7i76 spindle out wiring
7 years 1 week ago - 7 years 1 week ago #148243 by bevins
Replied by bevins on topic 7i76 spindle out wiring
When the spindle is not suppose to be running, you need to remove the run signal. Close it when you get an M3,
Without the run signal, it should not spin.
motion.spindle-forward ===> output (run contact on VFD)
Last edit: 7 years 1 week ago by bevins.
7 years 1 week ago #148250 by Ross77
Replied by Ross77 on topic 7i76 spindle out wiring
Hal and ini files ?
And do double check the wiring, that does not seem right, it should work properly as per the above wiring explanation.
The machine is at the workshop so will have to check tomorrow. thanks
I did think that but I'm sure I should be able to have the spindle running slowly. at the moment it seems to be a minimum of 1000rpm
7 years 1 week ago #148253 by bevins
Are the two commons attached?
7 years 1 week ago #148261 by PCW
Replied by PCW on topic 7i76 spindle out wiring
You may need to supply an isolated 10 or 12V since it looks like the spindle control
cannot supply the ~5 mA that the 7I76 analog out circuitry needs.
Note the _isolated_ make sure the supply is isolated (no PC supplies etc)
7 years 1 week ago #148348 by Ross77
I'm confused now because I thought the isolated spindle output on the 7i76 was to be able to interface with non isolated drives.
Would this be suitable? uk.rs-online.com/web/p/isolated-dc-dc-converters/1874585/
7 years 1 week ago #148350 by PCW
It can interface with non-isolated drives but the drive must supply about
5mA for the digital potentiometer circuitry.
That 12V DC-DC converter should work (with possible scale changes in the ini file to adjust for the 12V full scale output)
Time to create page: 0.380 seconds
