200changer.lock)
              The sensors do not line up exactly with the actual tool position, but are a set offset.
              To allow the ATC time to get past the sensor and line the locking pins up with the holes, a timedelay component
              is used with the on-delay set to X seconds.
              This is activated automatically by the PC200changer component with the hal connections shown below.
              The turret uses a simple DC motor. This is driven by an H-bridge (L298N) which takes two input signals to determine direction.
              motor A and motor B. A HIGH, B HIGH = motor off; A HIGH, B LOW = motor forward; A LOW, B HIGH = motor reverse; A LOW, B LOW = motor off;
              I use A HIGH, B HIGH for off, as this is less susceptible to noise than a resting LOW state.
              To cater for the delay in mechanical relays switching the motor on and off and forward and reverse, and to allow the motor
              itself to cease movement, there is a simple counter delay in the component.
              The period of this delay is set by default to 500, which equates to 1-2 secs on my test system
              It can be modified in the .hal file using
              'setp PC200changer.times nnn' where nnn is the new value
               Compile the components with 'sudo comp --install PC200changer.comp'
               and                         'sudo comp --install timedelay2.comp' respectively
               Below .hal file extracts give a specimen .hal connection guide. Place them as appropriate in .hal file
# loading the toolchange and timedelay2 components in .hal file
loadrt PC200changer
addf PC200changer servo-thread
#loadrt timedelay count=1
#addf timedelay.0 servo-thread
### will wait 5 secs approx
#setp timedelay.0.on-delay 5
net tool-change iocontrol.0.tool-change => PC200changer.toolchange
net tool-changed iocontrol.0.tool-changed <= PC200changer.toolchanged
net tool-number iocontrol.0.tool-prep-number => PC200changer.toolnumber
net tool-oldnumber iocontrol.0.tool-number => PC200changer.currenttoolnumber
net turret-lock PC200changer.lock <= hm2_7i43.0.7i76.0.0.input-25 #Turret Lock sensor (White)
net turret-index PC200changer.index <= hm2_7i43.0.7i76.0.0.input-26 #Turret Index (Green)
net turret-position PC200changer.pocket <= hm2_7i43.0.7i76.0.0.input-27 #Turret Pulse (Blue)
## GPIO33 = Turret motorA
setp hm2_7i43.0.gpio.033.is_output true
setp hm2_7i43.0.gpio.033.out true ### pull high at startup!!! Can change if needed
## GPIO34 = Turret motorB
setp hm2_7i43.0.gpio.034.is_output true
setp hm2_7i43.0.gpio.034.out true ### pull high at startup!!! Can change if needed
net turret-motorA PC200changer.motorA => hm2_7i43.0.gpio.033.out
net turret-motorB PC200changer.motorB => hm2_7i43.0.gpio.034.out
net xhomed axis.0.homed => PC200changer.ishomedX
net zhomed axis.2.homed => PC200changer.ishomedZ
setp PC200changer.times nnn ### where nnn is the new value
#net delaystart timedelay.0.in <= PC200changer.delaystart
#net delaydone timedelay.0.out => PC200changer.delaydone
component PC200changer                  "This component controls the PC200 Lathe Auto Tool Changer. M6 calls this";
pin in bit toolchange                   "Receives signal from M6 that tool change required";
pin in s32 reqtoolnumber                "Requested Tool Number - Tx data from M6. Only 1-8 allowed";
pin in s32 currenttoolnumber            "Receives old tool number from hal / axis";
pin out bit toolchanged = false         "Sends signal when tool change finished";
pin out bit delaystart = false          "Starts timerdelay";
pin in bit delaydone =false             "Signals timer finished";
pin in bit index = 1                    "State of turret index sensor";
pin in bit pocket = 1                   "State of turret pocket sensor";
