Homing Modifications
  • destruction_cereal
  • destruction_cereal's Avatar Topic Author
  • Visitor
  • Visitor
31 Jul 2020 23:30 #176709 by destruction_cereal
Homing Modifications was created by destruction_cereal
In linuxcnc 2.8, is it possible change my homing sequence such that the machine triggers my limit switch multiple times and takes the median of the values to use? I'd be okay if it involved a slight bit of programming on my part.
I currently have a cheap Chinese inductive switch that has about a + 0.0004 home switch on the x axis of my lathe. This is a bit too much for my purposes. I'm honestly hoping for about half of that or less.
If anyone has any better ideas for getting a lower triggering tolerance, I'm all ears.
  • Moderator
  • Moderator
01 Aug 2020 13:28 #176780 by tommylight
Replied by tommylight on topic Homing Modifications
HOME_SEARCH_VEL = -50.000000
HOME_LATCH_VEL = -10
HOME_FINAL_VEL = 30
This is an example of my config, setting those values lower will result in better precision, especially latch velocity.
01 Aug 2020 14:39 - 01 Aug 2020 14:46 #176789 by M Sills
Replied by M Sills on topic Homing Modifications
Those are very similar to the values I have. Mine are slightly lower.
Any thing else I can do besides just buying a new sensor?
As a side note, I ended up making two account on the forums due to issues getting into my email on the pi. How do I delete either this account or destruction_cereal?
Last edit: 01 Aug 2020 14:46 by M Sills.
  • Moderator
  • Moderator
01 Aug 2020 16:33 #176797 by tommylight
Pick one so i can ban the other. At any time you wish to activate it again, you can e-mail moderators even from the banned account.
  • Visitor
  • Visitor
01 Aug 2020 17:24 #176800 by destruction_cereal
Replied by destruction_cereal on topic Homing Modifications
Destruction_cereal is the accountI would like deactivated.
Thank you.
  • Moderator
  • Moderator
01 Aug 2020 17:45 #176802 by tommylight
Done.
Time to create page: 0.217 seconds
