Axis Creep
  • Todd Zuercher
  • Todd Zuercher's Avatar
  • Platinum Member
  • Platinum Member
28 Mar 2018 12:35 - 28 Mar 2018 12:36 #108030 by Todd Zuercher
Replied by Todd Zuercher on topic Axis Creep
Have you considered the possibility that it could be a noise issue on your MPG encoder inputs?
Monitor the counts for the MPG encoder(s) while you are experiencing the drift problem. You should look at their A&B input pins with Halscope, (looking for signal noise).
Last edit: 28 Mar 2018 12:36 by Todd Zuercher.
  • Nitram
  • Nitram's Avatar Topic Author
  • Elite Member
  • Elite Member
29 Mar 2018 02:00 - 29 Mar 2018 02:01 #108056 by Nitram
Replied by Nitram on topic Axis Creep
Hi Peter.
Below is an extract from the HAL file referring to MPG movement.
To help identify, the MPG is connected to a 7i84 set to encoder mode, it is the first of three 7i84's and is thus addressed 0.
Namely hm2_5i24.0.7i84.0.0..........
I seem to recall a section was included to smooth jogging motion but as I glance over the HAL file it is not apparent to me.
Complete HAL and INI files attached a few posts up.
Thanks,
Marty.
# ---jogwheel signals to mesa encoder - shared MPG---
net joint-selected-count <= hm2_5i24.0.7i84.0.0.enc0.count
# ---mpg signals---
# for axis x MPG
setp axis.0.jog-vel-mode 0
net selected-jog-incr => axis.0.jog-scale
net joint-select-a => axis.0.jog-enable
net joint-selected-count => axis.0.jog-counts
# for axis y MPG
setp axis.1.jog-vel-mode 0
net selected-jog-incr => axis.1.jog-scale
net joint-select-b => axis.1.jog-enable
net joint-selected-count => axis.1.jog-counts
# for axis z MPG
setp axis.2.jog-vel-mode 0
net selected-jog-incr => axis.2.jog-scale
net joint-select-c => axis.2.jog-enable
net joint-selected-count => axis.2.jog-counts
# for axis 4th MPG
setp axis.3.jog-vel-mode 0
net selected-jog-incr => axis.3.jog-scale
net joint-select-d => axis.3.jog-enable
net joint-selected-count => axis.3.jog-counts
# connect selectable mpg jog increments
net jog-incr-a => jogincr.sel0
net jog-incr-b => jogincr.sel1
net jog-incr-c => jogincr.sel2
#net jog-incr-d => jogincr.sel3
net selected-jog-incr <= jogincr.out-f
setp jogincr.debounce-time 0.200000
setp jogincr.use-graycode False
setp jogincr.suppress-no-input False
setp jogincr.in00 0.001000
setp jogincr.in01 0.001000
setp jogincr.in02 0.010000
setp jogincr.in03 0.001000
setp jogincr.in04 0.100000
setp jogincr.in05 0.010000
setp jogincr.in06 0.050000
setp jogincr.in07 0.100000
setp jogincr.in08 0.125000
setp jogincr.in09 0.125000
setp jogincr.in10 0.125000
setp jogincr.in11 0.125000
setp jogincr.in12 0.125000
setp jogincr.in13 0.125000
setp jogincr.in14 0.125000
setp jogincr.in15 0.125000
Last edit: 29 Mar 2018 02:01 by Nitram.
29 Mar 2018 02:26 #108058 by PCW
Replied by PCW on topic Axis Creep
I think what Todd was suggesting is that you monitor hm2_5i24.0.7i84.0.0.enc0.count
(say with halmeter) to see if its possibly creeping due to a noise issue of some kind
  • Nitram
  • Elite Member
  • Elite Member
29 Mar 2018 03:58 #108059 by Nitram
Thanks yes. I'll do that tomorrow and report back.
I had the machine running all day and after an initial jog is finished and the drift takes place over the following 3 minutes, after that time the Z axis has no further movement after checking over the course of the following hour.
Then jog again, 3 minutes of slow drift again (in the direction of the jog) then static again at that point onwards (again, checking periodically over the course of an hour).
It was this behavior (i.e. static after the initial creep) that made me lean towards a few residual mpg pulses (encoder filtering?).
As suggested I'll check with HAL meter and let you know.
Thanks again!
Marty.
30 Mar 2018 19:54 #108125 by andypugh
Replied by andypugh on topic Axis Creep
Are you using Limit3? That turned out to have some wierd bugs.
github.com/LinuxCNC/linuxcnc/issues/240
Time to create page: 0.139 seconds
