Parallel port testing
- jensor
- Thank you received: 4
28 Mar 2018 15:09 #108034
by jensor
Parallel port testing was created by jensor
My Y axis is failing. It was working perfectly.
I'm using quadrature drive with channel A and B signals. Hal configuration "Show" indicates that the steps being sent to the A and B channels are normal. However, checking with a volt meter I find that the A channel is not responding.
Does this imply that I need to replace the parallel port board? The board has 2 ports on it and I was using one port for X axis communication and the other for Y axis .
- Thank you received: 1470
28 Mar 2018 17:41 #108042
Replied by Todd Zuercher on topic Parallel port testing
Is it possible for you to switch the A-channel that failed to an unused pin on the parallel port?
That could get you going again, but won't answer the question "What caused the pin to fail in the first place?"
- jensor
29 Mar 2018 19:06 #108080
by jensor
Replied by jensor on topic Parallel port testing
Rebooting the computer straightened it out.
Time to create page: 0.080 seconds
