- Configuring LinuxCNC
- Basic Configuration
- Functions do not execute, rtapi_print_msg do not print anything
- GingerPotato
12 Dec 2017 23:25 #103047
by GingerPotato
Functions do not execute, rtapi_print_msg do not print anything was created by GingerPotato
Hi all!
I am working on driver. Inside .hal I add functions like:In code I export it with:
Unfortunately function my_function do not execute.
Looking further I start thinking that nothing in my driver doesn't execute: none of rtapi_print_msg prints in terminal, parameters (pins) changed in code (inside rtapi_app_main) are not changed in linuxcnc.
On the other hand, changing function name without its changing in .hal cause error, so some part of code is being executed.
What can I do?
loadrt my-driver
addf my-driver.func servo-threadrtapi_snprintf(name, HAL_NAME_LEN, "%s.func", NAME);
hal_export_funct(name, my_function, NULL, 0, 0, comp_id)Unfortunately function my_function do not execute.
What can I do?
- GingerPotato
12 Dec 2017 23:26 #103048
by GingerPotato
Replied by GingerPotato on topic Functions do not execute, rtapi_print_msg do not print anything
I could send whole driver and configuration packed if someone would be able to look at it
- Thank you received: 4149
15 Dec 2017 22:07 #103146
Replied by rodw on topic Functions do not execute, rtapi_print_msg do not print anything
Sounds like you are not using halcompile. It will make your life so much easier and there will be no need for the export_func
- Thank you received: 4654
16 Dec 2017 01:48 #103151
Replied by andypugh on topic Functions do not execute, rtapi_print_msg do not print anything
If you are using RTAI then your rtapi_print will probably end up in dmesg, not at the terminal.
Time to create page: 0.496 seconds