pin in bit lock = 1                     "State of turret lock sensor";
pin out bit motorA = 1                  "Motor signal A";
pin out bit motorB = 1                  "Motor signal B";
pin in bit ishomedX = false             "Status of X axis homing";
pin in bit ishomedZ = false             "Status of Z axis homing";
pin out s32 position = 0                "Turret Position - Initialised as a pin for debugging so we can check where it thinks it is";
pin out s32 turrethomed = 0             "Turret Homed signal - Initialised as a pin for debugging so we can check where it thinks it is";
param rw float times = 5000             "Length of delay for forward move before locking";
// Internal and debugging stuff
pin out s32 progresslevel = 0;         // tracks the progress of the toolchange, just here so it can be read easily
pin out s32 tnumber = 0;               // Internal toolnumber to allow overrun of quadrant by 1 then reverse back onto it
variable bool bWarn = false;            // first toolnumber reminder
variable float sleeptime = 0;           // our own timer to set delay for locking - set to 0 for first run
variable int indexState = 1;           // current state of the index signal - for rising edge
variable int lastindexState = 1;       // previous state of the index signal - for rising edge
variable int pocketState = 1;           // current state of the pocket signal - for rising edge
variable int lastpocketState = 1;       // previous state of the pocket signal - for rising edge
variable int lockState = 1;           // current state of the pocket signal - for rising edge
variable int lastlockState = 1;       // previous state of the pocket signal - for rising edge
option singleton yes;                   // makes no sense to have more than one of these components running - only one ATC
function _;
author "pippin88 pippin88@imagineant.com";
license "GPL";
FUNCTION(_)
    switch (progresslevel)
        case 0:  // idle waiting for toolchange request
                //first make sure X and Z axes are homed. If turret is not homed, home it
                if((toolchange==1)&&(turrethomed==0)&&(ishomedX)&&(ishomedZ)){
                  progresslevel = 1; //call case 1 - homing sequence
                  break;
                if(toolchange==1 && toolchanged==0 && turrethomed==1) { // if tool change requested and not done and turret already homed
                    if(currenttoolnumber && reqtoolnumber != currenttoolnumber && reqtoolnumber > 0 && reqtoolnumber < 9) { // if a valid number
                        // switch off motor if already on - both pins high = stop
                        motorA = 1;    //    "Motor input A";
                        motorB = 1;    //    "Motor input B";
                        //delaystart = false;         //new toolchange - reset comp
                        sleeptime = 0;
                        progresslevel = 2; //call case 2
                        break;
                    else    // if tool requested is out of range set the toolchanged flag via case 5 and exit
                            // should only get this if tool table has more tools than ATC can have
                            // otherwise emc will error the M6 command
                        progresslevel = 5;
                if(toolchange==0 && toolchanged==1)
                      //Turn motor OFF
                      toolchanged = false;           // reset toolchange flag after reset by linuxcnc
                if(toolchange && currenttoolnumber==0) // if no tool is set in axis - set axis to tool requested so that can work next time
                     progresslevel = 5;
                break;
        case 1: // homing
                motorA = 0;    //    "Motor input A"; //need to check direction!!!!
