Turning: limit rpm
- jsskangas
- Thank you received: 9
23 Jul 2020 07:50 - 23 Jul 2020 07:51 #175473
by jsskangas
Turning: limit rpm was created by jsskangas
Hello
Just got my lathe retrofit running and took first cuts.
Does linuxcnc has G-code to limit max rpm of spindle?
Facing big parts in CSS mode with lathe that has 5000rpm spindle will give give you those brown pants moments....
Last edit: 23 Jul 2020 07:51 by jsskangas.
- jsskangas
23 Jul 2020 08:12 #175475
by jsskangas
Replied by jsskangas on topic Turning: limit rpm
Also tool change is pit unclear to me.
I would like to not to move any tool change position before changing tool.
how to make changes in lathe tool change procedure?
I have my own tool change program , but I want to control / take off any movement before tool change program call.
- Thank you received: 2175
24 Jul 2020 02:53 - 24 Jul 2020 02:53 #175594
Replied by cmorley on topic Turning: limit rpm
g96's d setting limits rpm
linuxcnc.org/docs/2.7/html/gcode/g-code.html#gcode:g96-g97
remove TOOL_CHANGE_POSITION parmeter
linuxcnc.org/docs/2.7/html/config/ini-co....html#_emcio_section
Last edit: 24 Jul 2020 02:53 by cmorley.
The following user(s) said Thank You: jsskangas
- jsskangas
24 Jul 2020 07:37 #175603
by jsskangas
This helped a lot.
This helped a lot.
Time to create page: 0.070 seconds
