Zelrp + Linuxcnc 2.7.12 + THC 150
- dyzio215
23 Feb 2018 18:57 #106409
by dyzio215
Replied by dyzio215 on topic Zelrp + Linuxcnc 2.7.12 + THC 150
Thank You for fast reply! Have U any idea about slow speed?
- Thank you received: 7478
23 Feb 2018 19:35 #106412
Replied by tommylight on topic Zelrp + Linuxcnc 2.7.12 + THC 150
Did you check if the scaling is ok?
You have to set the scaling correctly, after you can test the velocity and acceleration . If you have the Z axis move to fast or not move at all, check the proma thc thread on this forum on how to fix that.
- dyzio215
23 Feb 2018 21:01 #106416
by dyzio215
I take scale and other information from my old configuration (stepconf) and it worked there ok
24 Feb 2018 04:29 #106422
Nice.
What exactly is the low speed in your case? 800 what? mm/s?
If you are getting joint errors at higher speeds, check the acceleration, it should be 200 to 750 mm/s/s for a plasma cutter.
forum.linuxcnc.org/49-basic-configuratio...hc-config-that-works
Nice.
- dyzio215
24 Feb 2018 08:05 #106426
by dyzio215
Max what can i set and work is 800mm/min. For 1mm plate i need 2-3m/min...
- Thank you received: 4149
24 Feb 2018 08:37 #106427
Replied by rodw on topic Zelrp + Linuxcnc 2.7.12 + THC 150
When you are talking about being slow is that when jogging or when running gcode?
When jogging, speed is determined by
and set in machine units per second
[DISPLAY]
DEFAULT_LINEAR_VELOCITY = 120and set in machine units per second
- dyzio215
24 Feb 2018 09:02 - 24 Feb 2018 10:23 #106428
by dyzio215
You're right! Now i have 4200mm/min without problem
Next week first test! I was sending my thc to repair (problem with up down signal...) Thanks for all! And have a good weekend
Last edit: 24 Feb 2018 10:23 by dyzio215.
24 Feb 2018 19:59 #106442
Glad you got it working.
- dyzio215
07 Mar 2018 17:44 - 07 Mar 2018 23:16 #107083
by dyzio215
OK OK !
I read instruction and now i know what I must to do
Last edit: 07 Mar 2018 23:16 by dyzio215.
- dyzio215
09 Mar 2018 08:11 #107138
by dyzio215
What can i do when i have too slow move Z axis? When i change to up step size torch move faster but have slow reaction between up and down.
Time to create page: 0.190 seconds