                // use a state machine to detect the index pulse only once
                indexState = index; // read the pocket sensor input pin
                if (lastindexState != indexState) { // compare the pocketState to its previous state
                    if (index == 1) {   // if the current state is HIGH then the index went from off to on - RISING EDGE
                      //motorA = 1;
                      //motorB = 1;
                      position = 1; //Set Tool Pocket 1
                      turrethomed = 1; //Set turrent homed flag
                      progresslevel = 2; //move to motor forward sequence
                lastindexState = indexState; //store indexState for comparison next time around
                break; // index not triggered - get out of case 1 and go round again
        case 2: // Turns on motor forward
                // Run forward - need to clarify pins etc
                progresslevel = 3;
                break; //get out of case 2 - - go round again
        case 3: // Forward move until desired tool position
                if(position==0)  // if returning 0 something is wrong - should be homed and at pocket 1 at least
                   rtapi_print_msg(RTAPI_MSG_ERR, "Error - counter error");
                   progresslevel = 12; // doesn't exist so will go to default, output msg and then sit in level 10
                   break;
                //use a state machine to detect pocket sensor once per position only
                pocketState = pocket; // read the pocket sensor input pin
                if (lastpocketState != pocketState) { // compare the pocketState to its previous state
                    if (pocket == 1) {   // if the state has changed, increment the counter
                      // if the current state is HIGH then the button went from off to on - RISING EDGE
                      position++;
                      if(position > 8)             // add 1 so that stops on sector after required & reverses back to it
                      position = position - 8;
                lastpocketState = pocketState;    // save the current state as the last state, for next time through the loop
                sleeptime = 0; //reset counter to 0
                //delaystart = true; //signal to linuxcnc there will be a delay
                if (position == reqtoolnumber) {
                  progresslevel = 4; //move to case 3
                break; //get out of case 2 - go round again
        case 4: // Locking sequence
                // programmed delay to allow time to align with locking holes
                if(sleeptime < times)
                      sleeptime++;
                      break;
                // Reverse locking move - need to clarify pins etc
                motorB = 0;    //    "Motor input B";
                //use a state machine to detect lock sensor once only - detect falling edge
                lockState = lock; // read the pocket sensor input pin
                if (lastlockState != lockState) { // compare the pocketState to its previous state
                    if (lock == 0) {   // if the state has changed, increment the counter
                      // if the current state is LOW then the lock circuit has grounded
                      //Turn motor OFF
                      progresslevel = 5; // after first toolchange or update of tool number this is default
                lastlockState = lockState;    // save the current state as the last state, for next time through the loop
                break;  //get out of case 3 - go round again
        case 5: // clean up ready for next toolchange
                //delaystart = true;     // start the 5 second delay relay component to give time to latch
                progresslevel = 0;
                //delaystart=false;
                toolchanged = true;   // signal finished
                break; //get out of case 5 - go round again
        case 10:   break;  // should never get here but if we do then loop endlessly doing nothing
        default:
                progresslevel = 10;
                rtapi_print_msg(RTAPI_MSG_ERR, "Error state in PC200changer - now disabled - unload PC200changer");
                break;
The following user(s) said Thank You: johnmc1
07 Oct 2017 03:28 - 19 Oct 2017 21:31 #100032 by pippin88
Below code works on my machine. Slightly different approach from code posted earlier, as I worked out a bit more about how the turret works mechanically and under the old controller.
Modified by pippin88 - 07/10/2017
Version 0c -  The PC200 toolchanger has an 8 position unidirectional turret. There is an index sensor (PC200changer.index),
  			      When the motor moves forwards, the turret rotates forward.
              The position sensor does not line up exactly with the actual tool position, but is past the tool position a bit
               - the turret reverses until the spring-loaded pins line up and jump into the locking holes.
               Compile the component with 'sudo comp --install PC200changer.comp'
# loading the toolchange component in .hal file
loadrt PC200changer
net tool-number iocontrol.0.tool-prep-number => PC200changer.reqtoolnumber
net turret-pocket PC200changer.pocket <= hm2_7i43.0.7i76.0.0.input-27 #Turret Pulse (Blue)
net xhomed joint.0.homed => PC200changer.ishomedX
net zhomed joint.1.homed => PC200changer.ishomedZ
#setp PC200changer.times 125 ### where nnn is the new value - sets a sleep timer
pin out s32 turretposition = 0          "Turret Position - Initialised as a pin for debugging so we can check where it thinks it is";
