Getting Spindle Speed into LinuxCNC
  • Michael80
  • Topic Author
  • Junior Member
  • Junior Member
8 years 3 months ago #114574 by Michael80
Getting Spindle Speed into LinuxCNC was created by Michael80
Hi There,
2 Years ago i worked on a plasma cutter and it is working well. But now i got a small lathe and would like to use LCNC also for it.
Does anyone have a description how to get the Rotation Speed of the lathe into LCNC? I need to build up complete, theres no encoder on the lathe, so i need to do something here also, what is best suitable for LCNC?
BR
Michael
8 years 3 months ago #114575 by cmorley
Replied by cmorley on topic Getting Spindle Speed into LinuxCNC
You don;t give us much to go on there but:
If you are using a VFD they usually can supply the speed.
or add a industrial encoder
or use a gear tooth and a couple magnetic sensors,
or a couple of light sensors and a disk with holes in it.
Do you just want RPM displayed or do you want to thread?
VFD feedback is not enough to thread with.
If you are going to the trouble to add sensors - might as well add enough to thread with.
Chris M
  • Michael80
  • Topic Author
  • Junior Member
  • Junior Member
8 years 3 months ago #114578 by Michael80
Replied by Michael80 on topic Getting Spindle Speed into LinuxCNC
Hi Chris,
ok, its a little bit less, but i also have not more :P
due to i have the lathe, i think i will use an light sensor and make a wheel with 2 or 4 holes inside. But what signal does the LCNC need?
I want to use the RPM for Thread and displaying
MIchael
8 years 3 months ago #114945 by andypugh
Replied by andypugh on topic Getting Spindle Speed into LinuxCNC
For threading I would suggest a disk with around 50 slots and in index slot.
More or less is fine, but with less accuracy degrades and with more the count-rate might exceed the interface speed (if using the parallel port, not a problem with other hardware).
To do rigid tapping you need to add a third sensor for the B-quadrature signal, but you can do single-point threading with only pulse and index.
Time to create page: 0.163 seconds
