Probe error!
25 Jan 2018 10:19 #104995 by sarcokiller
Probe error! was created by sarcokiller
Hi all, I managed to install all correctly and my machine it's working fine. However when I try to say from the "stepconf wizard" that I have a probe on the Pin 11 of my board, when I try to open my configuration and jog, I got always this error:
"Probe tripped during a jog"
And in this way I can't jog, I receive this error every time I try to jog.
From the Hal meter I can see that my probe is working correctly, so I can't figure out the reason of this error that I got.
Can you help me?
Thanks a lot
25 Jan 2018 11:59 #104996 by tecno
Replied by tecno on topic Probe error!
What about MDI?
The following user(s) said Thank You: sarcokiller
25 Jan 2018 12:02 #104997 by sarcokiller
Replied by sarcokiller on topic Probe error!
Can't perform MDI moves too! Every time I try to move something I got the error. The probe is always disconnected of course but it gives me error as soon as I move an axis. If you need more information tell me (I'm sorry I'm new on linux cnc configurations)
25 Jan 2018 12:19 #104998 by Clive S
Replied by Clive S on topic Probe error!
It would help people if you posted your config files from the config folder ie xxx.ini and xxx.hal
25 Jan 2018 12:44 - 25 Jan 2018 20:24 #105000 by sarcokiller
Ok, thank you for the reply!
Attachment not found
EDIT:
SOLVED!
I solved the problem setting debounce to Probe-in signal!
Last edit: 25 Jan 2018 20:24 by sarcokiller.
Time to create page: 0.080 seconds
