[ 315.313307] perf: interrupt took too long (2505 > 2500), lowering kernel.perf_event_max_sample_rate to 79750
[ 344.918329] perf: interrupt took too long (3141 > 3131), lowering kernel.perf_event_max_sample_rate to 63500
[ 393.773090] perf: interrupt took too long (3929 > 3926), lowering kernel.perf_event_max_sample_rate to 50750
[ 493.338243] perf: interrupt took too long (4923 > 4911), lowering kernel.perf_event_max_sample_rate to 40500
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.7.14
Machine configuration directory is '/home/cnc/linuxcnc/configs/тест_1_энкодер_на_оси_посмотреть_что_генерит'
Machine configuration file is 'тест_1_энкодер_на_оси_посмотреть_что_генерит.ini'
INIFILE=/home/cnc/linuxcnc/configs/тест_1_энкодер_на_оси_посмотреть_что_генерит/тест_1_энкодер_на_оси_посмотреть_что_генерит.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Found file(REL): ./тест_1_энкодер_на_оси_посмотреть_что_генерит.hal
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 192.168.1.121: Hardware address: 00:60:1b:13:03:fe
hm2_eth: discovered 7I92
hm2/hm2_7i92.0: Smart Serial Firmware Version 43
hm2/hm2_7i92.0: 34 I/O Pins used:
hm2/hm2_7i92.0: IO Pin 000 (P2-01): StepGen #0, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 001 (P2-14): StepGen #0, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 002 (P2-02): StepGen #1, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 003 (P2-15): StepGen #1, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 004 (P2-03): StepGen #2, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 005 (P2-16): StepGen #2, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 006 (P2-04): IOPort
hm2/hm2_7i92.0: IO Pin 007 (P2-17): IOPort
hm2/hm2_7i92.0: IO Pin 008 (P2-05): IOPort
hm2/hm2_7i92.0: IO Pin 009 (P2-06): IOPort
hm2/hm2_7i92.0: IO Pin 010 (P2-07): IOPort
hm2/hm2_7i92.0: IO Pin 011 (P2-08): IOPort
hm2/hm2_7i92.0: IO Pin 012 (P2-09): IOPort
hm2/hm2_7i92.0: IO Pin 013 (P2-10): IOPort
hm2/hm2_7i92.0: IO Pin 014 (P2-11): Encoder #0, pin Index (Input)
hm2/hm2_7i92.0: IO Pin 015 (P2-12): Encoder #0, pin B (Input)
hm2/hm2_7i92.0: IO Pin 016 (P2-13): Encoder #0, pin A (Input)
hm2/hm2_7i92.0: IO Pin 017 (P1-01): IOPort
hm2/hm2_7i92.0: IO Pin 018 (P1-14): IOPort
hm2/hm2_7i92.0: IO Pin 019 (P1-02): IOPort
hm2/hm2_7i92.0: IO Pin 020 (P1-15): IOPort
hm2/hm2_7i92.0: IO Pin 021 (P1-03): IOPort
hm2/hm2_7i92.0: IO Pin 022 (P1-16): IOPort
hm2/hm2_7i92.0: IO Pin 023 (P1-04): IOPort
hm2/hm2_7i92.0: IO Pin 024 (P1-17): IOPort
hm2/hm2_7i92.0: IO Pin 025 (P1-05): IOPort
hm2/hm2_7i92.0: IO Pin 026 (P1-06): IOPort
hm2/hm2_7i92.0: IO Pin 027 (P1-07): IOPort
hm2/hm2_7i92.0: IO Pin 028 (P1-08): IOPort
hm2/hm2_7i92.0: IO Pin 029 (P1-09): IOPort
hm2/hm2_7i92.0: IO Pin 030 (P1-10): IOPort
hm2/hm2_7i92.0: IO Pin 031 (P1-11): IOPort
hm2/hm2_7i92.0: IO Pin 032 (P1-12): IOPort
hm2/hm2_7i92.0: IO Pin 033 (P1-13): IOPort
hm2/hm2_7i92.0: registered
Running HAL shutdown script
Killing task linuxcncsvr, PID=1373
hm2_eth: HostMot2 ethernet driver unloaded
hm2: unloading
Debug file information:
Note: Using POSIX realtime
./тест_1_энкодер_на_оси_посмотреть_что_генерит.hal:128: Pin 'hm2_7i92.0.encoder.00.position-fb' does not exist
1373
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Linux version 4.9.0-5-rt-686-pae (debian-kernel@lists.debian.org) (gcc version 6.3.0 20170516 (Debian 6.3.0-18) ) #1 SMP PREEMPT RT Debian 4.9.65-3+deb9u2 (2018-01-04)
[ 0.000000] x86/fpu: Legacy x87 FPU detected.
[ 0.000000] x86/fpu: Using 'eager' FPU context switches.
[ 0.000000] e820: BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009dfff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009e000-0x000000000009ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000000e4000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000007fecffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000007fed0000-0x000000007fedefff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000007fedf000-0x000000007fffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec0ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed003ff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed14000-0x00000000fed19fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed8ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] SMBIOS 2.4 present.
[ 0.000000] DMI: Acer Aspire 9920/Aspire 9920, BIOS V1.20 01/07/08
[ 0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000000] e820: last_pfn = 0x7fed0 max_arch_pfn = 0x1000000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask F80000000 write-back
[ 0.000000] 1 base 07FF00000 mask FFFF00000 uncachable
[ 0.000000] 2 disabled
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WC UC- WT
[ 0.000000] found SMP MP-table at [mem 0x000f70c0-0x000f70cf] mapped at [c00f70c0]
[ 0.000000] initial memory mapped: [mem 0x00000000-0x10ffffff]
[ 0.000000] Base memory trampoline at [c009a000] 9a000 size 16384
[ 0.000000] BRK [0x10a59000, 0x10a59fff] PGTABLE
[ 0.000000] BRK [0x10a5a000, 0x10a5bfff] PGTABLE
[ 0.000000] BRK [0x10a5c000, 0x10a5cfff] PGTABLE
[ 0.000000] BRK [0x10a5d000, 0x10a5dfff] PGTABLE
[ 0.000000] RAMDISK: [mem 0x353e3000-0x369e8fff]
[ 0.000000] ACPI: Early table checksum verification disabled
[ 0.000000] ACPI: RSDP 0x00000000000F7020 000024 (v02 ACRSYS)
[ 0.000000] ACPI: XSDT 0x000000007FED258F 00008C (v01 ACRSYS ACRPRDCT 06040000 LTP 00000000)
[ 0.000000] ACPI: FACP 0x000000007FEDBBD2 0000F4 (v03 INTEL CRESTLNE 06040000 ALAN 00000001)
[ 0.000000] ACPI: DSDT 0x000000007FED3AB3 0080AB (v02 INTEL CRESTLNE 06040000 INTL 20050624)
[ 0.000000] ACPI: FACS 0x000000007FEDEFC0 000040
[ 0.000000] ACPI: APIC 0x000000007FEDBCC6 000068 (v01 INTEL CRESTLNE 06040000 LOHR 0000005A)
[ 0.000000] ACPI: HPET 0x000000007FEDBD2E 000038 (v01 INTEL CRESTLNE 06040000 LOHR 0000005A)
[ 0.000000] ACPI: MCFG 0x000000007FEDBD66 00003C (v01 INTEL CRESTLNE 06040000 LOHR 0000005A)
[ 0.000000] ACPI: TCPA 0x000000007FEDBDA2 000032 (v01 Intel CRESTLN 06040000 00005A52)
[ 0.000000] ACPI: TMOR 0x000000007FEDBDD4 000026 (v01 PTLTD 06040000 PTL 00000003)
[ 0.000000] ACPI: APIC 0x000000007FEDBDFA 000068 (v01 PTLTD ? APIC 06040000 LTP 00000000)
[ 0.000000] ACPI: SLIC 0x000000007FEDBE62 000176 (v01 ACRSYS ACRPRDCT 06040000 LTP 00000000)
[ 0.000000] ACPI: BOOT 0x000000007FEDBFD8 000028 (v01 PTLTD $SBFTBL$ 06040000 LTP 00000001)
[ 0.000000] ACPI: SSDT 0x000000007FED37BE 0002F5 (v01 SataRe SataAhci 00001000 INTL 20050624)
[ 0.000000] ACPI: SSDT 0x000000007FED2BA7 00025F (v01 PmRef Cpu0Tst 00003000 INTL 20050624)
[ 0.000000] ACPI: SSDT 0x000000007FED2B01 0000A6 (v01 PmRef Cpu1Tst 00003000 INTL 20050624)
[ 0.000000] ACPI: SSDT 0x000000007FED261B 0004E6 (v01 PmRef CpuPm 00003000 INTL 20050624)
[ 0.000000] ACPI: BIOS bug: multiple APIC/MADT found, using 0
[ 0.000000] ACPI: If "acpi_apic_instance=2" works better, notify linux-acpi@vger.kernel.org
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 1156MB HIGHMEM available.
[ 0.000000] 889MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 379fe000
[ 0.000000] low ram: 0 - 379fe000
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.000000] Normal [mem 0x0000000001000000-0x00000000379fdfff]
[ 0.000000] HighMem [mem 0x00000000379fe000-0x000000007fecffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000001000-0x000000000009dfff]
[ 0.000000] node 0: [mem 0x0000000000100000-0x000000007fecffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x000000007fecffff]
[ 0.000000] On node 0 totalpages: 523885
[ 0.000000] free_area_init_node: node 0, pgdat d081b580, node_mem_map f3fe3028
[ 0.000000] DMA zone: 40 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3997 pages, LIFO batch:0
[ 0.000000] Normal zone: 2185 pages used for memmap
[ 0.000000] Normal zone: 223742 pages, LIFO batch:31
[ 0.000000] HighMem zone: 296146 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x1008
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.000000] IOAPIC[0]: apic_id 1, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.000000] smpboot: Allowing 2 CPUs, 0 hotplug CPUs
[ 0.000000] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.000000] PM: Registered nosave memory: [mem 0x0009e000-0x0009ffff]
[ 0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000e3fff]
[ 0.000000] PM: Registered nosave memory: [mem 0x000e4000-0x000fffff]
[ 0.000000] e820: [mem 0x80000000-0xdfffffff] available for PCI devices
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[ 0.000000] setup_percpu: NR_CPUS:32 nr_cpumask_bits:32 nr_cpu_ids:2 nr_node_ids:1
[ 0.000000] percpu: Embedded 101 pages/cpu @f7931000 s381408 r0 d32288 u413696
[ 0.000000] pcpu-alloc: s381408 r0 d32288 u413696 alloc=101*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 521660
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.9.0-5-rt-686-pae root=/dev/sda1 ro quiet
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] microcode: microcode updated early to revision 0xba, date = 2010-10-03
[ 0.000000] Initializing CPU#0
[ 0.000000] Initializing HighMem for node 0 (000379fe:0007fed0)
[ 0.000000] Initializing Movable for node 0 (00000000:00000000)
[ 0.000000] Memory: 2039700K/2095540K available (5978K kernel code, 632K rwdata, 1752K rodata, 1052K init, 592K bss, 55840K reserved, 0K cma-reserved, 1184584K highmem)
[ 0.000000] virtual kernel memory layout:
fixmap : 0xffd36000 - 0xfffff000 (2852 kB)
pkmap : 0xffa00000 - 0xffc00000 (2048 kB)
vmalloc : 0xf81fe000 - 0xff9fe000 ( 120 MB)
lowmem : 0xc0000000 - 0xf79fe000 ( 889 MB)
.init : 0xd082f000 - 0xd0936000 (1052 kB)
.data : 0xd05d6e64 - 0xd082d0c0 (2392 kB)
.text : 0xd0000000 - 0xd05d6e64 (5979 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=32 to nr_cpu_ids=2.
[ 0.000000] RCU kthread priority: 1.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS:2304 nr_irqs:440 16
[ 0.000000] CPU 0 irqstacks, hard=f703e000 soft=f7080000
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[ 0.000000] hpet clockevent registered
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] tsc: Detected 2194.606 MHz processor
[ 0.004004] Calibrating delay loop (skipped), value calculated using timer frequency.. 4389.21 BogoMIPS (lpj=8778424)
[ 0.004005] pid_max: default: 32768 minimum: 301
[ 0.004022] ACPI: Core revision 20160831
[ 0.013083] ACPI: 5 ACPI AML tables successfully acquired and loaded
[ 0.013109] Security Framework initialized
[ 0.013110] Yama: disabled by default; enable with sysctl kernel.yama.*
[ 0.013118] AppArmor: AppArmor disabled by boot time parameter
[ 0.013130] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.013132] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.013455] CPU: Physical Processor ID: 0
[ 0.013455] CPU: Processor Core ID: 0
[ 0.013461] mce: CPU supports 6 MCE banks
[ 0.013471] process: using mwait in idle threads
[ 0.013478] Last level iTLB entries: 4KB 128, 2MB 4, 4MB 4
[ 0.013479] Last level dTLB entries: 4KB 256, 2MB 0, 4MB 32, 1GB 0
[ 0.013697] Freeing SMP alternatives memory: 24K
[ 0.015913] ftrace: allocating 24005 entries in 47 pages
[ 0.024102] smpboot: Max logical packages: 1
[ 0.024108] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.024501] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.068000] smpboot: CPU0: Intel(R) Core(TM)2 Duo CPU T7500 @ 2.20GHz (family: 0x6, model: 0xf, stepping: 0xb)
[ 0.068000] Performance Events: PEBS fmt0+, Core2 events, Intel PMU driver.
[ 0.068000] core: PEBS disabled due to CPU errata
[ 0.068000] ... version: 2
[ 0.068000] ... bit width: 40
[ 0.068000] ... generic registers: 2
[ 0.068000] ... value mask: 000000ffffffffff
[ 0.068000] ... max period: 000000007fffffff
[ 0.068000] ... fixed-purpose events: 3
[ 0.068000] ... event mask: 0000000700000003
[ 0.120088] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[ 0.172025] CPU 1 irqstacks, hard=f7196000 soft=f7198000
[ 0.172026] x86: Booting SMP configuration:
[ 0.172028] .... node #0, CPUs: #1
[ 0.008000] Initializing CPU#1
[ 0.180086] x86: Booted up 1 node, 2 CPUs
[ 0.180086] smpboot: Total of 2 processors activated (8778.42 BogoMIPS)
[ 0.182093] devtmpfs: initialized
[ 0.182093] PM: Registering ACPI NVS region [mem 0x7fed0000-0x7fedefff] (61440 bytes)
[ 0.182093] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.182093] futex hash table entries: 512 (order: 3, 32768 bytes)
[ 0.182093] pinctrl core: initialized pinctrl subsystem
[ 0.182093] NET: Registered protocol family 16
[ 0.188017] cpuidle: using governor ladder
[ 0.192012] cpuidle: using governor menu
[ 0.192046] Simple Boot Flag at 0x36 set to 0x1
[ 0.192059] ACPI: bus type PCI registered
[ 0.192061] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.192142] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.192144] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[ 0.192145] PCI: Using MMCONFIG for extended config space
[ 0.192146] PCI: Using configuration type 1 for base access
[ 0.192252] mtrr: your CPUs had inconsistent variable MTRR settings
[ 0.192253] mtrr: probably your BIOS does not setup all CPUs.
[ 0.192254] mtrr: corrected configuration.
