Can't get Smithy 622 out of e-stop with 2.7
02 May 2018 22:49 #110067
Replied by andypugh on topic Can't get Smithy 622 out of e-stop with 2.7
Now to work out how to not require the manual step. Have you got anywhere with that? It really should not be difficult.
- lustenaderj
04 May 2018 02:02 #110162
by lustenaderj
Replied by lustenaderj on topic Can't get Smithy 622 out of e-stop with 2.7
I haven't had much time with the mill since determining that would work where I didn't have to get something actually made, but hoping to spend some time in the next couple of weeks trying to nail down how to properly incorporate it. Having surgery next Tuesday, so I'll have a bit of downtime to play with it.
- lustenaderj
06 May 2018 16:50 #110279
by lustenaderj
Not sure on the why it works, but I got everything working as intended.
I moved the sets Enable true line to the end of the .hal file instead of directly beneath the newsig line. Entirely on a whim, but it does the trick.
Thanks for all the guidance.
09 May 2018 21:34 #110456
It sounds like somewhere else in the HAL file the signal was being set false.
Time to create page: 0.275 seconds