param rw float times = 290             "Length of delay";
//pin out s32 tnumber = 0;               // Internal toolnumber to allow overrun of quadrant by 1 then reverse back onto it
pin out bit indexState = 1;           // current state of the index signal - for rising edge
pin out bit lastindexState = 1;       // previous state of the index signal - for rising edge
pin out bit unlockState = 1;           // current state of the index signal - for rising edge
pin out bit lastunlockState = 1;       // previous state of the index signal - for rising edge
pin out bit pocketState = 1;           // current state of the pocket signal - for rising edge
pin out bit lastpocketState = 1;       // previous state of the pocket signal - for rising edge
pin out bit lockState = 1;           // current state of the pocket signal - lock is detected on falling edge
pin out bit lastlockState = 1;       // previous state of the pocket signal
pin out bit turretislocked = 0;
function _;
license "GPL";
FUNCTION(_)
    switch (progresslevel)  {
                      break;
                if((toolchange==1)&&(toolchanged==0)&&(turrethomed==1)) { // if tool change requested and not done and turret already homed
                            //sleeptime = 0;
                            break;
                          progresslevel = 5;
                if(!toolchange) {
                      //Turn motor OFF
                      toolchanged = 0;           // reset toolchange flag after reset by linuxcnc
                //if(toolchange && currenttoolnumber==0) // if no tool is set in axis - set axis to tool requested so that can work next time
                //     motorA = 1;    //    "Motor input A";
                //     motorB = 1;    //    "Motor input B";
                //     progresslevel = 5;
                break;
        case 1: // HOMING SEQUENCE
                // Turn motor forward
                indexState = index; // read the index sensor input pin
                if (lastindexState != indexState) { // compare the indexState to its previous state
                      if (index == 0) {   // if the current state is LOW then the index went from ON to OFF - FALLING EDGE
                          turretposition = 8; //Set Tool Pocket 1
                  			  if (reqtoolnumber == 8){
                              progresslevel = 4; //move to locking sequence
                  			  } else {
        case 2: // UNLOCKING - use first pocket pulse to show that turret unlocked, and to prevent that first pulse counting as a position increment
                unlockState = pocket; // read the pocket sensor input pin
                if (lastunlockState != unlockState) { // compare the pocketState to its previous state
                      if (pocket == 1) { // if the current state is HIGH then the button went from OFF to ON - RISING EDGE
                          progresslevel = 3;
                lastunlockState = unlockState;    // save the current state as the last state, for next time through the loop
        case 3: // FORWARD TOOL FIND SEQUENCE - Forward move until desired tool position
                if(turretposition==0) { // if returning 0 something is wrong - should be homed and at pocket 1 at least
                      break;
                      if (pocket == 0) {   // if the state has changed, increment the counter
                      // if the current state is LOW then the button went from ON to OFF - FALLING EDGE
                          turretposition++; //increment tool position counter
                          if(turretposition > 8)
                          turretposition = turretposition - 8; //we have gone round from 8 to 1
                if (turretposition == reqtoolnumber) {
                      progresslevel = 4; //move to case 4
        case 4: // LOCKING SEQUENCE
                      //Turn motor OFF
                      turretislocked = 1;
                      progresslevel = 5;
                break;  //get out of case 4 - go round again
                //sleeptime = 0;
                progresslevel = 6;
                toolchanged = 1;   // signal finished
        case 6:
              //if(sleeptime < 1)
              //      sleeptime++;
              //      break;
                progresslevel = 0;
                break;
        default:
                progresslevel = 10;
                break;
Last edit: 19 Oct 2017 21:31 by pippin88.
07 Apr 2020 14:49 #163064 by AndrewL
Replied by AndrewL on topic Lathe tool changer turret - DC motor based
I am interested in using the code you've posted on turret tool changer using a hydraulic motor, position sensor, and a lock pin. How do I use what you have written for my configuration?
I do not know how to use the .comp
I see this line in your code:
But I don't know how to use it and if I try it in the command line I get a 'comp: command not found'. Is this something that will only work on a development version of linuxcnc or can I incorporate it into what I have (2.7.14)?
  • Moderator
  • Moderator
07 Apr 2020 22:38 #163110 by tommylight
Replied by tommylight on topic Lathe tool changer turret - DC motor based
It does require development version installed, easy to do using synaptics, seems you have a Wheezy installation.
And the command comp is now halcompile, so just replace that when installing the component.
08 Apr 2020 02:12 #163145 by AndrewL
Thank you. Yes I have a Wheezy uspace install. Is wheezy 2.8-rtpreempt the one I'll need?
Time to create page: 0.307 seconds