[ 0.192617] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.192617] ACPI: Added _OSI(Module Device)
[ 0.192617] ACPI: Added _OSI(Processor Device)
[ 0.192617] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.192617] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.220012] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 0.241791] ACPI: Dynamic OEM Table Load:
[ 0.241800] ACPI: SSDT 0x00000000F7207C00 00027A (v01 PmRef Cpu0Ist 00003000 INTL 20050624)
[ 0.242056] ACPI: Dynamic OEM Table Load:
[ 0.242063] ACPI: SSDT 0x00000000F71F3000 0005F1 (v01 PmRef Cpu0Cst 00003001 INTL 20050624)
[ 0.242390] ACPI: Dynamic OEM Table Load:
[ 0.242396] ACPI: SSDT 0x00000000F71C3E00 0000C8 (v01 PmRef Cpu1Ist 00003000 INTL 20050624)
[ 0.242571] ACPI: Dynamic OEM Table Load:
[ 0.242577] ACPI: SSDT 0x00000000F71BC240 000085 (v01 PmRef Cpu1Cst 00003000 INTL 20050624)
[ 0.243134] ACPI : EC: EC started
[ 0.243136] ACPI : EC: interrupt blocked
[ 0.243235] ACPI: \_SB_.PCI0.LPCB.EC0_: Used as first EC
[ 0.243238] ACPI: \_SB_.PCI0.LPCB.EC0_: GPE=0x16, EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.243240] ACPI: \_SB_.PCI0.LPCB.EC0_: Used as boot DSDT EC to handle transactions
[ 0.243241] ACPI: Interpreter enabled
[ 0.243266] ACPI: (supports S0 S3 S4 S5)
[ 0.243268] ACPI: Using IOAPIC for interrupt routing
[ 0.243298] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.245203] acpi SADDLEST:00: ACPI dock station (docks/bays count: 1)
[ 0.252167] ACPI: Power Resource [FN00] (off)
[ 0.253110] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.253116] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[ 0.253121] acpi PNP0A08:00: _OSC failed (AE_NOT_FOUND); disabling ASPM
[ 0.253781] PCI host bridge to bus 0000:00
[ 0.253784] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.253786] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.253788] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.253790] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff window]
[ 0.253792] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff window]
[ 0.253794] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff window]
[ 0.253796] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
[ 0.253797] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff window]
[ 0.253799] pci_bus 0000:00: root bus resource [mem 0x80000000-0xdfffffff window]
[ 0.253801] pci_bus 0000:00: root bus resource [mem 0xf0000000-0xfebfffff window]
[ 0.253803] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.253814] pci 0000:00:00.0: [8086:2a00] type 00 class 0x060000
[ 0.253982] pci 0000:00:01.0: [8086:2a01] type 01 class 0x060400
[ 0.254037] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.254203] pci 0000:00:1a.0: [8086:2834] type 00 class 0x0c0300
[ 0.254261] pci 0000:00:1a.0: reg 0x20: [io 0x1800-0x181f]
[ 0.254385] pci 0000:00:1a.0: System wakeup disabled by ACPI
[ 0.254451] pci 0000:00:1a.1: [8086:2835] type 00 class 0x0c0300
[ 0.254508] pci 0000:00:1a.1: reg 0x20: [io 0x1820-0x183f]
[ 0.254632] pci 0000:00:1a.1: System wakeup disabled by ACPI
[ 0.254710] pci 0000:00:1a.7: [8086:283a] type 00 class 0x0c0320
[ 0.254731] pci 0000:00:1a.7: reg 0x10: [mem 0xfc304800-0xfc304bff]
[ 0.254835] pci 0000:00:1a.7: PME# supported from D0 D3hot D3cold
[ 0.254978] pci 0000:00:1b.0: [8086:284b] type 00 class 0x040300
[ 0.255003] pci 0000:00:1b.0: reg 0x10: [mem 0xfc300000-0xfc303fff 64bit]
[ 0.255108] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.255191] pci 0000:00:1b.0: System wakeup disabled by ACPI
[ 0.255258] pci 0000:00:1c.0: [8086:283f] type 01 class 0x060400
[ 0.255365] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.255514] pci 0000:00:1c.1: [8086:2841] type 01 class 0x060400
[ 0.255624] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[ 0.255772] pci 0000:00:1c.2: [8086:2843] type 01 class 0x060400
[ 0.255878] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[ 0.256037] pci 0000:00:1c.3: [8086:2845] type 01 class 0x060400
[ 0.256144] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[ 0.256294] pci 0000:00:1d.0: [8086:2830] type 00 class 0x0c0300
[ 0.256352] pci 0000:00:1d.0: reg 0x20: [io 0x1840-0x185f]
[ 0.256476] pci 0000:00:1d.0: System wakeup disabled by ACPI
[ 0.256537] pci 0000:00:1d.1: [8086:2831] type 00 class 0x0c0300
[ 0.256596] pci 0000:00:1d.1: reg 0x20: [io 0x1860-0x187f]
[ 0.256717] pci 0000:00:1d.1: System wakeup disabled by ACPI
[ 0.256783] pci 0000:00:1d.2: [8086:2832] type 00 class 0x0c0300
[ 0.256840] pci 0000:00:1d.2: reg 0x20: [io 0x1880-0x189f]
[ 0.257007] pci 0000:00:1d.7: [8086:2836] type 00 class 0x0c0320
[ 0.257029] pci 0000:00:1d.7: reg 0x10: [mem 0xfc304c00-0xfc304fff]
[ 0.257133] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.257208] pci 0000:00:1d.7: System wakeup disabled by ACPI
[ 0.257277] pci 0000:00:1e.0: [8086:2448] type 01 class 0x060401
[ 0.257459] pci 0000:00:1f.0: [8086:2815] type 00 class 0x060100
[ 0.257550] pci 0000:00:1f.0: quirk: [io 0x1000-0x107f] claimed by ICH6 ACPI/GPIO/TCO
[ 0.257556] pci 0000:00:1f.0: quirk: [io 0x1180-0x11bf] claimed by ICH6 GPIO
[ 0.257559] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 1 PIO at 0400 (mask 0003)
[ 0.257563] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 2 PIO at 1640 (mask 007f)
[ 0.257717] pci 0000:00:1f.1: [8086:2850] type 00 class 0x01018a
[ 0.257734] pci 0000:00:1f.1: reg 0x10: [io 0x0000-0x0007]
[ 0.257746] pci 0000:00:1f.1: reg 0x14: [io 0x0000-0x0003]
[ 0.257758] pci 0000:00:1f.1: reg 0x18: [io 0x0000-0x0007]
[ 0.257769] pci 0000:00:1f.1: reg 0x1c: [io 0x0000-0x0003]
[ 0.257781] pci 0000:00:1f.1: reg 0x20: [io 0x18a0-0x18af]
[ 0.257806] pci 0000:00:1f.1: legacy IDE quirk: reg 0x10: [io 0x01f0-0x01f7]
[ 0.257808] pci 0000:00:1f.1: legacy IDE quirk: reg 0x14: [io 0x03f6]
[ 0.257810] pci 0000:00:1f.1: legacy IDE quirk: reg 0x18: [io 0x0170-0x0177]
[ 0.257811] pci 0000:00:1f.1: legacy IDE quirk: reg 0x1c: [io 0x0376]
[ 0.257943] pci 0000:00:1f.2: [8086:2829] type 00 class 0x010601
[ 0.257964] pci 0000:00:1f.2: reg 0x10: [io 0x18d8-0x18df]
[ 0.257974] pci 0000:00:1f.2: reg 0x14: [io 0x18cc-0x18cf]
[ 0.257985] pci 0000:00:1f.2: reg 0x18: [io 0x18d0-0x18d7]
[ 0.257996] pci 0000:00:1f.2: reg 0x1c: [io 0x18c8-0x18cb]
[ 0.258007] pci 0000:00:1f.2: reg 0x20: [io 0x18e0-0x18ff]
[ 0.258018] pci 0000:00:1f.2: reg 0x24: [mem 0xfc304000-0xfc3047ff]
[ 0.258074] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.258209] pci 0000:00:1f.3: [8086:283e] type 00 class 0x0c0500
[ 0.258226] pci 0000:00:1f.3: reg 0x10: [mem 0x00000000-0x000000ff]
[ 0.258265] pci 0000:00:1f.3: reg 0x20: [io 0x1c00-0x1c1f]
[ 0.258487] pci 0000:01:00.0: [10de:0407] type 00 class 0x030000
[ 0.258501] pci 0000:01:00.0: reg 0x10: [mem 0xca000000-0xcaffffff]
[ 0.258514] pci 0000:01:00.0: reg 0x14: [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.258526] pci 0000:01:00.0: reg 0x1c: [mem 0xc8000000-0xc9ffffff 64bit]
[ 0.258535] pci 0000:01:00.0: reg 0x24: [io 0x2000-0x207f]
[ 0.258543] pci 0000:01:00.0: reg 0x30: [mem 0x00000000-0x0001ffff pref]
[ 0.268010] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.268014] pci 0000:00:01.0: bridge window [io 0x2000-0x2fff]
[ 0.268017] pci 0000:00:01.0: bridge window [mem 0xc8000000-0xcaffffff]
[ 0.268022] pci 0000:00:01.0: bridge window [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.268206] pci 0000:02:00.0: [14e4:1693] type 00 class 0x020000
[ 0.268278] pci 0000:02:00.0: reg 0x10: [mem 0xfa000000-0xfa00ffff 64bit]
[ 0.268691] pci 0000:02:00.0: PME# supported from D3hot D3cold
[ 0.268840] pci 0000:02:00.0: System wakeup disabled by ACPI
[ 0.269018] pci 0000:00:1c.0: PCI bridge to [bus 02-03]
[ 0.269025] pci 0000:00:1c.0: bridge window [mem 0xfa000000-0xfbffffff]
[ 0.269033] pci 0000:00:1c.0: bridge window [mem 0xf4000000-0xf5ffffff 64bit pref]
[ 0.269132] acpiphp: Slot [1] registered
[ 0.269139] pci 0000:00:1c.1: PCI bridge to [bus 04-05]
[ 0.269146] pci 0000:00:1c.1: bridge window [mem 0xf6000000-0xf7ffffff]
[ 0.269154] pci 0000:00:1c.1: bridge window [mem 0xf0000000-0xf1ffffff 64bit pref]
[ 0.269242] pci 0000:00:1c.2: PCI bridge to [bus 06-07]
[ 0.269250] pci 0000:00:1c.2: bridge window [mem 0xf8000000-0xf9ffffff]
[ 0.269257] pci 0000:00:1c.2: bridge window [mem 0xf2000000-0xf3ffffff 64bit pref]
[ 0.269408] pci 0000:08:00.0: [8086:4229] type 00 class 0x028000
[ 0.269460] pci 0000:08:00.0: reg 0x10: [mem 0xc4000000-0xc4001fff 64bit]
[ 0.269698] pci 0000:08:00.0: PME# supported from D0 D3hot D3cold
[ 0.269778] pci 0000:08:00.0: System wakeup disabled by ACPI
[ 0.280042] pci 0000:00:1c.3: PCI bridge to [bus 08-09]
[ 0.280050] pci 0000:00:1c.3: bridge window [mem 0xc4000000-0xc5ffffff]
[ 0.280057] pci 0000:00:1c.3: bridge window [mem 0xcc000000-0xcdffffff 64bit pref]
[ 0.280178] pci 0000:0a:06.0: [104c:8039] type 02 class 0x060700
[ 0.280196] pci 0000:0a:06.0: reg 0x10: [mem 0xfc004000-0xfc004fff]
[ 0.280234] pci 0000:0a:06.0: supports D1 D2
[ 0.280236] pci 0000:0a:06.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.280326] pci 0000:0a:06.1: [104c:803a] type 00 class 0x0c0010
[ 0.280346] pci 0000:0a:06.1: reg 0x10: [mem 0xfc006000-0xfc0067ff]
[ 0.280357] pci 0000:0a:06.1: reg 0x14: [mem 0xfc000000-0xfc003fff]
[ 0.280445] pci 0000:0a:06.1: supports D1 D2
[ 0.280447] pci 0000:0a:06.1: PME# supported from D0 D1 D2 D3hot
[ 0.280535] pci 0000:0a:06.2: [104c:803b] type 00 class 0x018000
[ 0.280552] pci 0000:0a:06.2: reg 0x10: [mem 0xfc005000-0xfc005fff]
[ 0.280632] pci 0000:0a:06.2: supports D1 D2
[ 0.280634] pci 0000:0a:06.2: PME# supported from D0 D1 D2 D3hot
[ 0.280718] pci 0000:0a:06.3: [104c:803c] type 00 class 0x080501
[ 0.280735] pci 0000:0a:06.3: reg 0x10: [mem 0xfc006800-0xfc0068ff]
[ 0.280735] pci 0000:0a:06.3: supports D1 D2
[ 0.280735] pci 0000:0a:06.3: PME# supported from D0 D1 D2 D3hot
[ 0.280735] pci 0000:00:1e.0: PCI bridge to [bus 0a-0b] (subtractive decode)
[ 0.280735] pci 0000:00:1e.0: bridge window [mem 0xfc000000-0xfc0fffff]
[ 0.280735] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7 window] (subtractive decode)
[ 0.280735] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff window] (subtractive decode)
[ 0.280735] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode)
[ 0.280735] pci 0000:00:1e.0: bridge window [mem 0x000d0000-0x000d3fff window] (subtractive decode)
[ 0.280735] pci 0000:00:1e.0: bridge window [mem 0x000d4000-0x000d7fff window] (subtractive decode)
[ 0.280735] pci 0000:00:1e.0: bridge window [mem 0x000d8000-0x000dbfff window] (subtractive decode)
[ 0.280735] pci 0000:00:1e.0: bridge window [mem 0x000dc000-0x000dffff window] (subtractive decode)
[ 0.280735] pci 0000:00:1e.0: bridge window [mem 0x000e0000-0x000e3fff window] (subtractive decode)
[ 0.280735] pci 0000:00:1e.0: bridge window [mem 0x80000000-0xdfffffff window] (subtractive decode)
[ 0.280735] pci 0000:00:1e.0: bridge window [mem 0xf0000000-0xfebfffff window] (subtractive decode)
[ 0.280735] pci_bus 0000:0b: busn_res: can not insert [bus 0b-ff] under [bus 0a-0b] (conflicts with (null) [bus 0a-0b])
[ 0.280735] pci_bus 0000:0b: busn_res: [bus 0b-ff] end is updated to 0e
[ 0.280735] pci_bus 0000:0b: busn_res: can not insert [bus 0b-0e] under [bus 0a-0b] (conflicts with (null) [bus 0a-0b])
[ 0.280735] pci_bus 0000:0b: [bus 0b-0e] partially hidden behind transparent bridge 0000:0a [bus 0a-0b]
[ 0.280735] pci 0000:00:1e.0: bridge has subordinate 0b but max busn 0e
[ 0.280735] pci_bus 0000:00: on NUMA node 0
[ 0.280735] ACPI: PCI Interrupt Link [LNKA] (IRQs 1 3 4 *5 6 7 10 12 14 15)
[ 0.280735] ACPI: PCI Interrupt Link [LNKB] (IRQs 1 3 4 5 6 7 11 12 14 15) *10
[ 0.280735] ACPI: PCI Interrupt Link [LNKC] (IRQs 1 3 4 5 6 7 10 12 14 15) *11
[ 0.280751] ACPI: PCI Interrupt Link [LNKD] (IRQs 1 3 4 5 6 7 11 12 14 15) *10
[ 0.280825] ACPI: PCI Interrupt Link [LNKE] (IRQs 1 3 4 5 6 7 10 12 14 15) *0, disabled.
[ 0.280900] ACPI: PCI Interrupt Link [LNKF] (IRQs 1 3 4 5 6 7 *11 12 14 15)
[ 0.280973] ACPI: PCI Interrupt Link [LNKG] (IRQs 1 3 4 5 6 7 10 12 14 15) *11
[ 0.281047] ACPI: PCI Interrupt Link [LNKH] (IRQs 1 3 4 5 6 7 11 12 14 15) *10
[ 0.282065] ACPI: Enabled 3 GPEs in block 00 to 1F
[ 0.282132] ACPI : EC: interrupt unblocked
[ 0.282140] ACPI : EC: event unblocked
[ 0.282148] ACPI: \_SB_.PCI0.LPCB.EC0_: GPE=0x16, EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.282151] ACPI: \_SB_.PCI0.LPCB.EC0_: Used as boot DSDT EC to handle transactions and events
[ 0.282279] vgaarb: setting as boot device: PCI:0000:01:00.0
[ 0.282279] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.282279] vgaarb: loaded
[ 0.282279] vgaarb: bridge control possible 0000:01:00.0
[ 0.282279] PCI: Using ACPI for IRQ routing
[ 0.292369] PCI: pci_cache_line_size set to 64 bytes
[ 0.292547] e820: reserve RAM buffer [mem 0x0009e000-0x0009ffff]
[ 0.292549] e820: reserve RAM buffer [mem 0x7fed0000-0x7fffffff]
[ 0.292720] HPET: 3 timers in total, 0 timers will be used for per-cpu timer
[ 0.292720] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.292720] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
[ 0.294128] clocksource: Switched to clocksource hpet
[ 0.307817] VFS: Disk quotas dquot_6.6.0
[ 0.307840] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.307967] pnp: PnP ACPI init
[ 0.308259] system 00:00: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.308262] system 00:00: [mem 0xfed14000-0xfed17fff] has been reserved
[ 0.308265] system 00:00: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.308271] system 00:00: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.308273] system 00:00: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.308276] system 00:00: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.308278] system 00:00: [mem 0xfed40000-0xfed44fff] has been reserved
[ 0.308280] system 00:00: [mem 0xfed45000-0xfed8ffff] has been reserved
[ 0.308286] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.308726] system 00:01: [mem 0xfed00000-0xfed003ff] has been reserved
[ 0.308730] system 00:01: Plug and Play ACPI device, IDs PNP0103 PNP0c01 (active)
[ 0.308830] system 00:02: [io 0x0400-0x0401] has been reserved
[ 0.308833] system 00:02: [io 0x01f8-0x0273] has been reserved
[ 0.308835] system 00:02: [io 0x0680-0x069f] has been reserved
[ 0.308838] system 00:02: [io 0x0800-0x080f] has been reserved
[ 0.308840] system 00:02: [io 0x1000-0x107f] has been reserved
[ 0.308843] system 00:02: [io 0x1180-0x11bf] has been reserved
[ 0.308845] system 00:02: [io 0x1640-0x164f] has been reserved
[ 0.308847] system 00:02: [io 0xfe00] has been reserved
[ 0.308851] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.308897] pnp 00:03: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.309287] pnp 00:04: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.309530] pnp 00:05: Plug and Play ACPI device, IDs PNP0401 (disabled)
[ 0.309621] pnp 00:06: Plug and Play ACPI device, IDs ITE8709 (active)
[ 0.309680] pnp 00:07: Plug and Play ACPI device, IDs PNP0303 (active)
[ 0.309726] pnp 00:08: Plug and Play ACPI device, IDs SYN1904 SYN1900 SYN0002 PNP0f13 (active)
[ 0.309813] pnp: PnP ACPI: found 9 devices
[ 0.309816] PnPBIOS: Disabled
[ 0.347675] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.347699] pci 0000:00:1c.0: bridge window [io 0x1000-0x0fff] to [bus 02-03] add_size 1000
[ 0.347710] pci 0000:00:1c.1: bridge window [io 0x1000-0x0fff] to [bus 04-05] add_size 1000
[ 0.347720] pci 0000:00:1c.2: bridge window [io 0x1000-0x0fff] to [bus 06-07] add_size 1000
[ 0.347731] pci 0000:00:1c.3: bridge window [io 0x1000-0x0fff] to [bus 08-09] add_size 1000
[ 0.347748] pci 0000:0a:06.0: res[13]=[io 0x0100-0x00ff] res_to_dev_res add_size 100 min_align 100
[ 0.347751] pci 0000:0a:06.0: res[14]=[io 0x0100-0x00ff] res_to_dev_res add_size 100 min_align 100
[ 0.347753] pci 0000:00:1e.0: bridge window [io 0x1000-0x0fff] to [bus 0a-0b] add_size 1000
[ 0.347761] pci 0000:00:1c.0: res[13]=[io 0x1000-0x0fff] res_to_dev_res add_size 1000 min_align 1000
[ 0.347763] pci 0000:00:1c.0: res[13]=[io 0x1000-0x1fff] res_to_dev_res add_size 1000 min_align 1000
[ 0.347766] pci 0000:00:1c.1: res[13]=[io 0x1000-0x0fff] res_to_dev_res add_size 1000 min_align 1000
[ 0.347768] pci 0000:00:1c.1: res[13]=[io 0x1000-0x1fff] res_to_dev_res add_size 1000 min_align 1000
[ 0.347770] pci 0000:00:1c.2: res[13]=[io 0x1000-0x0fff] res_to_dev_res add_size 1000 min_align 1000
[ 0.347772] pci 0000:00:1c.2: res[13]=[io 0x1000-0x1fff] res_to_dev_res add_size 1000 min_align 1000
[ 0.347774] pci 0000:00:1c.3: res[13]=[io 0x1000-0x0fff] res_to_dev_res add_size 1000 min_align 1000
[ 0.347776] pci 0000:00:1c.3: res[13]=[io 0x1000-0x1fff] res_to_dev_res add_size 1000 min_align 1000
[ 0.347778] pci 0000:00:1e.0: res[13]=[io 0x1000-0x0fff] res_to_dev_res add_size 1000 min_align 1000
[ 0.347780] pci 0000:00:1e.0: res[13]=[io 0x1000-0x1fff] res_to_dev_res add_size 1000 min_align 1000
[ 0.347787] pci 0000:00:1c.0: BAR 13: assigned [io 0x3000-0x3fff]
[ 0.347791] pci 0000:00:1c.1: BAR 13: assigned [io 0x4000-0x4fff]
[ 0.347795] pci 0000:00:1c.2: BAR 13: assigned [io 0x5000-0x5fff]
[ 0.347798] pci 0000:00:1c.3: BAR 13: assigned [io 0x6000-0x6fff]
[ 0.347802] pci 0000:00:1e.0: BAR 13: assigned [io 0x7000-0x7fff]
[ 0.347808] pci 0000:00:1f.3: BAR 0: assigned [mem 0x80000000-0x800000ff]
[ 0.347816] pci 0000:01:00.0: BAR 6: no space for [mem size 0x00020000 pref]
[ 0.347818] pci 0000:01:00.0: BAR 6: failed to assign [mem size 0x00020000 pref]
[ 0.347820] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.347823] pci 0000:00:01.0: bridge window [io 0x2000-0x2fff]
[ 0.347827] pci 0000:00:01.0: bridge window [mem 0xc8000000-0xcaffffff]
[ 0.347830] pci 0000:00:01.0: bridge window [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.347835] pci 0000:00:1c.0: PCI bridge to [bus 02-03]
[ 0.347838] pci 0000:00:1c.0: bridge window [io 0x3000-0x3fff]
[ 0.347844] pci 0000:00:1c.0: bridge window [mem 0xfa000000-0xfbffffff]
[ 0.347848] pci 0000:00:1c.0: bridge window [mem 0xf4000000-0xf5ffffff 64bit pref]
[ 0.347855] pci 0000:00:1c.1: PCI bridge to [bus 04-05]
[ 0.347858] pci 0000:00:1c.1: bridge window [io 0x4000-0x4fff]
[ 0.347863] pci 0000:00:1c.1: bridge window [mem 0xf6000000-0xf7ffffff]
[ 0.347868] pci 0000:00:1c.1: bridge window [mem 0xf0000000-0xf1ffffff 64bit pref]
[ 0.347875] pci 0000:00:1c.2: PCI bridge to [bus 06-07]
[ 0.347878] pci 0000:00:1c.2: bridge window [io 0x5000-0x5fff]
[ 0.347883] pci 0000:00:1c.2: bridge window [mem 0xf8000000-0xf9ffffff]
[ 0.347888] pci 0000:00:1c.2: bridge window [mem 0xf2000000-0xf3ffffff 64bit pref]
[ 0.347895] pci 0000:00:1c.3: PCI bridge to [bus 08-09]
[ 0.347897] pci 0000:00:1c.3: bridge window [io 0x6000-0x6fff]
[ 0.347903] pci 0000:00:1c.3: bridge window [mem 0xc4000000-0xc5ffffff]
[ 0.347908] pci 0000:00:1c.3: bridge window [mem 0xcc000000-0xcdffffff 64bit pref]
[ 0.347917] pci 0000:0a:06.0: res[15]=[mem 0x04000000-0x03ffffff pref] res_to_dev_res add_size 4000000 min_align 4000000
