7i76 spindle out wiring
7 years 1 week ago #148423 by Ross77
Replied by Ross77 on topic 7i76 spindle out wiring
Looks like there is a problem as the sprint manual has the 10v output rated at 10maA max so should be plenty.
I also cant get the Spindle enable to work either so could be a problem with the 7i76.
Looking at the sprint manual there is a trim pot in the low side which might need to be adjusted. there is also a direct spped input on pin 66 which may be a better option
Can I test the 7i76 output by hooking up a separate 10v feed and check the output ?
Your browser does not support embedded PDFs. Please download the file here: Download PDF.
7 years 1 week ago #148425 by PCW
Replied by PCW on topic 7i76 spindle out wiring
Yes, you can use a separate supply to test the 7I76 analog output
(and an ohmmeter to test the enable output)
It does look like you should connect 7I76 SPIN- to Drive COM = pin 4
not Drive MIN = pin2
The MIN pot resistance is likely the reason you only got 2.7V
7 years 1 week ago #148426 by Ross77
Thanks for the quick response, that's a great help.
Just seen another post saying the same thing so hopefully that's all that's wrong.
What values should I see as normal operation?
7 years 1 week ago #148432 by PCW
Some resistance for "on" and infinite resistance for "off"
Sometimes the diode test selection works better as a continuity tester
The following user(s) said Thank You: Ross77
7 years 1 week ago #148499 by Ross77
Main problem is solved so Thanks for the advice. Worked perfect when Spin - was connected to a com rather than the min output on the sprint 400.
I'm still having trouble with Spin enable and direction. I tested the resistance and it did change but not very much 4meg to 2 meg.
To get the mill working I have set one of the outputs for spindle cw and using that to trigger the spindle relay. As long as I don't run out of I/O I should be ok.
7 years 1 week ago #148541 by PCW
Changing from 2 to 4M is probably OK
(the "on" voltage of the OPTOs is high enough that they will never read a
low resistance on most meters)
The OPTOs are basically switches so its good to test your hardware with a mechanical
switch first, If a mechanical switch works, the OPTOs should as well
Time to create page: 0.211 seconds
