- Thank you received: 26
Speed limitation close to software limit by traj planner
- Nico2017
6 years 9 months ago #155487
by Nico2017
Replied by Nico2017 on topic Speed limitation close to software limit by traj planner
Hi all,
regarding this topic,I obverse a different behaviour regarding if the motor is homed or not.
If it is homed, the axis min position limits the motion. If it is not homed, the joint min position does not seem to be effective.
Any idea why?
Thank you,
Nicolas
Any idea why?
Thank you,
Nicolas
- Thank you received: 7491
6 years 9 months ago #155578
Replied by tommylight on topic Speed limitation close to software limit by traj planner
That is normal.
The machine should not be used without being homed first.
The following user(s) said Thank You: Nico2017
- Nico2017
6 years 9 months ago #155581
by Nico2017
ok, that sounds perfectly normal. I am just wondering then why do you define min and max limit for the joints in the ini file?
Is it if the hard limit switch is triggered to get a value for the machine position, or is it for display reason of the machine limits in gremlin or axis?
Thank you,
Nicolas
Thank you,
Nicolas
- Leon82
- Thank you received: 79
6 years 9 months ago #155589
by Leon82
Replied by Leon82 on topic Speed limitation close to software limit by traj planner
The hard limits are to prevent machine damage from a faulty encoder or a large amount of lost steps or slippage of the coupling.
Ideally you would set them a little after home and min limit.
so in a perfect world you will never hit your hard limit switches only software limit
- Thank you received: 2181
6 years 9 months ago #155590
Replied by cmorley on topic Speed limitation close to software limit by traj planner
Because in some machines say robots, you can move the joints individually after homing, so they need limits of their own.
Chris
Chris
- phillc54
- Thank you received: 2100
6 years 9 months ago #155601
by phillc54
Replied by phillc54 on topic Speed limitation close to software limit by traj planner
AFAIK these definitions are used to set the soft limits after the machine has been homed.Nico2017 wrote: Hi,
Thank you,
Nicolas
Time to create page: 2.982 seconds