[ 0.347920] pci 0000:0a:06.0: res[15]=[mem 0x04000000-0x07ffffff pref] res_to_dev_res add_size 4000000 min_align 4000000
[ 0.347922] pci 0000:0a:06.0: res[16]=[mem 0x04000000-0x03ffffff] res_to_dev_res add_size 4000000 min_align 4000000
[ 0.347924] pci 0000:0a:06.0: res[16]=[mem 0x04000000-0x07ffffff] res_to_dev_res add_size 4000000 min_align 4000000
[ 0.347926] pci 0000:0a:06.0: res[13]=[io 0x0100-0x00ff] res_to_dev_res add_size 100 min_align 100
[ 0.347928] pci 0000:0a:06.0: res[13]=[io 0x0100-0x01ff] res_to_dev_res add_size 100 min_align 100
[ 0.347930] pci 0000:0a:06.0: res[14]=[io 0x0100-0x00ff] res_to_dev_res add_size 100 min_align 100
[ 0.347932] pci 0000:0a:06.0: res[14]=[io 0x0100-0x01ff] res_to_dev_res add_size 100 min_align 100
[ 0.347939] pci 0000:0a:06.0: BAR 15: assigned [mem 0x84000000-0x87ffffff pref]
[ 0.347945] pci 0000:0a:06.0: BAR 16: assigned [mem 0x88000000-0x8bffffff]
[ 0.347947] pci 0000:0a:06.0: BAR 13: assigned [io 0x7000-0x70ff]
[ 0.347949] pci 0000:0a:06.0: BAR 14: assigned [io 0x7400-0x74ff]
[ 0.347952] pci 0000:0a:06.0: CardBus bridge to [bus 0b-0e]
[ 0.347954] pci 0000:0a:06.0: bridge window [io 0x7000-0x70ff]
[ 0.347958] pci 0000:0a:06.0: bridge window [io 0x7400-0x74ff]
[ 0.347963] pci 0000:0a:06.0: bridge window [mem 0x84000000-0x87ffffff pref]
[ 0.347968] pci 0000:0a:06.0: bridge window [mem 0x88000000-0x8bffffff]
[ 0.347972] pci 0000:00:1e.0: PCI bridge to [bus 0a-0b]
[ 0.347975] pci 0000:00:1e.0: bridge window [io 0x7000-0x7fff]
[ 0.347981] pci 0000:00:1e.0: bridge window [mem 0xfc000000-0xfc0fffff]
[ 0.347991] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.347993] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.347995] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.347997] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000d3fff window]
[ 0.347999] pci_bus 0000:00: resource 8 [mem 0x000d4000-0x000d7fff window]
[ 0.348014] pci_bus 0000:00: resource 9 [mem 0x000d8000-0x000dbfff window]
[ 0.348016] pci_bus 0000:00: resource 10 [mem 0x000dc000-0x000dffff window]
[ 0.348018] pci_bus 0000:00: resource 11 [mem 0x000e0000-0x000e3fff window]
[ 0.348019] pci_bus 0000:00: resource 12 [mem 0x80000000-0xdfffffff window]
[ 0.348021] pci_bus 0000:00: resource 13 [mem 0xf0000000-0xfebfffff window]
[ 0.348024] pci_bus 0000:01: resource 0 [io 0x2000-0x2fff]
[ 0.348025] pci_bus 0000:01: resource 1 [mem 0xc8000000-0xcaffffff]
[ 0.348027] pci_bus 0000:01: resource 2 [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.348029] pci_bus 0000:02: resource 0 [io 0x3000-0x3fff]
[ 0.348031] pci_bus 0000:02: resource 1 [mem 0xfa000000-0xfbffffff]
[ 0.348033] pci_bus 0000:02: resource 2 [mem 0xf4000000-0xf5ffffff 64bit pref]
[ 0.348035] pci_bus 0000:04: resource 0 [io 0x4000-0x4fff]
[ 0.348037] pci_bus 0000:04: resource 1 [mem 0xf6000000-0xf7ffffff]
[ 0.348039] pci_bus 0000:04: resource 2 [mem 0xf0000000-0xf1ffffff 64bit pref]
[ 0.348041] pci_bus 0000:06: resource 0 [io 0x5000-0x5fff]
[ 0.348042] pci_bus 0000:06: resource 1 [mem 0xf8000000-0xf9ffffff]
[ 0.348044] pci_bus 0000:06: resource 2 [mem 0xf2000000-0xf3ffffff 64bit pref]
[ 0.348046] pci_bus 0000:08: resource 0 [io 0x6000-0x6fff]
[ 0.348048] pci_bus 0000:08: resource 1 [mem 0xc4000000-0xc5ffffff]
[ 0.348050] pci_bus 0000:08: resource 2 [mem 0xcc000000-0xcdffffff 64bit pref]
[ 0.348052] pci_bus 0000:0a: resource 0 [io 0x7000-0x7fff]
[ 0.348053] pci_bus 0000:0a: resource 1 [mem 0xfc000000-0xfc0fffff]
[ 0.348055] pci_bus 0000:0a: resource 4 [io 0x0000-0x0cf7 window]
[ 0.348057] pci_bus 0000:0a: resource 5 [io 0x0d00-0xffff window]
[ 0.348059] pci_bus 0000:0a: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.348061] pci_bus 0000:0a: resource 7 [mem 0x000d0000-0x000d3fff window]
[ 0.348062] pci_bus 0000:0a: resource 8 [mem 0x000d4000-0x000d7fff window]
[ 0.348064] pci_bus 0000:0a: resource 9 [mem 0x000d8000-0x000dbfff window]
[ 0.348066] pci_bus 0000:0a: resource 10 [mem 0x000dc000-0x000dffff window]
[ 0.348068] pci_bus 0000:0a: resource 11 [mem 0x000e0000-0x000e3fff window]
[ 0.348070] pci_bus 0000:0a: resource 12 [mem 0x80000000-0xdfffffff window]
[ 0.348071] pci_bus 0000:0a: resource 13 [mem 0xf0000000-0xfebfffff window]
[ 0.348073] pci_bus 0000:0b: resource 0 [io 0x7000-0x70ff]
[ 0.348075] pci_bus 0000:0b: resource 1 [io 0x7400-0x74ff]
[ 0.348077] pci_bus 0000:0b: resource 2 [mem 0x84000000-0x87ffffff pref]
[ 0.348079] pci_bus 0000:0b: resource 3 [mem 0x88000000-0x8bffffff]
[ 0.348212] NET: Registered protocol family 2
[ 0.348432] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.348452] TCP bind hash table entries: 8192 (order: 5, 229376 bytes)
[ 0.348547] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.348581] UDP hash table entries: 512 (order: 3, 32768 bytes)
[ 0.348599] UDP-Lite hash table entries: 512 (order: 3, 32768 bytes)
[ 0.348669] NET: Registered protocol family 1
[ 0.351245] pci 0000:01:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.351326] PCI: CLS 64 bytes, default 64
[ 0.351395] Unpacking initramfs...
[ 0.837908] Freeing initrd memory: 22552K
[ 0.838549] audit: initializing netlink subsys (disabled)
[ 0.838579] audit: type=2000 audit(1535817997.836:1): initialized
[ 0.839149] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[ 0.842189] zbud: loaded
[ 0.843169] bounce: pool size: 64 pages
[ 0.843224] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 0.843261] io scheduler noop registered
[ 0.843263] io scheduler deadline registered
[ 0.843318] io scheduler cfq registered (default)
[ 0.844986] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.844995] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.845021] intel_idle: does not run on family 6 model 15
[ 0.854344] Monitor-Mwait will be used to enter C-1 state
[ 0.854351] Monitor-Mwait will be used to enter C-2 state
[ 0.854356] Monitor-Mwait will be used to enter C-3 state
[ 0.854362] tsc: Marking TSC unstable due to TSC halts in idle
[ 0.856613] GHES: HEST is not enabled!
[ 0.856673] isapnp: Scanning for PnP cards...
[ 1.210246] isapnp: No Plug & Play device found
[ 1.210365] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.230928] 00:04: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[ 1.231709] Linux agpgart interface v0.103
[ 1.232405] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 1.237435] i8042: Detected active multiplexing controller, rev 1.1
[ 1.240087] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.240150] serio: i8042 AUX0 port at 0x60,0x64 irq 12
[ 1.240205] serio: i8042 AUX1 port at 0x60,0x64 irq 12
[ 1.240261] serio: i8042 AUX2 port at 0x60,0x64 irq 12
[ 1.240307] serio: i8042 AUX3 port at 0x60,0x64 irq 12
[ 1.240506] mousedev: PS/2 mouse device common for all mice
[ 1.240572] rtc_cmos 00:03: RTC can wake from S4
[ 1.240767] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0
[ 1.240860] rtc_cmos 00:03: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[ 1.241577] NET: Registered protocol family 10
[ 1.241916] mip6: Mobile IPv6
[ 1.241919] NET: Registered protocol family 17
[ 1.241922] mpls_gso: MPLS GSO support
[ 1.242163] microcode: sig=0x6fb, pf=0x80, revision=0xba
[ 1.242263] microcode: Microcode Update Driver: v2.01 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 1.242267] Using IPI No-Shortcut mode
[ 1.242509] registered taskstats version 1
[ 1.242542] zswap: loaded using pool lzo/zbud
[ 1.242592] ima: No TPM chip found, activating TPM-bypass!
[ 1.243151] rtc_cmos 00:03: setting system clock to 2018-09-01 16:06:39 UTC (1535817999)
[ 1.243223] PM: Hibernation image not present or could not be loaded.
[ 1.243838] Freeing unused kernel memory: 1052K
[ 1.243970] Write protecting the kernel text: 5980k
[ 1.244107] Write protecting the kernel read-only data: 1760k
[ 1.244108] NX-protecting the kernel data: 4260k
[ 1.244379] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.262926] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 1.263051] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 1.264389] random: udevadm: uninitialized urandom read (16 bytes read)
[ 1.264714] random: udevadm: uninitialized urandom read (16 bytes read)
[ 1.266514] random: udevadm: uninitialized urandom read (16 bytes read)
[ 1.266618] random: udevadm: uninitialized urandom read (16 bytes read)
[ 1.266721] random: udevadm: uninitialized urandom read (16 bytes read)
[ 1.266832] random: udevadm: uninitialized urandom read (16 bytes read)
[ 1.266955] random: udevadm: uninitialized urandom read (16 bytes read)
[ 1.267522] random: udevadm: uninitialized urandom read (16 bytes read)
[ 1.279974] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[ 1.311023] ACPI: bus type USB registered
[ 1.311065] usbcore: registered new interface driver usbfs
[ 1.311082] usbcore: registered new interface driver hub
[ 1.316794] usbcore: registered new device driver usb
[ 1.317472] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.317880] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.318175] uhci_hcd 0000:00:1a.0: UHCI Host Controller
[ 1.318184] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 1
[ 1.318194] uhci_hcd 0000:00:1a.0: detected 2 ports
[ 1.320500] uhci_hcd 0000:00:1a.0: irq 16, io base 0x00001800
[ 1.320584] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.320587] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.320589] usb usb1: Product: UHCI Host Controller
[ 1.320590] usb usb1: Manufacturer: Linux 4.9.0-5-rt-686-pae uhci_hcd
[ 1.320592] usb usb1: SerialNumber: 0000:00:1a.0
[ 1.328505] hub 1-0:1.0: USB hub found
[ 1.328516] hub 1-0:1.0: 2 ports detected
[ 1.328933] uhci_hcd 0000:00:1a.1: UHCI Host Controller
[ 1.328940] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 2
[ 1.328948] uhci_hcd 0000:00:1a.1: detected 2 ports
[ 1.329124] ehci-pci: EHCI PCI platform driver
[ 1.334677] uhci_hcd 0000:00:1a.1: irq 21, io base 0x00001820
[ 1.334920] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.334922] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.334924] usb usb2: Product: UHCI Host Controller
[ 1.334926] usb usb2: Manufacturer: Linux 4.9.0-5-rt-686-pae uhci_hcd
[ 1.334928] usb usb2: SerialNumber: 0000:00:1a.1
[ 1.335123] hub 2-0:1.0: USB hub found
[ 1.335132] hub 2-0:1.0: 2 ports detected
[ 1.346125] pps_core: LinuxPPS API ver. 1 registered
[ 1.346126] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.346712] thermal LNXTHERM:00: registered as thermal_zone0
[ 1.346713] ACPI: Thermal Zone [TZ00] (53 C)
[ 1.347145] PTP clock support registered
[ 1.347248] thermal LNXTHERM:01: registered as thermal_zone1
[ 1.347249] ACPI: Thermal Zone [TZVR] (55 C)
[ 1.347436] thermal LNXTHERM:02: registered as thermal_zone2
[ 1.347438] ACPI: Thermal Zone [TZVL] (0 C)
[ 1.347619] thermal LNXTHERM:03: registered as thermal_zone3
[ 1.347621] ACPI: Thermal Zone [TZ01] (36 C)
[ 1.348063] ehci-pci 0000:00:1a.7: EHCI Host Controller
[ 1.348073] ehci-pci 0000:00:1a.7: new USB bus registered, assigned bus number 3
[ 1.348090] ehci-pci 0000:00:1a.7: debug port 1
[ 1.352097] ehci-pci 0000:00:1a.7: cache line size of 64 is not supported
[ 1.352173] ehci-pci 0000:00:1a.7: irq 18, io mem 0xfc304800
[ 1.353959] tg3.c:v3.137 (May 11, 2014)
[ 1.355605] SCSI subsystem initialized
[ 1.360947] sdhci: Secure Digital Host Controller Interface driver
[ 1.360949] sdhci: Copyright(c) Pierre Ossman
[ 1.361318] sdhci-pci 0000:0a:06.3: SDHCI controller found [104c:803c] (rev 0)
[ 1.361331] pci 0000:00:1e.0: enabling device (0004 -> 0007)
[ 1.361343] sdhci-pci 0000:0a:06.3: enabling device (0000 -> 0002)
[ 1.362633] mmc0: SDHCI controller on PCI [0000:0a:06.3] using DMA
[ 1.363442] libata version 3.00 loaded.
[ 1.368050] ehci-pci 0000:00:1a.7: USB 2.0 started, EHCI 1.00
[ 1.368156] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.368158] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.368160] usb usb3: Product: EHCI Host Controller
[ 1.368162] usb usb3: Manufacturer: Linux 4.9.0-5-rt-686-pae ehci_hcd
[ 1.368164] usb usb3: SerialNumber: 0000:00:1a.7
[ 1.369518] hub 3-0:1.0: USB hub found
[ 1.369530] hub 3-0:1.0: 4 ports detected
[ 1.396173] hub 1-0:1.0: USB hub found
[ 1.396186] hub 1-0:1.0: 2 ports detected
[ 1.420676] tg3 0000:02:00.0: VPD access failed. This is likely a firmware bug on this device. Contact the card vendor for a firmware update
[ 1.421711] tg3 0000:02:00.0 eth0: Tigon3 [partno(none) rev b002] (PCI Express) MAC address 00:a0:d1:a3:62:6f
[ 1.421714] tg3 0000:02:00.0 eth0: attached PHY is 5787 (10/100/1000Base-T Ethernet) (WireSpeed[1], EEE[0])
[ 1.421716] tg3 0000:02:00.0 eth0: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[0] TSOcap[1]
[ 1.421718] tg3 0000:02:00.0 eth0: dma_rwctrl[76180000] dma_mask[64-bit]
[ 1.424105] hub 2-0:1.0: USB hub found
[ 1.424117] hub 2-0:1.0: 2 ports detected
[ 1.424481] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 1.424488] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 4
[ 1.424498] uhci_hcd 0000:00:1d.0: detected 2 ports
[ 1.424710] uhci_hcd 0000:00:1d.0: irq 23, io base 0x00001840
[ 1.424795] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.424798] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.424799] usb usb4: Product: UHCI Host Controller
[ 1.424801] usb usb4: Manufacturer: Linux 4.9.0-5-rt-686-pae uhci_hcd
[ 1.424803] usb usb4: SerialNumber: 0000:00:1d.0
[ 1.424988] hub 4-0:1.0: USB hub found
[ 1.424999] hub 4-0:1.0: 2 ports detected
[ 1.425178] ata_piix 0000:00:1f.1: version 2.13
[ 1.430413] scsi host0: ata_piix
[ 1.434581] scsi host1: ata_piix
[ 1.434665] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0x18a0 irq 14
[ 1.434667] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0x18a8 irq 15
[ 1.434724] ahci 0000:00:1f.2: version 3.0
[ 1.435025] ahci 0000:00:1f.2: AHCI 0001.0100 32 slots 3 ports 3 Gbps 0x7 impl SATA mode
[ 1.435029] ahci 0000:00:1f.2: flags: 64bit ncq sntf pm led clo pio slum part ccc
[ 1.436089] firewire_ohci 0000:0a:06.1: added OHCI v1.10 device as card 0, 4 IR + 8 IT contexts, quirks 0x2
[ 1.440149] scsi host2: ahci
[ 1.444422] scsi host3: ahci
[ 1.448597] scsi host4: ahci
[ 1.448697] ata3: SATA max UDMA/133 abar m2048@0xfc304000 port 0xfc304100 irq 29
[ 1.448700] ata4: SATA max UDMA/133 abar m2048@0xfc304000 port 0xfc304180 irq 29
[ 1.448702] ata5: SATA max UDMA/133 abar m2048@0xfc304000 port 0xfc304200 irq 29
[ 1.449070] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
[ 1.450782] ehci-pci 0000:00:1d.7: EHCI Host Controller
[ 1.450789] ehci-pci 0000:00:1d.7: new USB bus registered, assigned bus number 5
[ 1.450804] ehci-pci 0000:00:1d.7: debug port 1
[ 1.454699] ehci-pci 0000:00:1d.7: cache line size of 64 is not supported
[ 1.455359] ehci-pci 0000:00:1d.7: irq 23, io mem 0xfc304c00
[ 1.468038] ehci-pci 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 1.468133] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.468135] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.468137] usb usb5: Product: EHCI Host Controller
[ 1.468139] usb usb5: Manufacturer: Linux 4.9.0-5-rt-686-pae ehci_hcd
[ 1.468141] usb usb5: SerialNumber: 0000:00:1d.7
[ 1.468342] hub 5-0:1.0: USB hub found
[ 1.468353] hub 5-0:1.0: 6 ports detected
[ 1.493069] tg3 0000:02:00.0 enp2s0: renamed from eth0
[ 1.496283] hub 4-0:1.0: USB hub found
[ 1.496295] hub 4-0:1.0: 2 ports detected
[ 1.496667] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 1.496741] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 6
[ 1.496749] uhci_hcd 0000:00:1d.1: detected 2 ports
[ 1.499414] uhci_hcd 0000:00:1d.1: irq 19, io base 0x00001860
[ 1.499536] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.499538] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.499540] usb usb6: Product: UHCI Host Controller
[ 1.499542] usb usb6: Manufacturer: Linux 4.9.0-5-rt-686-pae uhci_hcd
[ 1.499544] usb usb6: SerialNumber: 0000:00:1d.1
[ 1.499738] hub 6-0:1.0: USB hub found
[ 1.499749] hub 6-0:1.0: 2 ports detected
[ 1.500188] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 1.500195] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 7
[ 1.500202] uhci_hcd 0000:00:1d.2: detected 2 ports
[ 1.500267] uhci_hcd 0000:00:1d.2: irq 18, io base 0x00001880
[ 1.500398] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.500401] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.500402] usb usb7: Product: UHCI Host Controller
[ 1.500404] usb usb7: Manufacturer: Linux 4.9.0-5-rt-686-pae uhci_hcd
[ 1.500406] usb usb7: SerialNumber: 0000:00:1d.2
[ 1.500598] hub 7-0:1.0: USB hub found
[ 1.500609] hub 7-0:1.0: 2 ports detected
[ 1.696059] usb 3-2: new high-speed USB device number 2 using ehci-pci
[ 1.768181] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 1.770680] ata3.00: unexpected _GTF length (8)
[ 1.771900] ata3.00: ATA-7: ST9120822AS, 3.AXC, max UDMA/133
[ 1.771904] ata3.00: 234441648 sectors, multi 16: LBA48 NCQ (depth 31/32)
[ 1.776215] ata3.00: unexpected _GTF length (8)
[ 1.776259] ata4: SATA link down (SStatus 0 SControl 300)
[ 1.777453] ata3.00: configured for UDMA/133
[ 1.780259] ata5: SATA link down (SStatus 0 SControl 300)
[ 1.796191] usb 5-6: new high-speed USB device number 2 using ehci-pci
[ 1.856063] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x1fa24b52fc2, max_idle_ns: 440795273332 ns
[ 1.876367] ata1.01: ATAPI: Slimtype DVD A DS8A1P, CA14, max UDMA/33
[ 1.920269] ata1.01: configured for UDMA/33
[ 1.926890] scsi 0:0:1:0: CD-ROM Slimtype DVD A DS8A1P CA14 PQ: 0 ANSI: 5
[ 1.945754] scsi 2:0:0:0: Direct-Access ATA ST9120822AS C PQ: 0 ANSI: 5
[ 1.952226] firewire_core 0000:0a:06.1: created device fw0: GUID 00a0d1a0d1a3626f, S400
[ 1.953174] usb 5-6: New USB device found, idVendor=064e, idProduct=a101
[ 1.953179] usb 5-6: New USB device strings: Mfr=2, Product=1, SerialNumber=3
[ 1.953183] usb 5-6: Product: Acer CrystalEye webcam
[ 1.953186] usb 5-6: Manufacturer: SuYin
[ 1.953189] usb 5-6: SerialNumber: CN0314-OV03-VA-R02.00.00
[ 1.993865] sd 2:0:0:0: [sda] 234441648 512-byte logical blocks: (120 GB/112 GiB)
[ 1.993949] sd 2:0:0:0: [sda] Write Protect is off
[ 1.993951] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.993982] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.008078] sr 0:0:1:0: [sr0] scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[ 2.008081] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 2.008617] sr 0:0:1:0: Attached scsi CD-ROM sr0
[ 2.081065] sda: sda1 sda2 < sda5 >
[ 2.081593] sd 2:0:0:0: [sda] Attached SCSI disk
[ 2.129694] psmouse serio2: synaptics: Touchpad model: 1, fw: 6.2, id: 0x1280b1, caps: 0xa04713/0x204000/0x0/0x0, board id: 0, fw id: 235996
[ 2.166097] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio2/input/input6
[ 2.212874] random: fast init done
[ 2.769490] PM: Starting manual resume from disk
[ 2.769494] PM: Hibernation image partition 8:5 present
[ 2.769495] PM: Looking for hibernation image.
