clock
- deslee848
09 Mar 2019 03:11 #128127
by deslee848
clock was created by deslee848
hello guys,at first place i install Lcnc,but didnt care about the clock and date.so in Lcnc where can adjust the clock and date. thanks
- ant0ny
- Thank you received: 4
09 Mar 2019 05:52 #128131
by ant0ny
Replied by ant0ny on topic clock
I had same issue and was surprised it wasn't as straight forward as I thought.
wiki.debian.org/TimeZoneChanges
First I tried this wiki which didn't actually work for my first few installs... I was trying different setups and video cards etc.
After not getting it to work I installed NTP which fixed the issue. You may need to set the "local sources" as per the instructions.
wiki.debian.org/DateTime
Irony was after all that I did a final install but did the text based install instead of the gui install and it worked first go without any extra fix after install.
The following user(s) said Thank You: deslee848
- pl7i92
- Thank you received: 358
09 Mar 2019 08:16 #128135
by pl7i92
Replied by pl7i92 on topic clock
can be adchived easy in a side panel
by XML
and in the postgui HAL
by XML
<hbox>
<label>
<text>"Cycle Time"</text>
<font>("Helvetica",14)</font>
</label>
<u32>
<halpin>"time-hours"</halpin>
<format>"2d"</format>
</u32>
<label>
<text>":"</text>
</label>
<u32>
<halpin>"time-minutes"</halpin>
</u32>
<label>
<text>":"</text>
</label>
<u32>
<halpin>"time-seconds"</halpin>
</u32>
</hbox>and in the postgui HAL
loadrt time
addf time.0 servo-thread
net prog-running not.1.in <= halui.program.is-idle
net cycle-timer time.0.start <= not.1.out
net cycle-seconds pyvcp.time-seconds <= time.0.seconds
net cycle-minutes pyvcp.time-minutes <= time.0.minutes
net cycle-hours pyvcp.time-hours <= time.0.hours
Time to create page: 0.162 seconds
