Ok so I have it setup in terms of hardware. parallel port is on 14f2:0121. The spindle turns via its controller but despite running setpconf I have no movement.
The controller is a 3/4axis jb3163 type Ive tried two configs.
2=x step
3=xdir
4= y step
5 = y dir
6 = z step
7 = z dir
No movement.
The other way is I can import a mach.ini? if anyone has the same hardware?
**edit**
Ok Ive got a little further, I re-did the stepconf but didnt change a single thing and now when I go to test the axis I can here a small "thunk" from X and y steppers. Not for Z, that sounds like a relay is closing when I try and move. Hmmm so my noob opinion is I think the parallel card is detected OK and it sounds like something is happening so its down to I have the wrong pinouts?
***edit2***
Have case off, I have one lit red LED next to the parallel port and 8 green LEDs. first 6 = lit right to left X-pu, X-dr, Y-pu, y-dr z-pu, z-dr these are lit Green 7 is unknown and unit. When I toggle the em stop in Linux cnc green led 8 toggles also.
I can toggle the X and Y dr leds Ok while in test the axis. Hmm something needs enabling? something inverting?