[ 2.769693] PM: Image not found (code -22)
[ 2.769697] PM: Hibernation image not present or could not be loaded.
[ 3.281981] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 5.028419] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 5.087242] random: crng init done
[ 5.205748] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[ 5.205913] systemd[1]: Detected architecture x86.
[ 5.216600] systemd[1]: Set hostname to <228>.
[ 6.397947] systemd[1]: live-tools.service: Cannot add dependency job, ignoring: Unit live-tools.service is masked.
[ 6.398017] systemd[1]: rsync.service: Cannot add dependency job, ignoring: Unit rsync.service is masked.
[ 6.398979] systemd[1]: Listening on Journal Audit Socket.
[ 6.399094] systemd[1]: Listening on Journal Socket (/dev/log).
[ 6.399158] systemd[1]: Listening on udev Control Socket.
[ 6.399368] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 6.399452] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 6.884727] usb 3-2: New USB device found, idVendor=07ca, idProduct=a310
[ 6.884731] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 6.884733] usb 3-2: Product: A310
[ 6.884734] usb 3-2: Manufacturer: AVerMedia
[ 6.884736] usb 3-2: SerialNumber: 000000000000
[ 7.048772] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 7.402468] lp: driver loaded but no devices found
[ 7.481440] ppdev: user-space parallel port driver
[ 7.490395] parport_pc 00:05: [io 0x0378-0x037f]
[ 7.490400] parport_pc 00:05: [io 0x0778-0x077f]
[ 7.490612] parport_pc 00:05: [irq 7]
[ 7.490615] parport_pc 00:05: [dma 1]
[ 7.491440] parport_pc 00:05: activated
[ 7.491443] parport_pc 00:05: reported by Plug and Play ACPI
[ 7.491573] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE]
[ 7.565465] systemd-journald[230]: Received request to flush runtime journal from PID 1
[ 7.596211] lp0: using parport0 (interrupt-driven).
[ 9.249165] [Firmware Bug]: ACPI(EVGA) defines _DOD but not _DOS
[ 9.249224] ACPI: Video Device [EVGA] (multi-head: yes rom: no post: no)
[ 9.328155] acpi device:03: registered as cooling_device3
[ 9.328229] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:01/LNXVIDEO:00/input/input9
[ 9.359646] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 9.381893] ACPI: AC Adapter [ADP0] (on-line)
[ 9.382176] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input10
[ 9.382181] ACPI: Sleep Button [SLPB]
[ 9.382284] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input11
[ 9.382304] ACPI: Lid Switch [LID]
[ 9.382377] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input12
[ 9.382380] ACPI: Power Button [PWRB]
[ 9.382451] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input13
[ 9.382454] ACPI: Power Button [PWRF]
[ 9.796708] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC268: line_outs=2 (0x15/0x16/0x0/0x0/0x0) type:speaker
[ 9.796711] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 9.796714] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x14/0x0/0x0/0x0/0x0)
[ 9.796716] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 9.796717] snd_hda_codec_realtek hdaudioC0D0: dig-out=0x1e/0x0
[ 9.796719] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 9.796721] snd_hda_codec_realtek hdaudioC0D0: Internal Mic=0x19
[ 9.796724] snd_hda_codec_realtek hdaudioC0D0: Mic=0x18
[ 9.796725] snd_hda_codec_realtek hdaudioC0D0: Line=0x1a
[ 9.808161] wmi: Mapper loaded
[ 9.913373] [drm] Initialized
[ 9.924446] yenta_cardbus 0000:0a:06.0: enabling device (0000 -> 0003)
[ 9.924531] yenta_cardbus 0000:0a:06.0: CardBus bridge found [1025:0129]
[ 9.924549] yenta_cardbus 0000:0a:06.0: Enabling burst memory read transactions
[ 9.924554] yenta_cardbus 0000:0a:06.0: Using CSCINT to route CSC interrupts to PCI
[ 9.924556] yenta_cardbus 0000:0a:06.0: Routing CardBus interrupts to PCI
[ 9.924561] yenta_cardbus 0000:0a:06.0: TI: mfunc 0x01a61b22, devctl 0x66
[ 9.934146] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/sound/card0/input14
[ 9.934581] input: HDA Intel Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input15
[ 9.934638] input: HDA Intel Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input16
[ 9.934695] input: HDA Intel Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input17
[ 9.998963] ACPI Warning: SystemIO range 0x0000000000001028-0x000000000000102F conflicts with OpRegion 0x0000000000001000-0x000000000000107F (\PMIO) (20160831/utaddress-247)
[ 9.998971] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 9.998975] ACPI Warning: SystemIO range 0x00000000000011B0-0x00000000000011BF conflicts with OpRegion 0x0000000000001180-0x00000000000011BB (\GPIO) (20160831/utaddress-247)
[ 9.998980] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 9.998981] ACPI Warning: SystemIO range 0x0000000000001180-0x00000000000011AF conflicts with OpRegion 0x0000000000001180-0x00000000000011BB (\GPIO) (20160831/utaddress-247)
[ 9.998985] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 9.998986] lpc_ich: Resource conflict(s) found affecting gpio_ich
[ 10.003590] ite_cir: Auto-detected model: ITE8709 CIR transceiver
[ 10.003592] ite_cir: Using model: ITE8709 CIR transceiver
[ 10.003594] ite_cir: TX-capable: 1
[ 10.003595] ite_cir: Sample period (ns): 8680
[ 10.003596] ite_cir: TX carrier frequency (Hz): 38000
[ 10.003597] ite_cir: TX duty cycle (%): 33
[ 10.003598] ite_cir: RX low carrier frequency (Hz): 0
[ 10.003599] ite_cir: RX high carrier frequency (Hz): 0
[ 10.011637] media: Linux media interface: v0.10
[ 10.044140] Linux video capture interface: v2.00
[ 10.079161] usb 3-2: dvb_usb_v2: found a 'AVerMedia A310 USB 2.0 DVB-T tuner' in warm state
[ 10.079947] sr 0:0:1:0: Attached scsi generic sg0 type 5
[ 10.080663] sd 2:0:0:0: Attached scsi generic sg1 type 0
[ 10.086557] usb 3-2: dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
[ 10.086584] DVB: registering new adapter (AVerMedia A310 USB 2.0 DVB-T tuner)
[ 10.097123] ACPI: Battery Slot [BAT0] (battery present)
[ 10.124059] Registered IR keymap rc-rc6-mce
[ 10.124181] input: ITE8709 CIR transceiver as /devices/virtual/rc/rc0/input18
[ 10.140981] usb 3-2: DVB: registering adapter 0 frontend 0 (Zarlink ZL10353 DVB-T)...
[ 10.157483] rc rc0: ITE8709 CIR transceiver as /devices/virtual/rc/rc0
[ 10.236722] yenta_cardbus 0000:0a:06.0: ISA IRQ mask 0x0c78, PCI irq 21
[ 10.236726] yenta_cardbus 0000:0a:06.0: Socket status: 30000006
[ 10.236730] pci_bus 0000:0a: Raising subordinate bus# of parent bus (#0a) from #0b to #0e
[ 10.236736] yenta_cardbus 0000:0a:06.0: pcmcia: parent PCI bridge window: [io 0x7000-0x7fff]
[ 10.236739] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x7000-0x7fff:
[ 10.238081] excluding 0x7000-0x70ff 0x7400-0x74ff
[ 10.244650] yenta_cardbus 0000:0a:06.0: pcmcia: parent PCI bridge window: [mem 0xfc000000-0xfc0fffff]
[ 10.244653] pcmcia_socket pcmcia_socket0: cs: memory probe 0xfc000000-0xfc0fffff:
[ 10.244657] excluding 0xfc000000-0xfc00ffff
[ 10.245087] tifm_7xx1 0000:0a:06.2: enabling device (0000 -> 0002)
[ 10.246422] lirc_dev: IR Remote Control driver registered, major 244
[ 10.246660] IR RC6 protocol handler initialized
[ 10.257052] rc rc0: lirc_dev: driver ir-lirc-codec (ite-cir) registered at minor = 0
[ 10.257055] IR LIRC bridge handler initialized
[ 10.272158] ite_cir: driver has been successfully loaded
[ 10.301084] MXL5005S: Attached at address 0xc6
[ 10.301395] usb 3-2: dvb_usb_v2: 'AVerMedia A310 USB 2.0 DVB-T tuner' successfully initialized and connected
[ 10.301422] usbcore: registered new interface driver dvb_usb_ce6230
[ 10.308233] uvcvideo: Found UVC 1.00 device Acer CrystalEye webcam (064e:a101)
[ 10.310743] uvcvideo 5-6:1.0: Entity type for entity Extension 4 was not initialized!
[ 10.310748] uvcvideo 5-6:1.0: Entity type for entity Processing 3 was not initialized!
[ 10.310751] uvcvideo 5-6:1.0: Entity type for entity Camera 1 was not initialized!
[ 10.310903] input: Acer CrystalEye webcam as /devices/pci0000:00/0000:00:1d.7/usb5/5-6/5-6:1.0/input/input19
[ 10.310941] usbcore: registered new interface driver uvcvideo
[ 10.310942] USB Video Class driver (1.1.1)
[ 10.428293] nouveau 0000:01:00.0: NVIDIA G84 (084700a2)
[ 10.548746] nouveau 0000:01:00.0: bios: version 60.84.62.00.39
[ 10.570364] nouveau 0000:01:00.0: bios: M0203T not found
[ 10.570366] nouveau 0000:01:00.0: bios: M0203E not matched!
[ 10.570369] nouveau 0000:01:00.0: fb: 256 MiB DDR2
[ 10.619592] [TTM] Zone kernel: Available graphics memory: 439372 kiB
[ 10.619594] [TTM] Zone highmem: Available graphics memory: 1031664 kiB
[ 10.619595] [TTM] Initializing pool allocator
[ 10.619603] [TTM] Initializing DMA pool allocator
[ 10.619626] nouveau 0000:01:00.0: DRM: VRAM: 256 MiB
[ 10.619628] nouveau 0000:01:00.0: DRM: GART: 1048576 MiB
[ 10.619633] nouveau 0000:01:00.0: DRM: TMDS table version 2.0
[ 10.619635] nouveau 0000:01:00.0: DRM: DCB version 4.0
[ 10.619638] nouveau 0000:01:00.0: DRM: DCB outp 00: 01000323 00000035
[ 10.619641] nouveau 0000:01:00.0: DRM: DCB outp 01: 02011300 00000028
[ 10.619643] nouveau 0000:01:00.0: DRM: DCB outp 02: 02022312 00000010
[ 10.619645] nouveau 0000:01:00.0: DRM: DCB outp 03: 010333f1 00c0c080
[ 10.619647] nouveau 0000:01:00.0: DRM: DCB conn 00: 0040
[ 10.619649] nouveau 0000:01:00.0: DRM: DCB conn 01: 0100
[ 10.619651] nouveau 0000:01:00.0: DRM: DCB conn 02: 1231
[ 10.619653] nouveau 0000:01:00.0: DRM: DCB conn 03: 0310
[ 10.619654] nouveau 0000:01:00.0: DRM: DCB conn 04: 0311
[ 10.619659] nouveau 0000:01:00.0: DRM: BIOS FP mode: 1680x1050 (151000kHz pixel clock)
[ 10.684449] nouveau 0000:01:00.0: DRM: failed to create encoder 0/1/0: -19
[ 10.684452] nouveau 0000:01:00.0: DRM: TV-1 has no encoders, removing
[ 10.684496] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 10.684497] [drm] Driver supports precise vblank timestamp query.
[ 10.725039] input: PC Speaker as /devices/platform/pcspkr/input/input20
[ 10.762321] nouveau 0000:01:00.0: DRM: MM: using CRYPT for buffer copies
[ 11.188529] iTCO_vendor_support: vendor-support=0
[ 11.191584] acer_wmi: Acer Laptop ACPI-WMI Extras
[ 11.191737] acer_wmi: Function bitmap for Communication Device: 0x17
[ 11.353768] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[ 11.353808] iTCO_wdt: Found a ICH8M TCO device (Version=2, TCOBASE=0x1060)
[ 11.354164] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 11.398611] intel_powerclamp: No package C-state available
[ 11.438519] iwl4965: Intel(R) Wireless WiFi 4965 driver for Linux, in-tree:
[ 11.438521] iwl4965: Copyright(c) 2003-2011 Intel Corporation
[ 11.438580] iwl4965 0000:08:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 11.438773] iwl4965 0000:08:00.0: Detected Intel(R) Wireless WiFi Link 4965AGN, REV=0x4
[ 11.482163] iwl4965 0000:08:00.0: device EEPROM VER=0x36, CALIB=0x5
[ 11.482180] iwl4965 0000:08:00.0: Tunable channels: 13 802.11bg, 19 802.11a channels
[ 11.533900] iwl4965 0000:08:00.0: firmware: direct-loading firmware iwlwifi-4965-2.ucode
[ 11.533907] iwl4965 0000:08:00.0: loaded firmware version 228.61.2.24
[ 11.836042] usb 7-1: new full-speed USB device number 2 using uhci_hcd
[ 11.886050] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x100-0x3af:
[ 11.886922] excluding 0x170-0x177 0x1f0-0x277 0x370-0x37f
[ 11.887514] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x3e0-0x4ff:
[ 11.887883] excluding 0x3f0-0x407 0x4d0-0x4d7
[ 11.888261] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x820-0x8ff:
[ 11.888850] clean
[ 11.888869] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xc00-0xcf7:
[ 11.889536] clean
[ 11.889561] pcmcia_socket pcmcia_socket0: cs: memory probe 0x0c0000-0x0fffff:
[ 11.889568] excluding 0xc0000-0xcffff 0xe4000-0xfffff
[ 11.889602] pcmcia_socket pcmcia_socket0: cs: memory probe 0xa0000000-0xa0ffffff:
[ 11.889625] clean
[ 11.889643] pcmcia_socket pcmcia_socket0: cs: memory probe 0x60000000-0x60ffffff:
[ 11.889659] excluding 0x60000000-0x60ffffff
[ 11.889681] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xa00-0xaff:
[ 11.890354] clean
[ 11.917571] nouveau 0000:01:00.0: DRM: allocated 1680x1050 fb: 0x50000, bo f638b400
[ 11.917670] fbcon: nouveaufb (fb0) is primary device
[ 12.019066] usb 7-1: New USB device found, idVendor=0a5c, idProduct=2101
[ 12.019069] usb 7-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 12.019070] usb 7-1: Product: Acer Module
[ 12.019071] usb 7-1: Manufacturer: Broadcom Corp
[ 12.022470] Console: switching to colour frame buffer device 210x65
[ 12.027048] nouveau 0000:01:00.0: fb0: nouveaufb frame buffer device
[ 12.040071] [drm] Initialized nouveau 1.3.1 20120801 for 0000:01:00.0 on minor 0
[ 12.203182] ieee80211 phy0: Selected rate control algorithm 'iwl-4965-rs'
[ 12.308230] Adding 2093052k swap on /dev/sda5. Priority:-1 extents:1 across:2093052k FS
[ 16.664578] iwl4965 0000:08:00.0: RF_KILL bit toggled to enable radio.
