Joint 0 following error. Error on axis 0, command number X
8 years 10 months ago #102997 by AndrewHsasku
I am trying to develop my configuration.
At the moment I am having problem with error
printed in linuxCNC and
printed in terminal.
No idea what I miss in .ini/.hal/.c. Projects uses trivkins and pid. FERROR for each axis is set to 1. LinuxCNC is installed on VirtualBox. When starting I also receive an error
Unexpected realtime delay on task 1
. Latency is nearly 1s (nothing strange when it is installed on virtual machine).
What would be a reason of this error: something missed or just latency?
8 years 10 months ago #102999 by BigJohnT
You can't run LinuxCNC from a Virtual Box as it's not real time.
JT
8 years 10 months ago #103004 by PCW
If you are just testing the driver and don't care about motion behaviour you can loop back the
commanded position to the feedback position and avoid following error faults
8 years 10 months ago #103008 by AndrewHsasku
Looping feedback and position changes nothing.
Thats part of my hal:
# THREADS # ################################################ addf driver.read servo-thread addf motion-command-handler servo-thread addf motion-controller servo-thread addf x-pid.do-pid-calcs servo-thread addf y-pid.do-pid-calcs servo-thread addf z-pid.do-pid-calcs servo-thread addf a-pid.do-pid-calcs servo-thread addf driver.write servo-thread # PID # ################################################ setp z-pid.Pgain 1.0 setp z-pid.Igain 0.0 setp z-pid.Dgain 0.0 setp z-pid.FF0 0.0 setp z-pid.FF1 1.0 setp z-pid.FF2 0.0 setp z-pid.deadband 0.01 setp z-pid.maxoutput 200.0 net z-enable axis.2.amp-enable-out => z-pid.enable driver.axis_z.enable net z-pos-cmd axis.2.motor-pos-cmd => z-pid.command net z-pos-fb driver.axis_z.position => z-pid.feedback axis.2.motor-pos-fb net z-vel-cmd z-pid.output => driver.axis_z.velocity net z-fault driver.axis_z.fault => axis.2.amp-fault-in
My functions write and read do not execute
8 years 10 months ago #103012 by PCW
You did not loop back command to position, that would be done something like this:
net zpos axis.2.motor-pos-fb axis.2.motor-pos-cmd
8 years 10 months ago #103014 by AndrewHsasku
Yeah, pasted one is my original code before changes. I have tried suggested changes rather like below and it didn't helped
net z-pos-cmd axis.2.motor-pos-cmd => z-pid.command net z-vel-cmd z-pid.output => z-pid.feedback axis.2.motor-pos-fb
Anyway just feed backing this way will just omit my driver.
Inside driver code, in read function, just for current tests, there is cloning data from driver.axis_z.velocity to driver.axis_z.position. However as far, read function do not execute.
Time to create page: 0.543 seconds
