After googling a lot searching for schematics of similar BOBs, PNP NC sensors ecc i came up with this that
I THINK should be an approximation of what is going on:
What i understood is that this kind of BOB is just made to have inputs like E-STOPS, mechanic switches ecc, because it simply wants the inputs to be driven by connecting / disconnecting them to /from gnd.
I assumed the position of the led into the sensors: that should explain why the leds only dim: the current from vcc, once the switch gets opened (when the sensor has something near) , can flow to gnd passing through the leds.
Also this would mean that actually those sensors only work thanks to the path to ground that is created through those LEDS...
Does this make sense?
How can i fix this? It looks that i simply have a BOB that is not meant to be used with this kind of sensor..