[ 16.664581] iwl4965 0000:08:00.0: On demand firmware reload
[ 16.664623] ieee80211 phy0: Hardware restart was requested
[ 16.819790] iwl4965 0000:08:00.0 wlp8s0: renamed from wlan0
[ 17.535042] Bluetooth: Core ver 2.22
[ 17.535076] NET: Registered protocol family 31
[ 17.535078] Bluetooth: HCI device and connection manager initialized
[ 17.535083] Bluetooth: HCI socket layer initialized
[ 17.535087] Bluetooth: L2CAP socket layer initialized
[ 17.535098] Bluetooth: SCO socket layer initialized
[ 17.702987] usbcore: registered new interface driver btusb
[ 19.960099] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 19.960101] Bluetooth: BNEP filters: protocol multicast
[ 19.960106] Bluetooth: BNEP socket layer initialized
[ 24.214479] IPv6: ADDRCONF(NETDEV_UP): enp2s0: link is not ready
[ 24.264358] IPv6: ADDRCONF(NETDEV_UP): enp2s0: link is not ready
[ 24.285310] IPv6: ADDRCONF(NETDEV_UP): wlp8s0: link is not ready
[ 24.534834] IPv6: ADDRCONF(NETDEV_UP): wlp8s0: link is not ready
[ 24.841962] IPv6: ADDRCONF(NETDEV_UP): wlp8s0: link is not ready
[ 25.899902] IPv6: ADDRCONF(NETDEV_UP): wlp8s0: link is not ready
[ 41.506881] IPv6: ADDRCONF(NETDEV_UP): wlp8s0: link is not ready
[ 43.797265] wlp8s0: authenticate with 18:d6:c7:de:f0:0c
[ 43.813284] wlp8s0: send auth to 18:d6:c7:de:f0:0c (try 1/3)
[ 43.814983] wlp8s0: authenticated
[ 43.816037] wlp8s0: associate with 18:d6:c7:de:f0:0c (try 1/3)
[ 43.826495] wlp8s0: RX AssocResp from 18:d6:c7:de:f0:0c (capab=0x411 status=0 aid=1)
[ 43.852947] wlp8s0: associated
[ 43.853018] IPv6: ADDRCONF(NETDEV_CHANGE): wlp8s0: link becomes ready
[ 212.002937] tg3 0000:02:00.0 enp2s0: Link is up at 100 Mbps, full duplex
[ 212.002940] tg3 0000:02:00.0 enp2s0: Flow control is on for TX and on for RX
[ 212.003644] IPv6: ADDRCONF(NETDEV_CHANGE): enp2s0: link becomes ready
[ 315.313307] perf: interrupt took too long (2505 > 2500), lowering kernel.perf_event_max_sample_rate to 79750
[ 344.918329] perf: interrupt took too long (3141 > 3131), lowering kernel.perf_event_max_sample_rate to 63500
[ 393.773090] perf: interrupt took too long (3929 > 3926), lowering kernel.perf_event_max_sample_rate to 50750
[ 493.338243] perf: interrupt took too long (4923 > 4911), lowering kernel.perf_event_max_sample_rate to 40500
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.7.14
Machine configuration directory is '/home/cnc/linuxcnc/configs/тест_1_энкодер_на_оси_посмотреть_что_генерит'
Machine configuration file is 'тест_1_энкодер_на_оси_посмотреть_что_генерит.ini'
INIFILE=/home/cnc/linuxcnc/configs/тест_1_энкодер_на_оси_посмотреть_что_генерит/тест_1_энкодер_на_оси_посмотреть_что_генерит.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Found file(REL): ./тест_1_энкодер_на_оси_посмотреть_что_генерит.hal
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 192.168.1.121: Hardware address: 00:60:1b:13:03:fe
hm2_eth: discovered 7I92
hm2/hm2_7i92.0: Smart Serial Firmware Version 43
hm2/hm2_7i92.0: 34 I/O Pins used:
hm2/hm2_7i92.0: IO Pin 000 (P2-01): StepGen #0, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 001 (P2-14): StepGen #0, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 002 (P2-02): StepGen #1, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 003 (P2-15): StepGen #1, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 004 (P2-03): StepGen #2, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 005 (P2-16): StepGen #2, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 006 (P2-04): IOPort
hm2/hm2_7i92.0: IO Pin 007 (P2-17): IOPort
hm2/hm2_7i92.0: IO Pin 008 (P2-05): IOPort
hm2/hm2_7i92.0: IO Pin 009 (P2-06): IOPort
hm2/hm2_7i92.0: IO Pin 010 (P2-07): IOPort
hm2/hm2_7i92.0: IO Pin 011 (P2-08): IOPort
hm2/hm2_7i92.0: IO Pin 012 (P2-09): IOPort
hm2/hm2_7i92.0: IO Pin 013 (P2-10): IOPort
hm2/hm2_7i92.0: IO Pin 014 (P2-11): Encoder #0, pin Index (Input)
hm2/hm2_7i92.0: IO Pin 015 (P2-12): Encoder #0, pin B (Input)
hm2/hm2_7i92.0: IO Pin 016 (P2-13): Encoder #0, pin A (Input)
hm2/hm2_7i92.0: IO Pin 017 (P1-01): IOPort
hm2/hm2_7i92.0: IO Pin 018 (P1-14): IOPort
hm2/hm2_7i92.0: IO Pin 019 (P1-02): IOPort
hm2/hm2_7i92.0: IO Pin 020 (P1-15): IOPort
hm2/hm2_7i92.0: IO Pin 021 (P1-03): IOPort
hm2/hm2_7i92.0: IO Pin 022 (P1-16): IOPort
hm2/hm2_7i92.0: IO Pin 023 (P1-04): IOPort
hm2/hm2_7i92.0: IO Pin 024 (P1-17): IOPort
hm2/hm2_7i92.0: IO Pin 025 (P1-05): IOPort
hm2/hm2_7i92.0: IO Pin 026 (P1-06): IOPort
hm2/hm2_7i92.0: IO Pin 027 (P1-07): IOPort
hm2/hm2_7i92.0: IO Pin 028 (P1-08): IOPort
hm2/hm2_7i92.0: IO Pin 029 (P1-09): IOPort
hm2/hm2_7i92.0: IO Pin 030 (P1-10): IOPort
hm2/hm2_7i92.0: IO Pin 031 (P1-11): IOPort
hm2/hm2_7i92.0: IO Pin 032 (P1-12): IOPort
hm2/hm2_7i92.0: IO Pin 033 (P1-13): IOPort
hm2/hm2_7i92.0: registered
Running HAL shutdown script
Killing task linuxcncsvr, PID=1373
hm2_eth: HostMot2 ethernet driver unloaded
hm2: unloading
Debug file information:
Note: Using POSIX realtime
./тест_1_энкодер_на_оси_посмотреть_что_генерит.hal:128: Pin 'hm2_7i92.0.encoder.00.position-fb' does not exist
1373
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Linux version 4.9.0-5-rt-686-pae (debian-kernel@lists.debian.org) (gcc version 6.3.0 20170516 (Debian 6.3.0-18) ) #1 SMP PREEMPT RT Debian 4.9.65-3+deb9u2 (2018-01-04)
[ 0.000000] x86/fpu: Legacy x87 FPU detected.
[ 0.000000] x86/fpu: Using 'eager' FPU context switches.
[ 0.000000] e820: BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009dfff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009e000-0x000000000009ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000000e4000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000007fecffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000007fed0000-0x000000007fedefff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000007fedf000-0x000000007fffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec0ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed003ff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed14000-0x00000000fed19fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed8ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] SMBIOS 2.4 present.
[ 0.000000] DMI: Acer Aspire 9920/Aspire 9920, BIOS V1.20 01/07/08
[ 0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000000] e820: last_pfn = 0x7fed0 max_arch_pfn = 0x1000000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask F80000000 write-back
[ 0.000000] 1 base 07FF00000 mask FFFF00000 uncachable
[ 0.000000] 2 disabled
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WC UC- WT
[ 0.000000] found SMP MP-table at [mem 0x000f70c0-0x000f70cf] mapped at [c00f70c0]
[ 0.000000] initial memory mapped: [mem 0x00000000-0x10ffffff]
[ 0.000000] Base memory trampoline at [c009a000] 9a000 size 16384
[ 0.000000] BRK [0x10a59000, 0x10a59fff] PGTABLE
[ 0.000000] BRK [0x10a5a000, 0x10a5bfff] PGTABLE
[ 0.000000] BRK [0x10a5c000, 0x10a5cfff] PGTABLE
[ 0.000000] BRK [0x10a5d000, 0x10a5dfff] PGTABLE
[ 0.000000] RAMDISK: [mem 0x353e3000-0x369e8fff]
[ 0.000000] ACPI: Early table checksum verification disabled
[ 0.000000] ACPI: RSDP 0x00000000000F7020 000024 (v02 ACRSYS)
[ 0.000000] ACPI: XSDT 0x000000007FED258F 00008C (v01 ACRSYS ACRPRDCT 06040000 LTP 00000000)
[ 0.000000] ACPI: FACP 0x000000007FEDBBD2 0000F4 (v03 INTEL CRESTLNE 06040000 ALAN 00000001)
[ 0.000000] ACPI: DSDT 0x000000007FED3AB3 0080AB (v02 INTEL CRESTLNE 06040000 INTL 20050624)
[ 0.000000] ACPI: FACS 0x000000007FEDEFC0 000040
[ 0.000000] ACPI: APIC 0x000000007FEDBCC6 000068 (v01 INTEL CRESTLNE 06040000 LOHR 0000005A)
[ 0.000000] ACPI: HPET 0x000000007FEDBD2E 000038 (v01 INTEL CRESTLNE 06040000 LOHR 0000005A)
[ 0.000000] ACPI: MCFG 0x000000007FEDBD66 00003C (v01 INTEL CRESTLNE 06040000 LOHR 0000005A)
[ 0.000000] ACPI: TCPA 0x000000007FEDBDA2 000032 (v01 Intel CRESTLN 06040000 00005A52)
[ 0.000000] ACPI: TMOR 0x000000007FEDBDD4 000026 (v01 PTLTD 06040000 PTL 00000003)
[ 0.000000] ACPI: APIC 0x000000007FEDBDFA 000068 (v01 PTLTD ? APIC 06040000 LTP 00000000)
[ 0.000000] ACPI: SLIC 0x000000007FEDBE62 000176 (v01 ACRSYS ACRPRDCT 06040000 LTP 00000000)
[ 0.000000] ACPI: BOOT 0x000000007FEDBFD8 000028 (v01 PTLTD $SBFTBL$ 06040000 LTP 00000001)
[ 0.000000] ACPI: SSDT 0x000000007FED37BE 0002F5 (v01 SataRe SataAhci 00001000 INTL 20050624)
[ 0.000000] ACPI: SSDT 0x000000007FED2BA7 00025F (v01 PmRef Cpu0Tst 00003000 INTL 20050624)
[ 0.000000] ACPI: SSDT 0x000000007FED2B01 0000A6 (v01 PmRef Cpu1Tst 00003000 INTL 20050624)
[ 0.000000] ACPI: SSDT 0x000000007FED261B 0004E6 (v01 PmRef CpuPm 00003000 INTL 20050624)
[ 0.000000] ACPI: BIOS bug: multiple APIC/MADT found, using 0
[ 0.000000] ACPI: If "acpi_apic_instance=2" works better, notify linux-acpi@vger.kernel.org
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 1156MB HIGHMEM available.
[ 0.000000] 889MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 379fe000
[ 0.000000] low ram: 0 - 379fe000
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.000000] Normal [mem 0x0000000001000000-0x00000000379fdfff]
[ 0.000000] HighMem [mem 0x00000000379fe000-0x000000007fecffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000001000-0x000000000009dfff]
[ 0.000000] node 0: [mem 0x0000000000100000-0x000000007fecffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x000000007fecffff]
[ 0.000000] On node 0 totalpages: 523885
[ 0.000000] free_area_init_node: node 0, pgdat d081b580, node_mem_map f3fe3028
[ 0.000000] DMA zone: 40 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3997 pages, LIFO batch:0
[ 0.000000] Normal zone: 2185 pages used for memmap
[ 0.000000] Normal zone: 223742 pages, LIFO batch:31
[ 0.000000] HighMem zone: 296146 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x1008
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.000000] IOAPIC[0]: apic_id 1, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.000000] smpboot: Allowing 2 CPUs, 0 hotplug CPUs
[ 0.000000] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.000000] PM: Registered nosave memory: [mem 0x0009e000-0x0009ffff]
[ 0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000e3fff]
[ 0.000000] PM: Registered nosave memory: [mem 0x000e4000-0x000fffff]
[ 0.000000] e820: [mem 0x80000000-0xdfffffff] available for PCI devices
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[ 0.000000] setup_percpu: NR_CPUS:32 nr_cpumask_bits:32 nr_cpu_ids:2 nr_node_ids:1
[ 0.000000] percpu: Embedded 101 pages/cpu @f7931000 s381408 r0 d32288 u413696
[ 0.000000] pcpu-alloc: s381408 r0 d32288 u413696 alloc=101*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 521660
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.9.0-5-rt-686-pae root=/dev/sda1 ro quiet
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] microcode: microcode updated early to revision 0xba, date = 2010-10-03
[ 0.000000] Initializing CPU#0
[ 0.000000] Initializing HighMem for node 0 (000379fe:0007fed0)
[ 0.000000] Initializing Movable for node 0 (00000000:00000000)
[ 0.000000] Memory: 2039700K/2095540K available (5978K kernel code, 632K rwdata, 1752K rodata, 1052K init, 592K bss, 55840K reserved, 0K cma-reserved, 1184584K highmem)
[ 0.000000] virtual kernel memory layout:
fixmap : 0xffd36000 - 0xfffff000 (2852 kB)
pkmap : 0xffa00000 - 0xffc00000 (2048 kB)
vmalloc : 0xf81fe000 - 0xff9fe000 ( 120 MB)
lowmem : 0xc0000000 - 0xf79fe000 ( 889 MB)
.init : 0xd082f000 - 0xd0936000 (1052 kB)
.data : 0xd05d6e64 - 0xd082d0c0 (2392 kB)
.text : 0xd0000000 - 0xd05d6e64 (5979 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=32 to nr_cpu_ids=2.
[ 0.000000] RCU kthread priority: 1.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS:2304 nr_irqs:440 16
[ 0.000000] CPU 0 irqstacks, hard=f703e000 soft=f7080000
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[ 0.000000] hpet clockevent registered
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] tsc: Detected 2194.606 MHz processor
[ 0.004004] Calibrating delay loop (skipped), value calculated using timer frequency.. 4389.21 BogoMIPS (lpj=8778424)
[ 0.004005] pid_max: default: 32768 minimum: 301
[ 0.004022] ACPI: Core revision 20160831
[ 0.013083] ACPI: 5 ACPI AML tables successfully acquired and loaded
[ 0.013109] Security Framework initialized
[ 0.013110] Yama: disabled by default; enable with sysctl kernel.yama.*
[ 0.013118] AppArmor: AppArmor disabled by boot time parameter
[ 0.013130] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.013132] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.013455] CPU: Physical Processor ID: 0
[ 0.013455] CPU: Processor Core ID: 0
[ 0.013461] mce: CPU supports 6 MCE banks
[ 0.013471] process: using mwait in idle threads
[ 0.013478] Last level iTLB entries: 4KB 128, 2MB 4, 4MB 4
[ 0.013479] Last level dTLB entries: 4KB 256, 2MB 0, 4MB 32, 1GB 0
[ 0.013697] Freeing SMP alternatives memory: 24K
[ 0.015913] ftrace: allocating 24005 entries in 47 pages
[ 0.024102] smpboot: Max logical packages: 1
[ 0.024108] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.024501] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.068000] smpboot: CPU0: Intel(R) Core(TM)2 Duo CPU T7500 @ 2.20GHz (family: 0x6, model: 0xf, stepping: 0xb)
[ 0.068000] Performance Events: PEBS fmt0+, Core2 events, Intel PMU driver.
[ 0.068000] core: PEBS disabled due to CPU errata
[ 0.068000] ... version: 2
[ 0.068000] ... bit width: 40
[ 0.068000] ... generic registers: 2
[ 0.068000] ... value mask: 000000ffffffffff
[ 0.068000] ... max period: 000000007fffffff
[ 0.068000] ... fixed-purpose events: 3
[ 0.068000] ... event mask: 0000000700000003
[ 0.120088] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[ 0.172025] CPU 1 irqstacks, hard=f7196000 soft=f7198000
[ 0.172026] x86: Booting SMP configuration:
[ 0.172028] .... node #0, CPUs: #1
[ 0.008000] Initializing CPU#1
[ 0.180086] x86: Booted up 1 node, 2 CPUs
[ 0.180086] smpboot: Total of 2 processors activated (8778.42 BogoMIPS)
[ 0.182093] devtmpfs: initialized
[ 0.182093] PM: Registering ACPI NVS region [mem 0x7fed0000-0x7fedefff] (61440 bytes)
[ 0.182093] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.182093] futex hash table entries: 512 (order: 3, 32768 bytes)
[ 0.182093] pinctrl core: initialized pinctrl subsystem
[ 0.182093] NET: Registered protocol family 16
[ 0.188017] cpuidle: using governor ladder
[ 0.192012] cpuidle: using governor menu
[ 0.192046] Simple Boot Flag at 0x36 set to 0x1
[ 0.192059] ACPI: bus type PCI registered
[ 0.192061] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.192142] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.192144] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[ 0.192145] PCI: Using MMCONFIG for extended config space
[ 0.192146] PCI: Using configuration type 1 for base access
[ 0.192252] mtrr: your CPUs had inconsistent variable MTRR settings
[ 0.192253] mtrr: probably your BIOS does not setup all CPUs.
[ 0.192254] mtrr: corrected configuration.
