G-Code Newbie Question
  • Project_Hopeless
  • Project_Hopeless's Avatar Topic Author
  • Elite Member
  • Elite Member
10 Jul 2020 16:30 #174234 by Project_Hopeless
Manual Tool Change was created by Project_Hopeless
I have a file created in Fusion 360. I believe my program is stopping on the T1 M6 command, manual tool change? But I'm not getting a message dialog to indicate tool change.
(SPOILBOARD)
(1ST ATTEMP AT SPOIL BOARD)
(T1  D=6.35 CR=0. - ZMIN=-19. - FLAT END MILL)
N10 G90 G94 G17 G91.1
N15 G21
N20 G53 G0 Z0.  <<<<<<<<<<executes this line then stops
(BORE1)
N25 T1 M6
I did not consciously setup for manual tool change. Is there some HAL or INI configuration you have to edit to have manual tool change?
10 Jul 2020 17:42 #174239 by cmorley
Replied by cmorley on topic Manual Tool Change
yes you must configure a manual tool change prompt.
usually by loading and connecting to the hal_manualtoolchange component.
  • Todd Zuercher
  • Todd Zuercher's Avatar
  • Platinum Member
  • Platinum Member
10 Jul 2020 18:23 #174240 by Todd Zuercher
Replied by Todd Zuercher on topic G-Code Newbie Question
Not knowing more about your machine configuration, my guess is that it is actually pausing for the line "N25 T1 M6" which is commanding a tool change to tool #1. If you don't have a tool changer and your config isn't properly configured for not having one, or if you do have a tool changer and your configuration is somehow wrong regarding it, that is what happens. Without seeing your config files or knowing more about your machine, we are only guessing.
  • Moderator
  • Moderator
10 Jul 2020 18:31 #174242 by tommylight
Replied by tommylight on topic G-Code Newbie Question
@Project_Hopeless
No double posting
The other topic with the same content was deleted, Todd's answer moved to this topic.
10 Jul 2020 21:09 #174274 by MaHa
Replied by MaHa on topic G-Code Newbie Question
For manualtoolchange sometimes this solves in hal.
net tool-change iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-changed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
The following user(s) said Thank You: Project_Hopeless
  • Project_Hopeless
  • Elite Member
  • Elite Member
11 Jul 2020 00:43 #174282 by Project_Hopeless
Replied by Project_Hopeless on topic G-Code Newbie Question
Thank-you I will give it a try.
Does it matter where in the HAL file these code lines are placed? This is copied to the main HAL file or postGUI.hal, or other?
  • Moderator
  • Moderator
11 Jul 2020 10:59 #174293 by tommylight
Always at the bottom of the main hal file.
  • Project_Hopeless
  • Elite Member
  • Elite Member
11 Jul 2020 18:31 #174317 by Project_Hopeless
Thank-you all! That worked like a charm.
Time to create page: 0.167 seconds
