NET: can not add OUT pin .. it already has out pin
- AndrewHsasku
11 Dec 2017 19:08 #102927
by AndrewHsasku
NET: can not add OUT pin .. it already has out pin was created by AndrewHsasku
How net function should work? Why I can't connect one input to two outputs?or
net enable axis.0.amp-enable-out => driver.enable x-pid.enablenet enable <= axis.0.amp-enable-out
net enable => driver.enable
net enable => x-pid.enablePlease Log in or Create an account to join the conversation.
- Thank you received: 1482
11 Dec 2017 20:10 - 11 Dec 2017 20:40 #102931
Replied by Todd Zuercher on topic NET: can not add OUT pin .. it already has out pin
Multiple in pins can be connected to an out, but only one out can ever be connected to a signal.
If for some reason you need to use more than one source for a signal, you can use an or2 or another hal logic component.
linuxcnc.org/docs/html/man/man9/or2.9.html
Example
Now the example you gave looks like it only has one output pin (axis.0.amp-enable-out) and two input pins, so it shouldn't be a problem. (I say this guessing that "driver.enable" is supposed to represent some GPIO input pin that sends a signal out to enable your drive, such as parport.0.pin-09-out.)
Example
loadrt or2 count=1
addf or2.0 servo-thread
net outpin1 <= some.hal-out1 => or2.0.in0
net outpin2 <= some.hal-out2 => or2.0.in1
net target <= or2.0.outNow the example you gave looks like it only has one output pin (axis.0.amp-enable-out) and two input pins, so it shouldn't be a problem. (I say this guessing that "driver.enable" is supposed to represent some GPIO input pin that sends a signal out to enable your drive, such as parport.0.pin-09-out.)
Last edit: 11 Dec 2017 20:40 by Todd Zuercher.
- AndrewHsasku
11 Dec 2017 20:31 - 11 Dec 2017 20:37 #102933
by AndrewHsasku
Replied by AndrewHsasku on topic NET: can not add OUT pin .. it already has out pin
Don't get it. Once again - one pin is an input. This input is casted as a signal. This signal is transmitted to multiple output pins.
As it is written here: linuxcnc.org/docs/2.5/html/hal/basic_hal...#_net_a_id_sub_net_aThis is my case, that prints error.
Maybe there is a missconception about input and output. I mean input as an input for net function.
# signal source destination destination
net xStep stepgen.0.out => parport.0.pin-02-out parport.0.pin-08-outMaybe there is a missconception about input and output. I mean input as an input for net function.
Last edit: 11 Dec 2017 20:37 by AndrewHsasku.
11 Dec 2017 20:46 #102936
That line of hal code should not give you any problems due to multiple out pins, as both of the parport pins you have there are both hal input pins. (It is a little confusing since in hal they receive the signal as an input that the parallel port sends out.)
If you are getting a fault because of something to do with that line, it is possible that signal name is used somewhere else in your hal file(s) where another output (or even possibly the same one) is connected to it.
- AndrewHsasku
11 Dec 2017 22:50 - 11 Dec 2017 23:10 #102946
by AndrewHsasku
It seems that any net connection that output is my driver's pin results in such error
exact line looks for example like that:
net x-enable axis.0.amp-enable-out => x-pid.enable driver.axis_x.enable
net x-vel-cmd x-pid.output => driver.axis_x.velocity
Last edit: 11 Dec 2017 23:10 by AndrewHsasku.
12 Dec 2017 03:51 #102970
If you could post a copy of your whole hal file.
- ozzyrob
- Visitor
12 Dec 2017 04:37 #102974
by ozzyrob
Replied by ozzyrob on topic NET: can not add OUT pin .. it already has out pin
If you can run halrun and load your driver, then run show pin that will show the pins available from your driver and their directions.
No need to run a whole configuration.
- AndrewHsasku
12 Dec 2017 13:39 - 12 Dec 2017 13:56 #102994
by AndrewHsasku
Thanks, it started working
I used hal_pin_bit_newf(HAL_OUT not hal_pin_bit_newf(HAL_IN
Last edit: 12 Dec 2017 13:56 by AndrewHsasku.
- ozzyrob
- Visitor
12 Dec 2017 16:48 #103011
by ozzyrob
So you zigged when you should have zagged ?
Glad you got it sorted
Time to create page: 0.167 seconds