[ 0.192617] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.192617] ACPI: Added _OSI(Module Device)
[ 0.192617] ACPI: Added _OSI(Processor Device)
[ 0.192617] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.192617] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.220012] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 0.241791] ACPI: Dynamic OEM Table Load:
[ 0.241800] ACPI: SSDT 0x00000000F7207C00 00027A (v01 PmRef Cpu0Ist 00003000 INTL 20050624)
[ 0.242056] ACPI: Dynamic OEM Table Load:
[ 0.242063] ACPI: SSDT 0x00000000F71F3000 0005F1 (v01 PmRef Cpu0Cst 00003001 INTL 20050624)
[ 0.242390] ACPI: Dynamic OEM Table Load:
[ 0.242396] ACPI: SSDT 0x00000000F71C3E00 0000C8 (v01 PmRef Cpu1Ist 00003000 INTL 20050624)
[ 0.242571] ACPI: Dynamic OEM Table Load:
[ 0.242577] ACPI: SSDT 0x00000000F71BC240 000085 (v01 PmRef Cpu1Cst 00003000 INTL 20050624)
[ 0.243134] ACPI : EC: EC started
[ 0.243136] ACPI : EC: interrupt blocked
[ 0.243235] ACPI: \_SB_.PCI0.LPCB.EC0_: Used as first EC
[ 0.243238] ACPI: \_SB_.PCI0.LPCB.EC0_: GPE=0x16, EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.243240] ACPI: \_SB_.PCI0.LPCB.EC0_: Used as boot DSDT EC to handle transactions
[ 0.243241] ACPI: Interpreter enabled
[ 0.243266] ACPI: (supports S0 S3 S4 S5)
[ 0.243268] ACPI: Using IOAPIC for interrupt routing
[ 0.243298] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.245203] acpi SADDLEST:00: ACPI dock station (docks/bays count: 1)
[ 0.252167] ACPI: Power Resource [FN00] (off)
[ 0.253110] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.253116] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[ 0.253121] acpi PNP0A08:00: _OSC failed (AE_NOT_FOUND); disabling ASPM
[ 0.253781] PCI host bridge to bus 0000:00
[ 0.253784] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.253786] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.253788] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.253790] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff window]
[ 0.253792] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff window]
[ 0.253794] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff window]
[ 0.253796] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
[ 0.253797] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff window]
[ 0.253799] pci_bus 0000:00: root bus resource [mem 0x80000000-0xdfffffff window]
[ 0.253801] pci_bus 0000:00: root bus resource [mem 0xf0000000-0xfebfffff window]
[ 0.253803] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.253814] pci 0000:00:00.0: [8086:2a00] type 00 class 0x060000
[ 0.253982] pci 0000:00:01.0: [8086:2a01] type 01 class 0x060400
[ 0.254037] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.254203] pci 0000:00:1a.0: [8086:2834] type 00 class 0x0c0300
[ 0.254261] pci 0000:00:1a.0: reg 0x20: [io 0x1800-0x181f]
[ 0.254385] pci 0000:00:1a.0: System wakeup disabled by ACPI
[ 0.254451] pci 0000:00:1a.1: [8086:2835] type 00 class 0x0c0300
[ 0.254508] pci 0000:00:1a.1: reg 0x20: [io 0x1820-0x183f]
[ 0.254632] pci 0000:00:1a.1: System wakeup disabled by ACPI
[ 0.254710] pci 0000:00:1a.7: [8086:283a] type 00 class 0x0c0320
[ 0.254731] pci 0000:00:1a.7: reg 0x10: [mem 0xfc304800-0xfc304bff]
[ 0.254835] pci 0000:00:1a.7: PME# supported from D0 D3hot D3cold
[ 0.254978] pci 0000:00:1b.0: [8086:284b] type 00 class 0x040300
[ 0.255003] pci 0000:00:1b.0: reg 0x10: [mem 0xfc300000-0xfc303fff 64bit]
[ 0.255108] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.255191] pci 0000:00:1b.0: System wakeup disabled by ACPI
[ 0.255258] pci 0000:00:1c.0: [8086:283f] type 01 class 0x060400
[ 0.255365] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.255514] pci 0000:00:1c.1: [8086:2841] type 01 class 0x060400
[ 0.255624] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[ 0.255772] pci 0000:00:1c.2: [8086:2843] type 01 class 0x060400
[ 0.255878] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[ 0.256037] pci 0000:00:1c.3: [8086:2845] type 01 class 0x060400
[ 0.256144] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[ 0.256294] pci 0000:00:1d.0: [8086:2830] type 00 class 0x0c0300
[ 0.256352] pci 0000:00:1d.0: reg 0x20: [io 0x1840-0x185f]
[ 0.256476] pci 0000:00:1d.0: System wakeup disabled by ACPI
[ 0.256537] pci 0000:00:1d.1: [8086:2831] type 00 class 0x0c0300
[ 0.256596] pci 0000:00:1d.1: reg 0x20: [io 0x1860-0x187f]
[ 0.256717] pci 0000:00:1d.1: System wakeup disabled by ACPI
[ 0.256783] pci 0000:00:1d.2: [8086:2832] type 00 class 0x0c0300
[ 0.256840] pci 0000:00:1d.2: reg 0x20: [io 0x1880-0x189f]
[ 0.257007] pci 0000:00:1d.7: [8086:2836] type 00 class 0x0c0320
[ 0.257029] pci 0000:00:1d.7: reg 0x10: [mem 0xfc304c00-0xfc304fff]
[ 0.257133] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.257208] pci 0000:00:1d.7: System wakeup disabled by ACPI
[ 0.257277] pci 0000:00:1e.0: [8086:2448] type 01 class 0x060401
[ 0.257459] pci 0000:00:1f.0: [8086:2815] type 00 class 0x060100
[ 0.257550] pci 0000:00:1f.0: quirk: [io 0x1000-0x107f] claimed by ICH6 ACPI/GPIO/TCO
[ 0.257556] pci 0000:00:1f.0: quirk: [io 0x1180-0x11bf] claimed by ICH6 GPIO
[ 0.257559] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 1 PIO at 0400 (mask 0003)
[ 0.257563] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 2 PIO at 1640 (mask 007f)
[ 0.257717] pci 0000:00:1f.1: [8086:2850] type 00 class 0x01018a
[ 0.257734] pci 0000:00:1f.1: reg 0x10: [io 0x0000-0x0007]
[ 0.257746] pci 0000:00:1f.1: reg 0x14: [io 0x0000-0x0003]
[ 0.257758] pci 0000:00:1f.1: reg 0x18: [io 0x0000-0x0007]
[ 0.257769] pci 0000:00:1f.1: reg 0x1c: [io 0x0000-0x0003]
[ 0.257781] pci 0000:00:1f.1: reg 0x20: [io 0x18a0-0x18af]
[ 0.257806] pci 0000:00:1f.1: legacy IDE quirk: reg 0x10: [io 0x01f0-0x01f7]
[ 0.257808] pci 0000:00:1f.1: legacy IDE quirk: reg 0x14: [io 0x03f6]
[ 0.257810] pci 0000:00:1f.1: legacy IDE quirk: reg 0x18: [io 0x0170-0x0177]
[ 0.257811] pci 0000:00:1f.1: legacy IDE quirk: reg 0x1c: [io 0x0376]
[ 0.257943] pci 0000:00:1f.2: [8086:2829] type 00 class 0x010601
[ 0.257964] pci 0000:00:1f.2: reg 0x10: [io 0x18d8-0x18df]
[ 0.257974] pci 0000:00:1f.2: reg 0x14: [io 0x18cc-0x18cf]
[ 0.257985] pci 0000:00:1f.2: reg 0x18: [io 0x18d0-0x18d7]
[ 0.257996] pci 0000:00:1f.2: reg 0x1c: [io 0x18c8-0x18cb]
[ 0.258007] pci 0000:00:1f.2: reg 0x20: [io 0x18e0-0x18ff]
[ 0.258018] pci 0000:00:1f.2: reg 0x24: [mem 0xfc304000-0xfc3047ff]
[ 0.258074] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.258209] pci 0000:00:1f.3: [8086:283e] type 00 class 0x0c0500
[ 0.258226] pci 0000:00:1f.3: reg 0x10: [mem 0x00000000-0x000000ff]
[ 0.258265] pci 0000:00:1f.3: reg 0x20: [io 0x1c00-0x1c1f]
[ 0.258487] pci 0000:01:00.0: [10de:0407] type 00 class 0x030000
[ 0.258501] pci 0000:01:00.0: reg 0x10: [mem 0xca000000-0xcaffffff]
[ 0.258514] pci 0000:01:00.0: reg 0x14: [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.258526] pci 0000:01:00.0: reg 0x1c: [mem 0xc8000000-0xc9ffffff 64bit]
[ 0.258535] pci 0000:01:00.0: reg 0x24: [io 0x2000-0x207f]
[ 0.258543] pci 0000:01:00.0: reg 0x30: [mem 0x00000000-0x0001ffff pref]
[ 0.268010] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.268014] pci 0000:00:01.0: bridge window [io 0x2000-0x2fff]
[ 0.268017] pci 0000:00:01.0: bridge window [mem 0xc8000000-0xcaffffff]
[ 0.268022] pci 0000:00:01.0: bridge window [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.268206] pci 0000:02:00.0: [14e4:1693] type 00 class 0x020000
[ 0.268278] pci 0000:02:00.0: reg 0x10: [mem 0xfa000000-0xfa00ffff 64bit]
[ 0.268691] pci 0000:02:00.0: PME# supported from D3hot D3cold
[ 0.268840] pci 0000:02:00.0: System wakeup disabled by ACPI
[ 0.269018] pci 0000:00:1c.0: PCI bridge to [bus 02-03]
[ 0.269025] pci 0000:00:1c.0: bridge window [mem 0xfa000000-0xfbffffff]
[ 0.269033] pci 0000:00:1c.0: bridge window [mem 0xf4000000-0xf5ffffff 64bit pref]
[ 0.269132] acpiphp: Slot [1] registered
[ 0.269139] pci 0000:00:1c.1: PCI bridge to [bus 04-05]
[ 0.269146] pci 0000:00:1c.1: bridge window [mem 0xf6000000-0xf7ffffff]
[ 0.269154] pci 0000:00:1c.1: bridge window [mem 0xf0000000-0xf1ffffff 64bit pref]
[ 0.269242] pci 0000:00:1c.2: PCI bridge to [bus 06-07]
[ 0.269250] pci 0000:00:1c.2: bridge window [mem 0xf8000000-0xf9ffffff]
[ 0.269257] pci 0000:00:1c.2: bridge window [mem 0xf2000000-0xf3ffffff 64bit pref]
[ 0.269408] pci 0000:08:00.0: [8086:4229] type 00 class 0x028000
[ 0.269460] pci 0000:08:00.0: reg 0x10: [mem 0xc4000000-0xc4001fff 64bit]
[ 0.269698] pci 0000:08:00.0: PME# supported from D0 D3hot D3cold
[ 0.269778] pci 0000:08:00.0: System wakeup disabled by ACPI
[ 0.280042] pci 0000:00:1c.3: PCI bridge to [bus 08-09]
[ 0.280050] pci 0000:00:1c.3: bridge window [mem 0xc4000000-0xc5ffffff]
[ 0.280057] pci 0000:00:1c.3: bridge window [mem 0xcc000000-0xcdffffff 64bit pref]
[ 0.280178] pci 0000:0a:06.0: [104c:8039] type 02 class 0x060700
[ 0.280196] pci 0000:0a:06.0: reg 0x10: [mem 0xfc004000-0xfc004fff]
[ 0.280234] pci 0000:0a:06.0: supports D1 D2
[ 0.280236] pci 0000:0a:06.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.280326] pci 0000:0a:06.1: [104c:803a] type 00 class 0x0c0010
[ 0.280346] pci 0000:0a:06.1: reg 0x10: [mem 0xfc006000-0xfc0067ff]
[ 0.280357] pci 0000:0a:06.1: reg 0x14: [mem 0xfc000000-0xfc003fff]
[ 0.280445] pci 0000:0a:06.1: supports D1 D2
[ 0.280447] pci 0000:0a:06.1: PME# supported from D0 D1 D2 D3hot
[ 0.280535] pci 0000:0a:06.2: [104c:803b] type 00 class 0x018000
[ 0.280552] pci 0000:0a:06.2: reg 0x10: [mem 0xfc005000-0xfc005fff]
[ 0.280632] pci 0000:0a:06.2: supports D1 D2
[ 0.280634] pci 0000:0a:06.2: PME# supported from D0 D1 D2 D3hot
[ 0.280718] pci 0000:0a:06.3: [104c:803c] type 00 class 0x080501
[ 0.280735] pci 0000:0a:06.3: reg 0x10: [mem 0xfc006800-0xfc0068ff]
[ 0.280735] pci 0000:0a:06.3: supports D1 D2
[ 0.280735] pci 0000:0a:06.3: PME# supported from D0 D1 D2 D3hot
[ 0.280735] pci 0000:00:1e.0: PCI bridge to [bus 0a-0b] (subtractive decode)
[ 0.280735] pci 0000:00:1e.0: bridge window [mem 0xfc000000-0xfc0fffff]
[ 0.280735] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7 window] (subtractive decode)
[ 0.280735] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff window] (subtractive decode)
[ 0.280735] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode)
[ 0.280735] pci 0000:00:1e.0: bridge window [mem 0x000d0000-0x000d3fff window] (subtractive decode)
[ 0.280735] pci 0000:00:1e.0: bridge window [mem 0x000d4000-0x000d7fff window] (subtractive decode)
[ 0.280735] pci 0000:00:1e.0: bridge window [mem 0x000d8000-0x000dbfff window] (subtractive decode)
[ 0.280735] pci 0000:00:1e.0: bridge window [mem 0x000dc000-0x000dffff window] (subtractive decode)
[ 0.280735] pci 0000:00:1e.0: bridge window [mem 0x000e0000-0x000e3fff window] (subtractive decode)
[ 0.280735] pci 0000:00:1e.0: bridge window [mem 0x80000000-0xdfffffff window] (subtractive decode)
[ 0.280735] pci 0000:00:1e.0: bridge window [mem 0xf0000000-0xfebfffff window] (subtractive decode)
[ 0.280735] pci_bus 0000:0b: busn_res: can not insert [bus 0b-ff] under [bus 0a-0b] (conflicts with (null) [bus 0a-0b])
[ 0.280735] pci_bus 0000:0b: busn_res: [bus 0b-ff] end is updated to 0e
[ 0.280735] pci_bus 0000:0b: busn_res: can not insert [bus 0b-0e] under [bus 0a-0b] (conflicts with (null) [bus 0a-0b])
[ 0.280735] pci_bus 0000:0b: [bus 0b-0e] partially hidden behind transparent bridge 0000:0a [bus 0a-0b]
[ 0.280735] pci 0000:00:1e.0: bridge has subordinate 0b but max busn 0e
[ 0.280735] pci_bus 0000:00: on NUMA node 0
[ 0.280735] ACPI: PCI Interrupt Link [LNKA] (IRQs 1 3 4 *5 6 7 10 12 14 15)
[ 0.280735] ACPI: PCI Interrupt Link [LNKB] (IRQs 1 3 4 5 6 7 11 12 14 15) *10
[ 0.280735] ACPI: PCI Interrupt Link [LNKC] (IRQs 1 3 4 5 6 7 10 12 14 15) *11
[ 0.280751] ACPI: PCI Interrupt Link [LNKD] (IRQs 1 3 4 5 6 7 11 12 14 15) *10
[ 0.280825] ACPI: PCI Interrupt Link [LNKE] (IRQs 1 3 4 5 6 7 10 12 14 15) *0, disabled.
[ 0.280900] ACPI: PCI Interrupt Link [LNKF] (IRQs 1 3 4 5 6 7 *11 12 14 15)
[ 0.280973] ACPI: PCI Interrupt Link [LNKG] (IRQs 1 3 4 5 6 7 10 12 14 15) *11
[ 0.281047] ACPI: PCI Interrupt Link [LNKH] (IRQs 1 3 4 5 6 7 11 12 14 15) *10
[ 0.282065] ACPI: Enabled 3 GPEs in block 00 to 1F
[ 0.282132] ACPI : EC: interrupt unblocked
[ 0.282140] ACPI : EC: event unblocked
[ 0.282148] ACPI: \_SB_.PCI0.LPCB.EC0_: GPE=0x16, EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.282151] ACPI: \_SB_.PCI0.LPCB.EC0_: Used as boot DSDT EC to handle transactions and events
[ 0.282279] vgaarb: setting as boot device: PCI:0000:01:00.0
[ 0.282279] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.282279] vgaarb: loaded
[ 0.282279] vgaarb: bridge control possible 0000:01:00.0
[ 0.282279] PCI: Using ACPI for IRQ routing
[ 0.292369] PCI: pci_cache_line_size set to 64 bytes
[ 0.292547] e820: reserve RAM buffer [mem 0x0009e000-0x0009ffff]
[ 0.292549] e820: reserve RAM buffer [mem 0x7fed0000-0x7fffffff]
[ 0.292720] HPET: 3 timers in total, 0 timers will be used for per-cpu timer
[ 0.292720] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.292720] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
[ 0.294128] clocksource: Switched to clocksource hpet
[ 0.307817] VFS: Disk quotas dquot_6.6.0
[ 0.307840] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.307967] pnp: PnP ACPI init
[ 0.308259] system 00:00: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.308262] system 00:00: [mem 0xfed14000-0xfed17fff] has been reserved
[ 0.308265] system 00:00: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.308271] system 00:00: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.308273] system 00:00: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.308276] system 00:00: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.308278] system 00:00: [mem 0xfed40000-0xfed44fff] has been reserved
[ 0.308280] system 00:00: [mem 0xfed45000-0xfed8ffff] has been reserved
[ 0.308286] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.308726] system 00:01: [mem 0xfed00000-0xfed003ff] has been reserved
[ 0.308730] system 00:01: Plug and Play ACPI device, IDs PNP0103 PNP0c01 (active)
[ 0.308830] system 00:02: [io 0x0400-0x0401] has been reserved
[ 0.308833] system 00:02: [io 0x01f8-0x0273] has been reserved
[ 0.308835] system 00:02: [io 0x0680-0x069f] has been reserved
[ 0.308838] system 00:02: [io 0x0800-0x080f] has been reserved
[ 0.308840] system 00:02: [io 0x1000-0x107f] has been reserved
[ 0.308843] system 00:02: [io 0x1180-0x11bf] has been reserved
[ 0.308845] system 00:02: [io 0x1640-0x164f] has been reserved
[ 0.308847] system 00:02: [io 0xfe00] has been reserved
[ 0.308851] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.308897] pnp 00:03: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.309287] pnp 00:04: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.309530] pnp 00:05: Plug and Play ACPI device, IDs PNP0401 (disabled)
[ 0.309621] pnp 00:06: Plug and Play ACPI device, IDs ITE8709 (active)
[ 0.309680] pnp 00:07: Plug and Play ACPI device, IDs PNP0303 (active)
[ 0.309726] pnp 00:08: Plug and Play ACPI device, IDs SYN1904 SYN1900 SYN0002 PNP0f13 (active)
[ 0.309813] pnp: PnP ACPI: found 9 devices
[ 0.309816] PnPBIOS: Disabled
[ 0.347675] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.347699] pci 0000:00:1c.0: bridge window [io 0x1000-0x0fff] to [bus 02-03] add_size 1000
[ 0.347710] pci 0000:00:1c.1: bridge window [io 0x1000-0x0fff] to [bus 04-05] add_size 1000
[ 0.347720] pci 0000:00:1c.2: bridge window [io 0x1000-0x0fff] to [bus 06-07] add_size 1000
[ 0.347731] pci 0000:00:1c.3: bridge window [io 0x1000-0x0fff] to [bus 08-09] add_size 1000
[ 0.347748] pci 0000:0a:06.0: res[13]=[io 0x0100-0x00ff] res_to_dev_res add_size 100 min_align 100
[ 0.347751] pci 0000:0a:06.0: res[14]=[io 0x0100-0x00ff] res_to_dev_res add_size 100 min_align 100
[ 0.347753] pci 0000:00:1e.0: bridge window [io 0x1000-0x0fff] to [bus 0a-0b] add_size 1000
[ 0.347761] pci 0000:00:1c.0: res[13]=[io 0x1000-0x0fff] res_to_dev_res add_size 1000 min_align 1000
[ 0.347763] pci 0000:00:1c.0: res[13]=[io 0x1000-0x1fff] res_to_dev_res add_size 1000 min_align 1000
[ 0.347766] pci 0000:00:1c.1: res[13]=[io 0x1000-0x0fff] res_to_dev_res add_size 1000 min_align 1000
[ 0.347768] pci 0000:00:1c.1: res[13]=[io 0x1000-0x1fff] res_to_dev_res add_size 1000 min_align 1000
[ 0.347770] pci 0000:00:1c.2: res[13]=[io 0x1000-0x0fff] res_to_dev_res add_size 1000 min_align 1000
[ 0.347772] pci 0000:00:1c.2: res[13]=[io 0x1000-0x1fff] res_to_dev_res add_size 1000 min_align 1000
[ 0.347774] pci 0000:00:1c.3: res[13]=[io 0x1000-0x0fff] res_to_dev_res add_size 1000 min_align 1000
[ 0.347776] pci 0000:00:1c.3: res[13]=[io 0x1000-0x1fff] res_to_dev_res add_size 1000 min_align 1000
[ 0.347778] pci 0000:00:1e.0: res[13]=[io 0x1000-0x0fff] res_to_dev_res add_size 1000 min_align 1000
[ 0.347780] pci 0000:00:1e.0: res[13]=[io 0x1000-0x1fff] res_to_dev_res add_size 1000 min_align 1000
[ 0.347787] pci 0000:00:1c.0: BAR 13: assigned [io 0x3000-0x3fff]
[ 0.347791] pci 0000:00:1c.1: BAR 13: assigned [io 0x4000-0x4fff]
[ 0.347795] pci 0000:00:1c.2: BAR 13: assigned [io 0x5000-0x5fff]
[ 0.347798] pci 0000:00:1c.3: BAR 13: assigned [io 0x6000-0x6fff]
[ 0.347802] pci 0000:00:1e.0: BAR 13: assigned [io 0x7000-0x7fff]
[ 0.347808] pci 0000:00:1f.3: BAR 0: assigned [mem 0x80000000-0x800000ff]
[ 0.347816] pci 0000:01:00.0: BAR 6: no space for [mem size 0x00020000 pref]
[ 0.347818] pci 0000:01:00.0: BAR 6: failed to assign [mem size 0x00020000 pref]
[ 0.347820] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.347823] pci 0000:00:01.0: bridge window [io 0x2000-0x2fff]
[ 0.347827] pci 0000:00:01.0: bridge window [mem 0xc8000000-0xcaffffff]
[ 0.347830] pci 0000:00:01.0: bridge window [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.347835] pci 0000:00:1c.0: PCI bridge to [bus 02-03]
[ 0.347838] pci 0000:00:1c.0: bridge window [io 0x3000-0x3fff]
[ 0.347844] pci 0000:00:1c.0: bridge window [mem 0xfa000000-0xfbffffff]
[ 0.347848] pci 0000:00:1c.0: bridge window [mem 0xf4000000-0xf5ffffff 64bit pref]
[ 0.347855] pci 0000:00:1c.1: PCI bridge to [bus 04-05]
[ 0.347858] pci 0000:00:1c.1: bridge window [io 0x4000-0x4fff]
[ 0.347863] pci 0000:00:1c.1: bridge window [mem 0xf6000000-0xf7ffffff]
[ 0.347868] pci 0000:00:1c.1: bridge window [mem 0xf0000000-0xf1ffffff 64bit pref]
[ 0.347875] pci 0000:00:1c.2: PCI bridge to [bus 06-07]
[ 0.347878] pci 0000:00:1c.2: bridge window [io 0x5000-0x5fff]
[ 0.347883] pci 0000:00:1c.2: bridge window [mem 0xf8000000-0xf9ffffff]
[ 0.347888] pci 0000:00:1c.2: bridge window [mem 0xf2000000-0xf3ffffff 64bit pref]
[ 0.347895] pci 0000:00:1c.3: PCI bridge to [bus 08-09]
[ 0.347897] pci 0000:00:1c.3: bridge window [io 0x6000-0x6fff]
[ 0.347903] pci 0000:00:1c.3: bridge window [mem 0xc4000000-0xc5ffffff]
[ 0.347908] pci 0000:00:1c.3: bridge window [mem 0xcc000000-0xcdffffff 64bit pref]
[ 0.347917] pci 0000:0a:06.0: res[15]=[mem 0x04000000-0x03ffffff pref] res_to_dev_res add_size 4000000 min_align 4000000
