Spindle dwell time
- Thank you received: 2175
19 May 2020 14:27 #168272
Replied by cmorley on topic Spindle dwell time
IIRC you connect the sensor to A and index and put the encoder component into counter mode
- TKWard10000
19 May 2020 14:34 #168273
by TKWard10000
Replied by TKWard10000 on topic Spindle dwell time
sorry, I think I miscommunicated.
I have an optical encoder mounted already which gives 1 pulse per rev. ( presume I connect that to the index input ? )
Ideally, I wan to get this ( single pulse optical encoder ) working prior to the proper quadrature encoder arriving and being mounted..... Lots of additional timing pulleys and metal bashing to do to get the quadrature encoder to work, and I would prefer the logic and hal to be somewhat correct first.
I have done a search for encoder spindle pulse ... cant see anything about single index pulse encoders though.
Ideas ?
Ideas ?
19 May 2020 23:56 #168319
as I said you connect the ouput to A and index and put the encoder component into counter mode.
- TKWard10000
20 May 2020 12:31 #168376
by TKWard10000
Ahhh..... I didnt read that properly.
Apologies, and thanks!
