Mesa 5i25+7i76 position-fb running
  • grijalvap
  • grijalvap's Avatar Topic Author
  • Elite Member
  • Elite Member
11 Jan 2018 05:23 #104271 by grijalvap
Mesa 5i25+7i76 position-fb running was created by grijalvap
Hi
I have a configuration with mesa 5i25+one 7i76 running on 2.8 master, it was working fine until yesterday when I turn on the equipment, all the axis are getting feedback. even if the machine e-stop is off and the input command is 0,
does anybody have any clue?
Here is a small video of the DRO
thanks..
11 Jan 2018 13:10 #104288 by PCW
Replied by PCW on topic Mesa 5i25+7i76 position-fb running
That's really strange. If its not something really odd in hal
its looks like a PCI/5I25 connection issue (card partially out of slot/ dirty contacts/etc)
  • grijalvap
  • Elite Member
  • Elite Member
11 Jan 2018 23:05 #104314 by grijalvap
Replied by grijalvap on topic Mesa 5i25+7i76 position-fb running
Hi
I have double checked the installation and it is ok, then I replaced the 5i25 card with other and it behaves in the same way.
do you recommend install LinuxCNC again?
Thanks.
11 Jan 2018 23:23 - 11 Jan 2018 23:32 #104315 by PCW
That's really bizarre... can you do:
halcmd show all > all.txt
when its behaving this way
and attach the all.txt file here?
Last edit: 11 Jan 2018 23:32 by PCW.
  • grijalvap
  • Elite Member
  • Elite Member
11 Jan 2018 23:42 #104317 by grijalvap
hi
here is the file thanks for your help
File Name: all.txt
File Size:81 KB
12 Jan 2018 00:24 #104320 by PCW
Well if the count is changing and the stepgen commanded velocity is 0 , I really have no clue
bug in master? Hardware failure on PC? Really only guessing now
  • grijalvap
  • Elite Member
  • Elite Member
12 Jan 2018 00:28 #104321 by grijalvap
well i think it start after one upgrade.
How we can make this message visible to mesa people.
12 Jan 2018 01:01 #104325 by skunkworks
Replied by skunkworks on topic Mesa 5i25+7i76 position-fb running
I think seb was seeing this on the tip of master...
tom-itx.no-ip.biz:81/~tom-itx/irc/logs/%...evel/2018-01-10.html
(on irc)
12 Jan 2018 04:07 #104329 by seb_kuzminsky
Replied by seb_kuzminsky on topic Mesa 5i25+7i76 position-fb running
That sounds similar to what I was seeing. Please post the output of this command:
grep 'upgrade linuxcnc' /var/log/dpkg.log
  • grijalvap
  • Elite Member
  • Elite Member
12 Jan 2018 04:17 #104330 by grijalvap
thanks
here is the result file
Time to create page: 0.191 seconds