[ 0.347920] pci 0000:0a:06.0: res[15]=[mem 0x04000000-0x07ffffff pref] res_to_dev_res add_size 4000000 min_align 4000000
[ 0.347922] pci 0000:0a:06.0: res[16]=[mem 0x04000000-0x03ffffff] res_to_dev_res add_size 4000000 min_align 4000000
[ 0.347924] pci 0000:0a:06.0: res[16]=[mem 0x04000000-0x07ffffff] res_to_dev_res add_size 4000000 min_align 4000000
[ 0.347926] pci 0000:0a:06.0: res[13]=[io 0x0100-0x00ff] res_to_dev_res add_size 100 min_align 100
[ 0.347928] pci 0000:0a:06.0: res[13]=[io 0x0100-0x01ff] res_to_dev_res add_size 100 min_align 100
[ 0.347930] pci 0000:0a:06.0: res[14]=[io 0x0100-0x00ff] res_to_dev_res add_size 100 min_align 100
[ 0.347932] pci 0000:0a:06.0: res[14]=[io 0x0100-0x01ff] res_to_dev_res add_size 100 min_align 100
[ 0.347939] pci 0000:0a:06.0: BAR 15: assigned [mem 0x84000000-0x87ffffff pref]
[ 0.347945] pci 0000:0a:06.0: BAR 16: assigned [mem 0x88000000-0x8bffffff]
[ 0.347947] pci 0000:0a:06.0: BAR 13: assigned [io 0x7000-0x70ff]
[ 0.347949] pci 0000:0a:06.0: BAR 14: assigned [io 0x7400-0x74ff]
[ 0.347952] pci 0000:0a:06.0: CardBus bridge to [bus 0b-0e]
[ 0.347954] pci 0000:0a:06.0: bridge window [io 0x7000-0x70ff]
[ 0.347958] pci 0000:0a:06.0: bridge window [io 0x7400-0x74ff]
[ 0.347963] pci 0000:0a:06.0: bridge window [mem 0x84000000-0x87ffffff pref]
[ 0.347968] pci 0000:0a:06.0: bridge window [mem 0x88000000-0x8bffffff]
[ 0.347972] pci 0000:00:1e.0: PCI bridge to [bus 0a-0b]
[ 0.347975] pci 0000:00:1e.0: bridge window [io 0x7000-0x7fff]
[ 0.347981] pci 0000:00:1e.0: bridge window [mem 0xfc000000-0xfc0fffff]
[ 0.347991] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.347993] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.347995] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.347997] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000d3fff window]
[ 0.347999] pci_bus 0000:00: resource 8 [mem 0x000d4000-0x000d7fff window]
[ 0.348014] pci_bus 0000:00: resource 9 [mem 0x000d8000-0x000dbfff window]
[ 0.348016] pci_bus 0000:00: resource 10 [mem 0x000dc000-0x000dffff window]
[ 0.348018] pci_bus 0000:00: resource 11 [mem 0x000e0000-0x000e3fff window]
[ 0.348019] pci_bus 0000:00: resource 12 [mem 0x80000000-0xdfffffff window]
[ 0.348021] pci_bus 0000:00: resource 13 [mem 0xf0000000-0xfebfffff window]
[ 0.348024] pci_bus 0000:01: resource 0 [io 0x2000-0x2fff]
[ 0.348025] pci_bus 0000:01: resource 1 [mem 0xc8000000-0xcaffffff]
[ 0.348027] pci_bus 0000:01: resource 2 [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.348029] pci_bus 0000:02: resource 0 [io 0x3000-0x3fff]
[ 0.348031] pci_bus 0000:02: resource 1 [mem 0xfa000000-0xfbffffff]
[ 0.348033] pci_bus 0000:02: resource 2 [mem 0xf4000000-0xf5ffffff 64bit pref]
[ 0.348035] pci_bus 0000:04: resource 0 [io 0x4000-0x4fff]
[ 0.348037] pci_bus 0000:04: resource 1 [mem 0xf6000000-0xf7ffffff]
[ 0.348039] pci_bus 0000:04: resource 2 [mem 0xf0000000-0xf1ffffff 64bit pref]
[ 0.348041] pci_bus 0000:06: resource 0 [io 0x5000-0x5fff]
[ 0.348042] pci_bus 0000:06: resource 1 [mem 0xf8000000-0xf9ffffff]
[ 0.348044] pci_bus 0000:06: resource 2 [mem 0xf2000000-0xf3ffffff 64bit pref]
[ 0.348046] pci_bus 0000:08: resource 0 [io 0x6000-0x6fff]
[ 0.348048] pci_bus 0000:08: resource 1 [mem 0xc4000000-0xc5ffffff]
[ 0.348050] pci_bus 0000:08: resource 2 [mem 0xcc000000-0xcdffffff 64bit pref]
[ 0.348052] pci_bus 0000:0a: resource 0 [io 0x7000-0x7fff]
[ 0.348053] pci_bus 0000:0a: resource 1 [mem 0xfc000000-0xfc0fffff]
[ 0.348055] pci_bus 0000:0a: resource 4 [io 0x0000-0x0cf7 window]
[ 0.348057] pci_bus 0000:0a: resource 5 [io 0x0d00-0xffff window]
[ 0.348059] pci_bus 0000:0a: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.348061] pci_bus 0000:0a: resource 7 [mem 0x000d0000-0x000d3fff window]
[ 0.348062] pci_bus 0000:0a: resource 8 [mem 0x000d4000-0x000d7fff window]
[ 0.348064] pci_bus 0000:0a: resource 9 [mem 0x000d8000-0x000dbfff window]
[ 0.348066] pci_bus 0000:0a: resource 10 [mem 0x000dc000-0x000dffff window]
[ 0.348068] pci_bus 0000:0a: resource 11 [mem 0x000e0000-0x000e3fff window]
[ 0.348070] pci_bus 0000:0a: resource 12 [mem 0x80000000-0xdfffffff window]
[ 0.348071] pci_bus 0000:0a: resource 13 [mem 0xf0000000-0xfebfffff window]
[ 0.348073] pci_bus 0000:0b: resource 0 [io 0x7000-0x70ff]
[ 0.348075] pci_bus 0000:0b: resource 1 [io 0x7400-0x74ff]
[ 0.348077] pci_bus 0000:0b: resource 2 [mem 0x84000000-0x87ffffff pref]
[ 0.348079] pci_bus 0000:0b: resource 3 [mem 0x88000000-0x8bffffff]
[ 0.348212] NET: Registered protocol family 2
[ 0.348432] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.348452] TCP bind hash table entries: 8192 (order: 5, 229376 bytes)
[ 0.348547] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.348581] UDP hash table entries: 512 (order: 3, 32768 bytes)
[ 0.348599] UDP-Lite hash table entries: 512 (order: 3, 32768 bytes)
[ 0.348669] NET: Registered protocol family 1
[ 0.351245] pci 0000:01:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.351326] PCI: CLS 64 bytes, default 64
[ 0.351395] Unpacking initramfs...
[ 0.837908] Freeing initrd memory: 22552K
[ 0.838549] audit: initializing netlink subsys (disabled)
[ 0.838579] audit: type=2000 audit(1535817997.836:1): initialized
[ 0.839149] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[ 0.842189] zbud: loaded
[ 0.843169] bounce: pool size: 64 pages
[ 0.843224] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 0.843261] io scheduler noop registered
[ 0.843263] io scheduler deadline registered
[ 0.843318] io scheduler cfq registered (default)
[ 0.844986] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.844995] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.845021] intel_idle: does not run on family 6 model 15
[ 0.854344] Monitor-Mwait will be used to enter C-1 state
[ 0.854351] Monitor-Mwait will be used to enter C-2 state
[ 0.854356] Monitor-Mwait will be used to enter C-3 state
[ 0.854362] tsc: Marking TSC unstable due to TSC halts in idle
[ 0.856613] GHES: HEST is not enabled!
[ 0.856673] isapnp: Scanning for PnP cards...
[ 1.210246] isapnp: No Plug & Play device found
[ 1.210365] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.230928] 00:04: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[ 1.231709] Linux agpgart interface v0.103
[ 1.232405] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 1.237435] i8042: Detected active multiplexing controller, rev 1.1
[ 1.240087] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.240150] serio: i8042 AUX0 port at 0x60,0x64 irq 12
[ 1.240205] serio: i8042 AUX1 port at 0x60,0x64 irq 12
[ 1.240261] serio: i8042 AUX2 port at 0x60,0x64 irq 12
[ 1.240307] serio: i8042 AUX3 port at 0x60,0x64 irq 12
[ 1.240506] mousedev: PS/2 mouse device common for all mice
[ 1.240572] rtc_cmos 00:03: RTC can wake from S4
[ 1.240767] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0
[ 1.240860] rtc_cmos 00:03: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[ 1.241577] NET: Registered protocol family 10
[ 1.241916] mip6: Mobile IPv6
[ 1.241919] NET: Registered protocol family 17
[ 1.241922] mpls_gso: MPLS GSO support
[ 1.242163] microcode: sig=0x6fb, pf=0x80, revision=0xba
[ 1.242263] microcode: Microcode Update Driver: v2.01 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 1.242267] Using IPI No-Shortcut mode
[ 1.242509] registered taskstats version 1
[ 1.242542] zswap: loaded using pool lzo/zbud
[ 1.242592] ima: No TPM chip found, activating TPM-bypass!
[ 1.243151] rtc_cmos 00:03: setting system clock to 2018-09-01 16:06:39 UTC (1535817999)
[ 1.243223] PM: Hibernation image not present or could not be loaded.
[ 1.243838] Freeing unused kernel memory: 1052K
[ 1.243970] Write protecting the kernel text: 5980k
[ 1.244107] Write protecting the kernel read-only data: 1760k
[ 1.244108] NX-protecting the kernel data: 4260k
[ 1.244379] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.262926] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 1.263051] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 1.264389] random: udevadm: uninitialized urandom read (16 bytes read)
[ 1.264714] random: udevadm: uninitialized urandom read (16 bytes read)
[ 1.266514] random: udevadm: uninitialized urandom read (16 bytes read)
[ 1.266618] random: udevadm: uninitialized urandom read (16 bytes read)
[ 1.266721] random: udevadm: uninitialized urandom read (16 bytes read)
[ 1.266832] random: udevadm: uninitialized urandom read (16 bytes read)
[ 1.266955] random: udevadm: uninitialized urandom read (16 bytes read)
[ 1.267522] random: udevadm: uninitialized urandom read (16 bytes read)
[ 1.279974] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[ 1.311023] ACPI: bus type USB registered
[ 1.311065] usbcore: registered new interface driver usbfs
[ 1.311082] usbcore: registered new interface driver hub
[ 1.316794] usbcore: registered new device driver usb
[ 1.317472] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.317880] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.318175] uhci_hcd 0000:00:1a.0: UHCI Host Controller
[ 1.318184] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 1
[ 1.318194] uhci_hcd 0000:00:1a.0: detected 2 ports
[ 1.320500] uhci_hcd 0000:00:1a.0: irq 16, io base 0x00001800
[ 1.320584] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.320587] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.320589] usb usb1: Product: UHCI Host Controller
[ 1.320590] usb usb1: Manufacturer: Linux 4.9.0-5-rt-686-pae uhci_hcd
[ 1.320592] usb usb1: SerialNumber: 0000:00:1a.0
[ 1.328505] hub 1-0:1.0: USB hub found
[ 1.328516] hub 1-0:1.0: 2 ports detected
[ 1.328933] uhci_hcd 0000:00:1a.1: UHCI Host Controller
[ 1.328940] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 2
[ 1.328948] uhci_hcd 0000:00:1a.1: detected 2 ports
[ 1.329124] ehci-pci: EHCI PCI platform driver
[ 1.334677] uhci_hcd 0000:00:1a.1: irq 21, io base 0x00001820
[ 1.334920] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.334922] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.334924] usb usb2: Product: UHCI Host Controller
[ 1.334926] usb usb2: Manufacturer: Linux 4.9.0-5-rt-686-pae uhci_hcd
[ 1.334928] usb usb2: SerialNumber: 0000:00:1a.1
[ 1.335123] hub 2-0:1.0: USB hub found
[ 1.335132] hub 2-0:1.0: 2 ports detected
[ 1.346125] pps_core: LinuxPPS API ver. 1 registered
[ 1.346126] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.346712] thermal LNXTHERM:00: registered as thermal_zone0
[ 1.346713] ACPI: Thermal Zone [TZ00] (53 C)
[ 1.347145] PTP clock support registered
[ 1.347248] thermal LNXTHERM:01: registered as thermal_zone1
[ 1.347249] ACPI: Thermal Zone [TZVR] (55 C)
[ 1.347436] thermal LNXTHERM:02: registered as thermal_zone2
[ 1.347438] ACPI: Thermal Zone [TZVL] (0 C)
[ 1.347619] thermal LNXTHERM:03: registered as thermal_zone3
[ 1.347621] ACPI: Thermal Zone [TZ01] (36 C)
[ 1.348063] ehci-pci 0000:00:1a.7: EHCI Host Controller
[ 1.348073] ehci-pci 0000:00:1a.7: new USB bus registered, assigned bus number 3
[ 1.348090] ehci-pci 0000:00:1a.7: debug port 1
[ 1.352097] ehci-pci 0000:00:1a.7: cache line size of 64 is not supported
[ 1.352173] ehci-pci 0000:00:1a.7: irq 18, io mem 0xfc304800
[ 1.353959] tg3.c:v3.137 (May 11, 2014)
[ 1.355605] SCSI subsystem initialized
[ 1.360947] sdhci: Secure Digital Host Controller Interface driver
[ 1.360949] sdhci: Copyright(c) Pierre Ossman
[ 1.361318] sdhci-pci 0000:0a:06.3: SDHCI controller found [104c:803c] (rev 0)
[ 1.361331] pci 0000:00:1e.0: enabling device (0004 -> 0007)
[ 1.361343] sdhci-pci 0000:0a:06.3: enabling device (0000 -> 0002)
[ 1.362633] mmc0: SDHCI controller on PCI [0000:0a:06.3] using DMA
[ 1.363442] libata version 3.00 loaded.
[ 1.368050] ehci-pci 0000:00:1a.7: USB 2.0 started, EHCI 1.00
[ 1.368156] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.368158] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.368160] usb usb3: Product: EHCI Host Controller
[ 1.368162] usb usb3: Manufacturer: Linux 4.9.0-5-rt-686-pae ehci_hcd
[ 1.368164] usb usb3: SerialNumber: 0000:00:1a.7
[ 1.369518] hub 3-0:1.0: USB hub found
[ 1.369530] hub 3-0:1.0: 4 ports detected
[ 1.396173] hub 1-0:1.0: USB hub found
[ 1.396186] hub 1-0:1.0: 2 ports detected
[ 1.420676] tg3 0000:02:00.0: VPD access failed. This is likely a firmware bug on this device. Contact the card vendor for a firmware update
[ 1.421711] tg3 0000:02:00.0 eth0: Tigon3 [partno(none) rev b002] (PCI Express) MAC address 00:a0:d1:a3:62:6f
[ 1.421714] tg3 0000:02:00.0 eth0: attached PHY is 5787 (10/100/1000Base-T Ethernet) (WireSpeed[1], EEE[0])
[ 1.421716] tg3 0000:02:00.0 eth0: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[0] TSOcap[1]
[ 1.421718] tg3 0000:02:00.0 eth0: dma_rwctrl[76180000] dma_mask[64-bit]
[ 1.424105] hub 2-0:1.0: USB hub found
[ 1.424117] hub 2-0:1.0: 2 ports detected
[ 1.424481] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 1.424488] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 4
[ 1.424498] uhci_hcd 0000:00:1d.0: detected 2 ports
[ 1.424710] uhci_hcd 0000:00:1d.0: irq 23, io base 0x00001840
[ 1.424795] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.424798] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.424799] usb usb4: Product: UHCI Host Controller
[ 1.424801] usb usb4: Manufacturer: Linux 4.9.0-5-rt-686-pae uhci_hcd
[ 1.424803] usb usb4: SerialNumber: 0000:00:1d.0
[ 1.424988] hub 4-0:1.0: USB hub found
[ 1.424999] hub 4-0:1.0: 2 ports detected
[ 1.425178] ata_piix 0000:00:1f.1: version 2.13
[ 1.430413] scsi host0: ata_piix
[ 1.434581] scsi host1: ata_piix
[ 1.434665] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0x18a0 irq 14
[ 1.434667] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0x18a8 irq 15
[ 1.434724] ahci 0000:00:1f.2: version 3.0
[ 1.435025] ahci 0000:00:1f.2: AHCI 0001.0100 32 slots 3 ports 3 Gbps 0x7 impl SATA mode
[ 1.435029] ahci 0000:00:1f.2: flags: 64bit ncq sntf pm led clo pio slum part ccc
[ 1.436089] firewire_ohci 0000:0a:06.1: added OHCI v1.10 device as card 0, 4 IR + 8 IT contexts, quirks 0x2
[ 1.440149] scsi host2: ahci
[ 1.444422] scsi host3: ahci
[ 1.448597] scsi host4: ahci
[ 1.448697] ata3: SATA max UDMA/133 abar m2048@0xfc304000 port 0xfc304100 irq 29
[ 1.448700] ata4: SATA max UDMA/133 abar m2048@0xfc304000 port 0xfc304180 irq 29
[ 1.448702] ata5: SATA max UDMA/133 abar m2048@0xfc304000 port 0xfc304200 irq 29
[ 1.449070] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
[ 1.450782] ehci-pci 0000:00:1d.7: EHCI Host Controller
[ 1.450789] ehci-pci 0000:00:1d.7: new USB bus registered, assigned bus number 5
[ 1.450804] ehci-pci 0000:00:1d.7: debug port 1
[ 1.454699] ehci-pci 0000:00:1d.7: cache line size of 64 is not supported
[ 1.455359] ehci-pci 0000:00:1d.7: irq 23, io mem 0xfc304c00
[ 1.468038] ehci-pci 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 1.468133] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.468135] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.468137] usb usb5: Product: EHCI Host Controller
[ 1.468139] usb usb5: Manufacturer: Linux 4.9.0-5-rt-686-pae ehci_hcd
[ 1.468141] usb usb5: SerialNumber: 0000:00:1d.7
[ 1.468342] hub 5-0:1.0: USB hub found
[ 1.468353] hub 5-0:1.0: 6 ports detected
[ 1.493069] tg3 0000:02:00.0 enp2s0: renamed from eth0
[ 1.496283] hub 4-0:1.0: USB hub found
[ 1.496295] hub 4-0:1.0: 2 ports detected
[ 1.496667] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 1.496741] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 6
[ 1.496749] uhci_hcd 0000:00:1d.1: detected 2 ports
[ 1.499414] uhci_hcd 0000:00:1d.1: irq 19, io base 0x00001860
[ 1.499536] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.499538] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.499540] usb usb6: Product: UHCI Host Controller
[ 1.499542] usb usb6: Manufacturer: Linux 4.9.0-5-rt-686-pae uhci_hcd
[ 1.499544] usb usb6: SerialNumber: 0000:00:1d.1
[ 1.499738] hub 6-0:1.0: USB hub found
[ 1.499749] hub 6-0:1.0: 2 ports detected
[ 1.500188] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 1.500195] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 7
[ 1.500202] uhci_hcd 0000:00:1d.2: detected 2 ports
[ 1.500267] uhci_hcd 0000:00:1d.2: irq 18, io base 0x00001880
[ 1.500398] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.500401] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.500402] usb usb7: Product: UHCI Host Controller
[ 1.500404] usb usb7: Manufacturer: Linux 4.9.0-5-rt-686-pae uhci_hcd
[ 1.500406] usb usb7: SerialNumber: 0000:00:1d.2
[ 1.500598] hub 7-0:1.0: USB hub found
[ 1.500609] hub 7-0:1.0: 2 ports detected
[ 1.696059] usb 3-2: new high-speed USB device number 2 using ehci-pci
[ 1.768181] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 1.770680] ata3.00: unexpected _GTF length (8)
[ 1.771900] ata3.00: ATA-7: ST9120822AS, 3.AXC, max UDMA/133
[ 1.771904] ata3.00: 234441648 sectors, multi 16: LBA48 NCQ (depth 31/32)
[ 1.776215] ata3.00: unexpected _GTF length (8)
[ 1.776259] ata4: SATA link down (SStatus 0 SControl 300)
[ 1.777453] ata3.00: configured for UDMA/133
[ 1.780259] ata5: SATA link down (SStatus 0 SControl 300)
[ 1.796191] usb 5-6: new high-speed USB device number 2 using ehci-pci
[ 1.856063] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x1fa24b52fc2, max_idle_ns: 440795273332 ns
[ 1.876367] ata1.01: ATAPI: Slimtype DVD A DS8A1P, CA14, max UDMA/33
[ 1.920269] ata1.01: configured for UDMA/33
[ 1.926890] scsi 0:0:1:0: CD-ROM Slimtype DVD A DS8A1P CA14 PQ: 0 ANSI: 5
[ 1.945754] scsi 2:0:0:0: Direct-Access ATA ST9120822AS C PQ: 0 ANSI: 5
[ 1.952226] firewire_core 0000:0a:06.1: created device fw0: GUID 00a0d1a0d1a3626f, S400
[ 1.953174] usb 5-6: New USB device found, idVendor=064e, idProduct=a101
[ 1.953179] usb 5-6: New USB device strings: Mfr=2, Product=1, SerialNumber=3
[ 1.953183] usb 5-6: Product: Acer CrystalEye webcam
[ 1.953186] usb 5-6: Manufacturer: SuYin
[ 1.953189] usb 5-6: SerialNumber: CN0314-OV03-VA-R02.00.00
[ 1.993865] sd 2:0:0:0: [sda] 234441648 512-byte logical blocks: (120 GB/112 GiB)
[ 1.993949] sd 2:0:0:0: [sda] Write Protect is off
[ 1.993951] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.993982] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.008078] sr 0:0:1:0: [sr0] scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[ 2.008081] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 2.008617] sr 0:0:1:0: Attached scsi CD-ROM sr0
[ 2.081065] sda: sda1 sda2 < sda5 >
[ 2.081593] sd 2:0:0:0: [sda] Attached SCSI disk
[ 2.129694] psmouse serio2: synaptics: Touchpad model: 1, fw: 6.2, id: 0x1280b1, caps: 0xa04713/0x204000/0x0/0x0, board id: 0, fw id: 235996
[ 2.166097] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio2/input/input6
[ 2.212874] random: fast init done
[ 2.769490] PM: Starting manual resume from disk
[ 2.769494] PM: Hibernation image partition 8:5 present
[ 2.769495] PM: Looking for hibernation image.
