Doug,
Are you controlling the enable with just the Mesa, or are you also adding in any relay logic (as controlled from say an Estop)?
I will be excitedly following your progress as I too am in the middle of wiring up the four Kollmorgen ServoStar CD drives just like yours. I mounted them to the backpanel this evening, and hopefully will have one powered up this weekend.
For the enable, I considered driving it with Estop or just hard wiring it to 24V gnd to always enable and drop out L1/2/3 power with the Estop. Does anyone know if LinuxCNC normally wants to control an enable drive(s) signal?
While I'm not far enough to offer you much advice, I'll add that I came to the same conclusion of using them in velocity mode. My drives should (might) still be in tune as they came on the machine before I got it. I'm hoping I can hook up Motionlink, pull the settings/save & the play with them some before connecting to LinuxCNC. I'll attach one of my Y drive schematics. It's not fleshed completely out, but you may see something useful, or note something that looks like I'm lost. At least it's something that should look familiar to you, and hopefully give you some feedback that you're not alone with the ServoStars.
I'm assuming that you have your encoders wired to C2 (db25) and then are using the C4 (equivalent encoder output) to feed your Mesa card? This is what I have planned, but was wondering if I was on track or not.
Len
