G76 z axis stuttering
- Resinrocket
30 Nov 2019 16:18 #151582
by Resinrocket
G76 z axis stuttering was created by Resinrocket
Hello All
I am having a problem with G76 threading.
My lathe is a converted manual machine with no speed control (only belt changes).
I have a single hall pickup connected to phase a and index, which seems to work ok.
The problem I have is that the Z axis is moving in discreet steps once per revolution. Start, stop, start, stop etc.
The overall pitch is still correct but the feed is not constant.
What could be the cause.
Many thanks.
Adrian.
Many thanks.
Adrian.
- skunkworks
- Thank you received: 153
30 Nov 2019 16:50 #151586
by skunkworks
Replied by skunkworks on topic G76 z axis stuttering
Is this a printer port setup? Using the software encoder?
Use encoder.N.position−interpolated instead of encoder.N.position when hooking it to motion.spindle−revs...
linuxcnc.org/docs/html/man/man9/encoder.9.html
- Resinrocket
30 Nov 2019 20:25 #151602
by Resinrocket
Replied by Resinrocket on topic G76 z axis stuttering
Hello Skunkworks
Not only were you able to guess what setup I am using but nail the solution first time.
Probably really simple to most but not to me.
Many thanks, works like a dream now.
Adrian.
Adrian.
- skunkworks
03 Dec 2019 03:58 #151813
by skunkworks
Yay!!! (even a broken clock is right twice a day....)