[ 2.769693] PM: Image not found (code -22)
[ 2.769697] PM: Hibernation image not present or could not be loaded.
[ 3.281981] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 5.028419] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 5.087242] random: crng init done
[ 5.205748] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[ 5.205913] systemd[1]: Detected architecture x86.
[ 5.216600] systemd[1]: Set hostname to <228>.
[ 6.397947] systemd[1]: live-tools.service: Cannot add dependency job, ignoring: Unit live-tools.service is masked.
[ 6.398017] systemd[1]: rsync.service: Cannot add dependency job, ignoring: Unit rsync.service is masked.
[ 6.398979] systemd[1]: Listening on Journal Audit Socket.
[ 6.399094] systemd[1]: Listening on Journal Socket (/dev/log).
[ 6.399158] systemd[1]: Listening on udev Control Socket.
[ 6.399368] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 6.399452] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 6.884727] usb 3-2: New USB device found, idVendor=07ca, idProduct=a310
[ 6.884731] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 6.884733] usb 3-2: Product: A310
[ 6.884734] usb 3-2: Manufacturer: AVerMedia
[ 6.884736] usb 3-2: SerialNumber: 000000000000
[ 7.048772] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 7.402468] lp: driver loaded but no devices found
[ 7.481440] ppdev: user-space parallel port driver
[ 7.490395] parport_pc 00:05: [io 0x0378-0x037f]
[ 7.490400] parport_pc 00:05: [io 0x0778-0x077f]
[ 7.490612] parport_pc 00:05: [irq 7]
[ 7.490615] parport_pc 00:05: [dma 1]
[ 7.491440] parport_pc 00:05: activated
[ 7.491443] parport_pc 00:05: reported by Plug and Play ACPI
[ 7.491573] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE]
[ 7.565465] systemd-journald[230]: Received request to flush runtime journal from PID 1
[ 7.596211] lp0: using parport0 (interrupt-driven).
[ 9.249165] [Firmware Bug]: ACPI(EVGA) defines _DOD but not _DOS
[ 9.249224] ACPI: Video Device [EVGA] (multi-head: yes rom: no post: no)
[ 9.328155] acpi device:03: registered as cooling_device3
[ 9.328229] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:01/LNXVIDEO:00/input/input9
[ 9.359646] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 9.381893] ACPI: AC Adapter [ADP0] (on-line)
[ 9.382176] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input10
[ 9.382181] ACPI: Sleep Button [SLPB]
[ 9.382284] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input11
[ 9.382304] ACPI: Lid Switch [LID]
[ 9.382377] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input12
[ 9.382380] ACPI: Power Button [PWRB]
[ 9.382451] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input13
[ 9.382454] ACPI: Power Button [PWRF]
[ 9.796708] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC268: line_outs=2 (0x15/0x16/0x0/0x0/0x0) type:speaker
[ 9.796711] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 9.796714] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x14/0x0/0x0/0x0/0x0)
[ 9.796716] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 9.796717] snd_hda_codec_realtek hdaudioC0D0: dig-out=0x1e/0x0
[ 9.796719] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 9.796721] snd_hda_codec_realtek hdaudioC0D0: Internal Mic=0x19
[ 9.796724] snd_hda_codec_realtek hdaudioC0D0: Mic=0x18
[ 9.796725] snd_hda_codec_realtek hdaudioC0D0: Line=0x1a
[ 9.808161] wmi: Mapper loaded
[ 9.913373] [drm] Initialized
[ 9.924446] yenta_cardbus 0000:0a:06.0: enabling device (0000 -> 0003)
[ 9.924531] yenta_cardbus 0000:0a:06.0: CardBus bridge found [1025:0129]
[ 9.924549] yenta_cardbus 0000:0a:06.0: Enabling burst memory read transactions
[ 9.924554] yenta_cardbus 0000:0a:06.0: Using CSCINT to route CSC interrupts to PCI
[ 9.924556] yenta_cardbus 0000:0a:06.0: Routing CardBus interrupts to PCI
[ 9.924561] yenta_cardbus 0000:0a:06.0: TI: mfunc 0x01a61b22, devctl 0x66
[ 9.934146] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/sound/card0/input14
[ 9.934581] input: HDA Intel Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input15
[ 9.934638] input: HDA Intel Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input16
[ 9.934695] input: HDA Intel Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input17
[ 9.998963] ACPI Warning: SystemIO range 0x0000000000001028-0x000000000000102F conflicts with OpRegion 0x0000000000001000-0x000000000000107F (\PMIO) (20160831/utaddress-247)
[ 9.998971] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 9.998975] ACPI Warning: SystemIO range 0x00000000000011B0-0x00000000000011BF conflicts with OpRegion 0x0000000000001180-0x00000000000011BB (\GPIO) (20160831/utaddress-247)
[ 9.998980] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 9.998981] ACPI Warning: SystemIO range 0x0000000000001180-0x00000000000011AF conflicts with OpRegion 0x0000000000001180-0x00000000000011BB (\GPIO) (20160831/utaddress-247)
[ 9.998985] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 9.998986] lpc_ich: Resource conflict(s) found affecting gpio_ich
[ 10.003590] ite_cir: Auto-detected model: ITE8709 CIR transceiver
[ 10.003592] ite_cir: Using model: ITE8709 CIR transceiver
[ 10.003594] ite_cir: TX-capable: 1
[ 10.003595] ite_cir: Sample period (ns): 8680
[ 10.003596] ite_cir: TX carrier frequency (Hz): 38000
[ 10.003597] ite_cir: TX duty cycle (%): 33
[ 10.003598] ite_cir: RX low carrier frequency (Hz): 0
[ 10.003599] ite_cir: RX high carrier frequency (Hz): 0
[ 10.011637] media: Linux media interface: v0.10
[ 10.044140] Linux video capture interface: v2.00
[ 10.079161] usb 3-2: dvb_usb_v2: found a 'AVerMedia A310 USB 2.0 DVB-T tuner' in warm state
[ 10.079947] sr 0:0:1:0: Attached scsi generic sg0 type 5
[ 10.080663] sd 2:0:0:0: Attached scsi generic sg1 type 0
[ 10.086557] usb 3-2: dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
[ 10.086584] DVB: registering new adapter (AVerMedia A310 USB 2.0 DVB-T tuner)
[ 10.097123] ACPI: Battery Slot [BAT0] (battery present)
[ 10.124059] Registered IR keymap rc-rc6-mce
[ 10.124181] input: ITE8709 CIR transceiver as /devices/virtual/rc/rc0/input18
[ 10.140981] usb 3-2: DVB: registering adapter 0 frontend 0 (Zarlink ZL10353 DVB-T)...
[ 10.157483] rc rc0: ITE8709 CIR transceiver as /devices/virtual/rc/rc0
[ 10.236722] yenta_cardbus 0000:0a:06.0: ISA IRQ mask 0x0c78, PCI irq 21
[ 10.236726] yenta_cardbus 0000:0a:06.0: Socket status: 30000006
[ 10.236730] pci_bus 0000:0a: Raising subordinate bus# of parent bus (#0a) from #0b to #0e
[ 10.236736] yenta_cardbus 0000:0a:06.0: pcmcia: parent PCI bridge window: [io 0x7000-0x7fff]
[ 10.236739] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x7000-0x7fff:
[ 10.238081] excluding 0x7000-0x70ff 0x7400-0x74ff
[ 10.244650] yenta_cardbus 0000:0a:06.0: pcmcia: parent PCI bridge window: [mem 0xfc000000-0xfc0fffff]
[ 10.244653] pcmcia_socket pcmcia_socket0: cs: memory probe 0xfc000000-0xfc0fffff:
[ 10.244657] excluding 0xfc000000-0xfc00ffff
[ 10.245087] tifm_7xx1 0000:0a:06.2: enabling device (0000 -> 0002)
[ 10.246422] lirc_dev: IR Remote Control driver registered, major 244
[ 10.246660] IR RC6 protocol handler initialized
[ 10.257052] rc rc0: lirc_dev: driver ir-lirc-codec (ite-cir) registered at minor = 0
[ 10.257055] IR LIRC bridge handler initialized
[ 10.272158] ite_cir: driver has been successfully loaded
[ 10.301084] MXL5005S: Attached at address 0xc6
[ 10.301395] usb 3-2: dvb_usb_v2: 'AVerMedia A310 USB 2.0 DVB-T tuner' successfully initialized and connected
[ 10.301422] usbcore: registered new interface driver dvb_usb_ce6230
[ 10.308233] uvcvideo: Found UVC 1.00 device Acer CrystalEye webcam (064e:a101)
[ 10.310743] uvcvideo 5-6:1.0: Entity type for entity Extension 4 was not initialized!
[ 10.310748] uvcvideo 5-6:1.0: Entity type for entity Processing 3 was not initialized!
[ 10.310751] uvcvideo 5-6:1.0: Entity type for entity Camera 1 was not initialized!
[ 10.310903] input: Acer CrystalEye webcam as /devices/pci0000:00/0000:00:1d.7/usb5/5-6/5-6:1.0/input/input19
[ 10.310941] usbcore: registered new interface driver uvcvideo
[ 10.310942] USB Video Class driver (1.1.1)
[ 10.428293] nouveau 0000:01:00.0: NVIDIA G84 (084700a2)
[ 10.548746] nouveau 0000:01:00.0: bios: version 60.84.62.00.39
[ 10.570364] nouveau 0000:01:00.0: bios: M0203T not found
[ 10.570366] nouveau 0000:01:00.0: bios: M0203E not matched!
[ 10.570369] nouveau 0000:01:00.0: fb: 256 MiB DDR2
[ 10.619592] [TTM] Zone kernel: Available graphics memory: 439372 kiB
[ 10.619594] [TTM] Zone highmem: Available graphics memory: 1031664 kiB
[ 10.619595] [TTM] Initializing pool allocator
[ 10.619603] [TTM] Initializing DMA pool allocator
[ 10.619626] nouveau 0000:01:00.0: DRM: VRAM: 256 MiB
[ 10.619628] nouveau 0000:01:00.0: DRM: GART: 1048576 MiB
[ 10.619633] nouveau 0000:01:00.0: DRM: TMDS table version 2.0
[ 10.619635] nouveau 0000:01:00.0: DRM: DCB version 4.0
[ 10.619638] nouveau 0000:01:00.0: DRM: DCB outp 00: 01000323 00000035
[ 10.619641] nouveau 0000:01:00.0: DRM: DCB outp 01: 02011300 00000028
[ 10.619643] nouveau 0000:01:00.0: DRM: DCB outp 02: 02022312 00000010
[ 10.619645] nouveau 0000:01:00.0: DRM: DCB outp 03: 010333f1 00c0c080
[ 10.619647] nouveau 0000:01:00.0: DRM: DCB conn 00: 0040
[ 10.619649] nouveau 0000:01:00.0: DRM: DCB conn 01: 0100
[ 10.619651] nouveau 0000:01:00.0: DRM: DCB conn 02: 1231
[ 10.619653] nouveau 0000:01:00.0: DRM: DCB conn 03: 0310
[ 10.619654] nouveau 0000:01:00.0: DRM: DCB conn 04: 0311
[ 10.619659] nouveau 0000:01:00.0: DRM: BIOS FP mode: 1680x1050 (151000kHz pixel clock)
[ 10.684449] nouveau 0000:01:00.0: DRM: failed to create encoder 0/1/0: -19
[ 10.684452] nouveau 0000:01:00.0: DRM: TV-1 has no encoders, removing
[ 10.684496] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 10.684497] [drm] Driver supports precise vblank timestamp query.
[ 10.725039] input: PC Speaker as /devices/platform/pcspkr/input/input20
[ 10.762321] nouveau 0000:01:00.0: DRM: MM: using CRYPT for buffer copies
[ 11.188529] iTCO_vendor_support: vendor-support=0
[ 11.191584] acer_wmi: Acer Laptop ACPI-WMI Extras
[ 11.191737] acer_wmi: Function bitmap for Communication Device: 0x17
[ 11.353768] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[ 11.353808] iTCO_wdt: Found a ICH8M TCO device (Version=2, TCOBASE=0x1060)
[ 11.354164] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 11.398611] intel_powerclamp: No package C-state available
[ 11.438519] iwl4965: Intel(R) Wireless WiFi 4965 driver for Linux, in-tree:
[ 11.438521] iwl4965: Copyright(c) 2003-2011 Intel Corporation
[ 11.438580] iwl4965 0000:08:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 11.438773] iwl4965 0000:08:00.0: Detected Intel(R) Wireless WiFi Link 4965AGN, REV=0x4
[ 11.482163] iwl4965 0000:08:00.0: device EEPROM VER=0x36, CALIB=0x5
[ 11.482180] iwl4965 0000:08:00.0: Tunable channels: 13 802.11bg, 19 802.11a channels
[ 11.533900] iwl4965 0000:08:00.0: firmware: direct-loading firmware iwlwifi-4965-2.ucode
[ 11.533907] iwl4965 0000:08:00.0: loaded firmware version 228.61.2.24
[ 11.836042] usb 7-1: new full-speed USB device number 2 using uhci_hcd
[ 11.886050] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x100-0x3af:
[ 11.886922] excluding 0x170-0x177 0x1f0-0x277 0x370-0x37f
[ 11.887514] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x3e0-0x4ff:
[ 11.887883] excluding 0x3f0-0x407 0x4d0-0x4d7
[ 11.888261] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x820-0x8ff:
[ 11.888850] clean
[ 11.888869] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xc00-0xcf7:
[ 11.889536] clean
[ 11.889561] pcmcia_socket pcmcia_socket0: cs: memory probe 0x0c0000-0x0fffff:
[ 11.889568] excluding 0xc0000-0xcffff 0xe4000-0xfffff
[ 11.889602] pcmcia_socket pcmcia_socket0: cs: memory probe 0xa0000000-0xa0ffffff:
[ 11.889625] clean
[ 11.889643] pcmcia_socket pcmcia_socket0: cs: memory probe 0x60000000-0x60ffffff:
[ 11.889659] excluding 0x60000000-0x60ffffff
[ 11.889681] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xa00-0xaff:
[ 11.890354] clean
[ 11.917571] nouveau 0000:01:00.0: DRM: allocated 1680x1050 fb: 0x50000, bo f638b400
[ 11.917670] fbcon: nouveaufb (fb0) is primary device
[ 12.019066] usb 7-1: New USB device found, idVendor=0a5c, idProduct=2101
[ 12.019069] usb 7-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 12.019070] usb 7-1: Product: Acer Module
[ 12.019071] usb 7-1: Manufacturer: Broadcom Corp
[ 12.022470] Console: switching to colour frame buffer device 210x65
[ 12.027048] nouveau 0000:01:00.0: fb0: nouveaufb frame buffer device
[ 12.040071] [drm] Initialized nouveau 1.3.1 20120801 for 0000:01:00.0 on minor 0
[ 12.203182] ieee80211 phy0: Selected rate control algorithm 'iwl-4965-rs'
[ 12.308230] Adding 2093052k swap on /dev/sda5. Priority:-1 extents:1 across:2093052k FS
[ 16.664578] iwl4965 0000:08:00.0: RF_KILL bit toggled to enable radio.
[ 16.664581] iwl4965 0000:08:00.0: On demand firmware reload
[ 16.664623] ieee80211 phy0: Hardware restart was requested
[ 16.819790] iwl4965 0000:08:00.0 wlp8s0: renamed from wlan0
[ 17.535042] Bluetooth: Core ver 2.22
[ 17.535076] NET: Registered protocol family 31
[ 17.535078] Bluetooth: HCI device and connection manager initialized
[ 17.535083] Bluetooth: HCI socket layer initialized
[ 17.535087] Bluetooth: L2CAP socket layer initialized
[ 17.535098] Bluetooth: SCO socket layer initialized
[ 17.702987] usbcore: registered new interface driver btusb
[ 19.960099] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 19.960101] Bluetooth: BNEP filters: protocol multicast
[ 19.960106] Bluetooth: BNEP socket layer initialized
[ 24.214479] IPv6: ADDRCONF(NETDEV_UP): enp2s0: link is not ready
[ 24.264358] IPv6: ADDRCONF(NETDEV_UP): enp2s0: link is not ready
[ 24.285310] IPv6: ADDRCONF(NETDEV_UP): wlp8s0: link is not ready
[ 24.534834] IPv6: ADDRCONF(NETDEV_UP): wlp8s0: link is not ready
[ 24.841962] IPv6: ADDRCONF(NETDEV_UP): wlp8s0: link is not ready
[ 25.899902] IPv6: ADDRCONF(NETDEV_UP): wlp8s0: link is not ready
[ 41.506881] IPv6: ADDRCONF(NETDEV_UP): wlp8s0: link is not ready
[ 43.797265] wlp8s0: authenticate with 18:d6:c7:de:f0:0c
[ 43.813284] wlp8s0: send auth to 18:d6:c7:de:f0:0c (try 1/3)
[ 43.814983] wlp8s0: authenticated
[ 43.816037] wlp8s0: associate with 18:d6:c7:de:f0:0c (try 1/3)
[ 43.826495] wlp8s0: RX AssocResp from 18:d6:c7:de:f0:0c (capab=0x411 status=0 aid=1)
[ 43.852947] wlp8s0: associated
[ 43.853018] IPv6: ADDRCONF(NETDEV_CHANGE): wlp8s0: link becomes ready
[ 212.002937] tg3 0000:02:00.0 enp2s0: Link is up at 100 Mbps, full duplex
[ 212.002940] tg3 0000:02:00.0 enp2s0: Flow control is on for TX and on for RX
[ 212.003644] IPv6: ADDRCONF(NETDEV_CHANGE): enp2s0: link becomes ready
[ 315.313307] perf: interrupt took too long (2505 > 2500), lowering kernel.perf_event_max_sample_rate to 79750
[ 344.918329] perf: interrupt took too long (3141 > 3131), lowering kernel.perf_event_max_sample_rate to 63500
[ 393.773090] perf: interrupt took too long (3929 > 3926), lowering kernel.perf_event_max_sample_rate to 50750
[ 493.338243] perf: interrupt took too long (4923 > 4911), lowering kernel.perf_event_max_sample_rate to 40500
