Homing continues to baffle us
- CFE
- Thank you received: 35
07 May 2020 01:07 #166916
by CFE
Homing continues to baffle us was created by CFE
Hi all,
Once again we are getting caught out in mysterious ways by the Stepconf wizard and LinuxCNC. We got our plasma cutter up and running with PlasmaC/Gmoccapy (by the way, PlasmaC THC works like a charm !). So we thought we set up our home/limit switches and we would be looking pretty good. I ran the Stepconf wizard on a test configuration to get the INI and Hal file entries right, so I plucked the relevant lines from the generated INI and Hal file and pasted them in the configuration we are using.
To be sure I commented out the lines in the Hal file that connect the home/limit switches to the X- and Z-axis, with the idea to test the homing on the Y-axis first. But straight away I got a joint limit switch error, although in HAL Show I see the switch and it's associated HAL pins are not tripped yet. When I comment out the 3 lines in HAL with 'net both-home-y => ......' then the software starts and I can commence homing on Y, but of course it doesn't find the switch because the relevant pins are not connected. What's going wrong here ? Is the name of the Hal pin wrong, e.g. is joint.2.home-sw-in (or the other 2 related entries) wrong ? Or is it something in the INI file related to the Y-axis ?
I think part of the problem for us is that I can't find a decent description of halpins anywhere, the man pages are a bit difficult to decipher. I have tried different values and combinations in the INI file for all homing related entries, but to no avail. So I am leaning toward the thought that there is something is not quite right in the Hal file, but what ?
Cheers, Peter
Cheers, Peter
- Thank you received: 2175
07 May 2020 02:04 #166923
Replied by cmorley on topic Homing continues to baffle us
Can you post the actual error message?
- phillc54
- Thank you received: 2100
07 May 2020 10:21 #166951
by phillc54
Replied by phillc54 on topic Homing continues to baffle us
You will need values in the ini file for the three HOME_XXX_VELOCITY parameters.
- Thank you received: 7468
07 May 2020 10:36 #166953
Replied by tommylight on topic Homing continues to baffle us
HOME_SEARCH_VEL = 0
That is in your ini, one of the axis has no number after it mind you, so that will make the machine move at 0 velocity while homing, or not move at all.
Time to create page: 0.082 seconds
