Linuxcnc always wants to update my INI file
- DC67
09 Jan 2020 07:46 #154413
by DC67
Replied by DC67 on topic Linuxcnc always wants to update my INI file
Hello
Not until now. I'm still looking for a solution.
- Thank you received: 4652
09 Jan 2020 20:22 #154480
Replied by andypugh on topic Linuxcnc always wants to update my INI file
What happens if you allow LinuxCNC to update the INI file?
- DC67
10 Jan 2020 08:40 - 10 Jan 2020 08:41 #154531
by DC67
if i try to update i get an error.
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.8.0-pre1-5304-gc20f7ed38
Machine configuration directory is '/home/linuxcnc/linuxcnc/configs/Fenja'
Machine configuration file is 'Fenja.ini'
INIFILE=/home/linuxcnc/linuxcnc/configs/Fenja/Fenja.ini
VERSION=
halfiles =
halpaths =
update script failed in an unexpected way.
Debug file information:
Can not find -sec EMC -var VERSION -num 1
File "/usr/bin/update_ini", line 197, in <module>
all_sections.remove("EMC")
ValueError: list.remove(x): x not in list
Date: Fr 10. Jan 09:26:12 CET 2020
UTC Date: Fr 10. Jan 08:26:12 UTC 2020
this program: /usr/bin/linuxcnc_info
uptime: 09:26:12 up 2 min, 1 user, load average: 0,91, 0,66, 0,27
lsb_release -sa: Debian Debian GNU/Linux 9.11 (stretch) 9.11 stretch
which linuxcnc: /usr/bin/linuxcnc
uname items:
nodename -n: linuxcnc-fraese
kernel-name -s: Linux
kernel-vers -v: #1 SMP PREEMPT RT Debian 4.9.189-3+deb9u2 (2019-11-11)
machine -m: x86_64
processor -p: unknown
platform -i: unknown
oper system -o: GNU/Linux
/proc items:
cmdline: BOOT_IMAGE=/boot/vmlinuz-4.9.0-11-rt-amd64 root=UUID=d181fc0c-5f1c-4a2e-a0e1-6cfc77e43d12 ro quiet isolcpus=1,2,3
model name: Intel(R) Celeron(R) CPU J1900 @ 1.99GHz
cores: 4
cpu MHz: 1999.200
parport:
serial:
Versions:
gcc: gcc (Debian 6.3.0-18+deb9u1) 6.3.0 20170516
python: Python 2.7.13
git: git version 2.11.0
git commit: NA
tcl: 8.6
tk: 8.6
glade: glade 3.20.0
glade-gtk2: not_in_PATH
linuxcnc_var all:
LINUXCNCVERSION: 2.8.0-pre1-5304-gc20f7ed38
LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp
LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples
REALTIME: /etc/init.d/realtime
RTS: uspace
HALLIB_DIR: /usr/share/linuxcnc/hallib
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
VERSION=
halfiles =
halpaths =
uname items:
machine -m: x86_64
/proc items:
cores: 4
cpu MHz: 1999.200
parport:
serial:
Versions:
git commit: NA
tcl: 8.6
tk: 8.6
glade: glade 3.20.0
linuxcnc_var all:
RTS: uspace
Last edit: 10 Jan 2020 08:41 by DC67.
10 Jan 2020 12:37 #154543
Interesting. Does your INI file have an [EMC] section?
(I wrote the update_Ini script, and it looks like you have found a bug in it)
Can you attach the current INI and also the oldest one in the "old" directory of the same config directory?
- DC67
11 Jan 2020 07:53 - 11 Jan 2020 08:04 #154597
by DC67
Here are my ini files
this is may the same as current
this is where i upgraded from.I had moved the old folder v2.7 so that it would not be overwritten or deleted.
This EMC error started when adding probe/toolsensor to the INI .Before i could start linuxcnc without any message for update.
Last edit: 11 Jan 2020 08:04 by DC67.
11 Jan 2020 16:08 #154625
Backtracking a bit:
How are you starting LinuxCNC? This looks a bit like you are starting LinuxCNC in such a way that it is looking at an INI file called "Fenja.ini" and that is not containing any of the expected sections.
If you pick your "current.ini" from the LinuxCNC config picker, do things work better?
VERSION=
halfiles =
halpaths =
Can not find -sec EMC -var VERSION -num 1How are you starting LinuxCNC? This looks a bit like you are starting LinuxCNC in such a way that it is looking at an INI file called "Fenja.ini" and that is not containing any of the expected sections.
- DC67
11 Jan 2020 20:18 #154637
by DC67
Hi
sorry for confusion.
I changed the ini name so that you can see which version is current and which is older. but all are called fenja.ini in the current system
11 Jan 2020 21:21 #154641
I guessed that the file names were changed. (That’s why I put the substitute file name in quotes).
But whatever file is being run, LinuxCNC is not finding a version or any Hal files.
So something odd seems to be going on.
Are you starting LinuxCNC from the config picker or some other way?
- DC67
11 Jan 2020 22:16 #154643
by DC67
I start linuxcnc via a desktop shortcut that starts directly with fenja.ini
11 Jan 2020 22:40 #154648
Can you try it the other way?
