X Axis Travel Accuracy
7 years 18 hours ago #149349 by Leon82
Replied by Leon82 on topic X Axis Travel Accuracy
Does your setup allow you to adjust the pinion depth?
You could probably tighten it up a little. But too tight will accelerate wear also.
7 years 7 hours ago #149398 by Jason Arnold
Replied by Jason Arnold on topic X Axis Travel Accuracy
Hi Leon,
The Rack and Pinion system does use a preload spring to pull the pinion against the rack.
I'll pull one of the pinions off the machine today and post some pictures of the wear. I guess it's better to wear the pinion than the rack. ;-)
Cheers,
Jason.
The following user(s) said Thank You: Leon82
7 years 6 hours ago #149400 by Leon82
Jason Arnold wrote: Hi Leon,
Cheers,
Jason.
Yes better to replace a small gear vs a 4ft+ track.
It may be considered a "wear" item or maybe try some type of grease lubricant. If they are cheap enough it may be worthwhile to try a new one and check it with the indicator
7 years 6 hours ago #149401 by Jason Arnold
Yeah I think they do consider it a wear item. I was thinking that a dry lubricant might be helpful. Normal grease would probably catch too much dust and crap causing other problems.
Cheers,
Jason.
6 years 11 months ago #149443 by Jason Arnold
Here are some pictures of the R&P setup and the wear on the pinion.
The wear seems to be concentrated on one side of the tooth. I’ll check the other side of the gantry too. Maybe the pulleys can be swapped side to side to alleviate some of the wear.
Cheers,
Jason.
6 years 11 months ago #149445 by Leon82
Do you climb cut or conventional cut.
Conventional cutting will always be pushing back on the tooth.
Climb cutting the forces will accelerate the gantry with the rotation of the tool.or even possibly make it rattle back and forth if it's really loose
Time to create page: 0.143 seconds
