Hi Len, My project is a CNC retrofit for my bridgeport style knee mill using the Kollmorgen drives, motors and cables that were left over from a previous project from …well…nearly 20 years ago. On the linux cnc side of things I’m using a intel atom single board motherboard, mesa 5i25 with 7i77 (analog). My goal is to mimic a Trak mill from Southwest industries, those mills are the best in-between mills I’ve ever used mostly because they still have handles and dials on them so you can quickly use them for dirt simple things without any programing hassles but can also run programs and even 3-axis cnc machining. It took a lot of time to design and build a motor and timing belt interface so that I can keep the dials and handles, well different handles that is.
The Kollmorgen motors and drives I have are resolver based but the drives came equipped with an encoder equivalent output on C4 that is connected to the 7i77 encoder input. the resolver from the motor go to C2 on the drive. It seems to work fine near as I can tell so long as the parmeters in the drive are set right and the encoder scaling is correct in Pncconfig. The mill is in one location and the computer and panel with a single motor and drive are at home where I can work on it in relative peace and comfort. I verified the resolver to encoder equivalent counts and timing belt-leadscrew ratio on the x-axis prior to having linuxcnc fully configured using the Motion link software.
Man, I wish there was a Kollmorgen forum similar to the wonderful forum here at Linux CNC. Although I was deeply involved with the these motors and drives before, that was twenty years ago! Fortunately I still have the laptop from back then with a functioning serial port. I’ve not been able to get the USB to RS-232 cable & driver to work with my current laptop, I can see it transmitting but the drive never replies back. The old laptop running windows 2000 and Motionlink from that time period works just fine. I have found almost nothing to help with using motion link, takes a lot of time to muddle through it. I hit the estop/disable button a lot. To enable the drive I wired my estop using the normally closed side in-between pin 8 on C3 and -24V on the PS. +24V to pin 7 on C3. This weekend I’m working on getting the drives and PC next to the mill and start routing the cables and limit switch wires.
Here’s the Link to the Servo Star CD repository.
www.kollmorgen.com/en-us/developer-netwo...D=4176&title=&page=1
Good to hear Kollmorgen gave you the time of day when you called in. I expected it to be more of the same “we don’t support that version anymore”.
Your machine is using linear motors. One of the axes I delt with back in the day was a linear type. Man when those things go unstable its BIG deal. The one I had hit the hard stops in both directions a couple of times before I could hit e-stop. To be fair the travel wasn’t all that long.
Doug
