General network issue affecting 7i76e connection
6 years 3 months ago #175893 by simonmn
Hello
Yesterday I wanted to make a shared folder in the ncfiles directory, so that my main PC(laptop) with cam on it could save directly onto the machine. Its so nice! Did it on my lathe.
But as soon as I connected the laptop to the machine pc (ethernet via a usb adapter) I became unable to use the 7i76e at all. Linuxcnc reported "Network unreachable", no ping, nothing after reboot of machine pc with and without the laptop connected, or power cycling the 7i76e. Tried what felt like every forum post available to no avail.
Became really frustrated, so left the machine be for the day.
Went out again today with a more clear head. Tried just starting up as normal without the laptop, and boom, it works.
Began testing some different stuff, and made it work with some hoops:
Start the machine with the laptop connected,
go into network manager,
change gateway to 10.10.10.1,
go into the routes and uncheck "use this connection only for resources on its network",
save save save, close the network manager, reopen the network manager again, and undo all of what I just did.
After that, both the 7i76e and the laptop can apparently co-exist.
I'm pretty certain this is a debian issue I have created, and not a linuxcnc, especially then reading: Tommylights post
It sound like a copy paste issue of what tommy is describing in the bottom of his post, but I can't figure out how to fix it.
The 7i76e never came up in the network manager, so it hindered some of the steps for me.
Here is some screen shots I took of the various ip's and etc. I'll be happy to provide more if this isn't useful:
This one is the connection to the laptop (Bærbar)
Hope you guys can help me.
Thank you in advance!
6 years 3 months ago #175902 by tommylight
In the tutorial you linked to there is no mention of editing the interfaces file, yet your interface file is edited, and those two do not work together.
Ultimately you will have to decide if you want to use the method from that tutorial OR the usual method from the docs by editing the interfaces file, not both.
The following user(s) said Thank You: simonmn
6 years 3 months ago #175922 by PCW
You can use the interfaces file and the network manager together,
just not on the same device. If you do this, the device that is setup
in the interfaces file will appears as "unmanaged" in the network manager
The following user(s) said Thank You: tommylight, simonmn
6 years 3 months ago #175937 by tommylight
6 years 3 months ago #176136 by simonmn
Hey again.
Didn´t think about the complications of using both. Just dumped the next potential fix into the corresponding place... not that smart in hindsight :laugh:
Went full interface file, and after some fiddling around, it worked. Thanks Tommy for pointing out the issue!
Here is the new entry for anyone who might use it
# The primary network interface allow-hotplug eth0 <------- don't know if these are necessary, but seems to make it work for me allow-hotplug eth1 auto eth0 iface eth0 inet static address 10.10.10.11 netmask 255.255.255.0 auto eth1 iface eth1 inet static address 192.168.1.12 netmask 255.255.255.0
eth1 worked for me after I removed the gateway. Don't know if this is because I defined it incorrect or if its not needed in direct lan connections. Not too strong in linux other than the basics of basic.
Still have some weird issue with the 7i76e. If I start linuxcnc to quick after boot, it opens but shortly after spits out a bunch of read errors, and seemingly looses connection. This can be fixed by waiting shortly and trying again. Could this be a issue with the hot-plug?
Thanks!
6 years 3 months ago - 6 years 3 months ago #176141 by tommylight
That is usually caused by a slow or failing hard drive.
Or to little memory.
Last edit: 6 years 3 months ago by tommylight. Reason: More info
Time to create page: 0.087 seconds
