Stepper turn issue DM556
  • Erikcnc
  • Erikcnc's Avatar Topic Author
  • Premium Member
  • Premium Member
06 Aug 2018 09:22 - 06 Aug 2018 12:07 #115664 by Erikcnc
Stepper turn issue DM556 was created by Erikcnc
Hi all,
So...after installing pokeys, i was planning to power up the mesa 7i76e for the first time.
Unfortunately i had latancy problems. They were to high and i was unable to communicate with the board.
After some help from Lcvette and Kcj, i tried a linuxcnc stretch and run it from usb. I did alot of afford to install the touchscreen and pokeys, and now i have to do it all over again.
So...I start up the new linuxcnc from usb....did some latancy test, came at 20k or so, tested, did not work, did 1000k. Workt!
At my surprise, even the touchscreen workt directly.....
I did some tuning to the motor, because they jiggle while jogging and keeps jiggling when stationary.
After changeing the P value from 0 to 1000 it was over.
The problem
Now it is not perfect to work with. After jogging or moving, the motor turns a slight back.
See link for video.
Stepper Turnback Linuxcnc
What could this be?
the pc i use is a HP compaq 8200 ulta-slim with a i5
Last edit: 06 Aug 2018 12:07 by Erikcnc.
06 Aug 2018 15:44 #115669 by PCW
Replied by PCW on topic Stepper turn issue DM556
This is a pncconf bug on metric unit configurations
Removing all the "setp pid.N.maxerror= .0005" statements from the hal file should fix it
  • Erikcnc
  • Premium Member
  • Premium Member
16 Aug 2018 07:07 #116108 by Erikcnc
Replied by Erikcnc on topic Stepper turn issue DM556
Thank you!
Time to create page: 0.078 seconds
