Change default path following to G61?
06 Nov 2017 17:58 #101446 by rogerxue
Change default path following to G61? was created by rogerxue
Is there a way to change the default path following mode to exact? i.e. G61 instead of the blend mode?
thanks
06 Nov 2017 23:27 #101470 by BigJohnT
Replied by BigJohnT on topic Change default path following to G61?
Yes, have each G code program have a good preamble to set up the environment as you need it.
gnipsel.com/linuxcnc/g-code/gen01.html
JT
06 Nov 2017 23:38 #101471 by rogerxue
Replied by rogerxue on topic Change default path following to G61?
thanks for the reply, is there a place I can put the preamble in so each file don't need to have it?
06 Nov 2017 23:39 #101472 by BigJohnT
Well you could have a subroutine with the preamble and call it at the start of each G code file.
JT
06 Nov 2017 23:47 #101474 by rogerxue
I found this: linuxcnc.org/docs/2.6/html/config/ini_co...sub:RS274NGC-section
seems it is the right place to put the preamble ?
It says: "This is not a substitute for specifying modal g-codes at the top of each ngc file" does that mean each file can override the preamble?
06 Nov 2017 23:51 #101475 by BigJohnT
Exactly, never rely on the settings to be as you want after you run a G code file. Always put the preamble in each G code file.
JT
06 Nov 2017 23:55 #101476 by rogerxue
makes sense, but it would be nice to have a fall back default value, in case I forgot to include anything in the G file. In my case, I want to use G61 instead of the default blend mode. Is the RS274NGC the right place to put the default value?
08 Nov 2017 15:03 #101521 by bevins
Replied by bevins on topic Change default path following to G61?
Put it in your preample in your post processor of your CAM....no?
09 Nov 2017 13:13 #101549 by andypugh
Replied by andypugh on topic Change default path following to G61?
If you forget to put it in the first G-code file of the day then the INI file section will work.
But after you have run G-code, all bets are off about machine state.
  • Todd Zuercher
  • Todd Zuercher's Avatar
  • Platinum Member
  • Platinum Member
09 Nov 2017 15:27 #101560 by Todd Zuercher
Replied by Todd Zuercher on topic Change default path following to G61?
One thing that could be done, that would always work. You could create a script that inserts the line or lines of G-code you want at the start of every file when it is loaded. If you needed different settings in a file, having those codes already in the file, would override the inserted codes for that file, as they would be executed after the inserted codes.
Time to create page: 0.202 seconds
