mux 4 not recognized
- jpg
- Thank you received: 13
08 Sep 2020 16:37 - 08 Sep 2020 16:58 #181296
by jpg
mux 4 not recognized was created by jpg
hello, I am new to the forum, but not to linuxcnc, I have been trying to scramble on it for a few months.
(see my video you tube)
at the moment, i can't connect the "mux4" component, it is not recognized, do you have any idea, sorry for the spelling, i'm french
configuration: 2 cards // db 25 + 1 Chinese bob for this example
with the modified "mpg .hal" I can move the pap, but not change the speed
but inside, there is not the "mux4"
Attachment not found
Last edit: 08 Sep 2020 16:58 by jpg.
- Thank you received: 5321
08 Sep 2020 16:57 #181299
Replied by PCW on topic mux 4 not recognized
The error in on line 6 of custom.hal...
- Clive S
- Thank you received: 486
08 Sep 2020 16:59 #181300
by Clive S
Can you post the complete config ,you have not posted the custom.hal
Also have you edited anything in a word processor as that is a no no, always use a text editor like notepad etc.
Replied by Clive S on topic mux 4 not recognized
configuration: 2 cards // db 25 + 1 Chinese bob for this exampleAttachment not found
with the modified "mpg .hal" I can move the pap, but not change the speedAttachment not found
- jpg
08 Sep 2020 17:22 - 08 Sep 2020 17:44 #181304
by jpg
sorry I had erased the custum .hal, I put all my configuration, what I do not understand is that it does not recognize this component (
and I only open the files with the notepad)"mux4" so useful for an MPG, mine will be in 2 axis for lathe
Replied by jpg on topic mux 4 not recognized
Last edit: 08 Sep 2020 17:44 by jpg.
- Thank you received: 2175
08 Sep 2020 18:02 #181309
Replied by cmorley on topic mux 4 not recognized
there can be no spaces between count =
loadrt and2 count=3
loadrt mux4 count=2
loadrt and2 count=3
loadrt mux4 count=2
The following user(s) said Thank You: jpg
- Online
- Thank you received: 7468
08 Sep 2020 20:28 #181317
Replied by tommylight on topic mux 4 not recognized
And if you have to edit Linux files on a windows PC, use Notepad only.
The error says there are windows line endings in the file.
- jpg
08 Sep 2020 21:56 #181326
by jpg
good evening, a big thank you, that was it, I still have to find the entries for the mpg, I have the signals in the halscope
loadrt and2 count=3
loadrt mux4 count=2
- Mike_Eitel
- Thank you received: 183
09 Sep 2020 07:40 #181390
by Mike_Eitel
Replied by Mike_Eitel on topic mux 4 not recognized
On windows it is the best to use notepad++ as editor.
And additionally winscp plus even xrdp (on linux side)
That gives you an easy remote accessed working platform.
You could even run a job, what i personally would never do.
Mike
Mike
Time to create page: 0.266 seconds
