Control spindle with g code
- rotccapt
11 Sep 2020 21:49 #181799
by rotccapt
Control spindle with g code was created by rotccapt
Hello all im having problems getting my spindle to turn on with a M3 command. I can use the button in AXIS to start and stop it but if I issue a midi command for M3 it will not start the spindle. Im using a router motor controlled with a super pid. M5 will turn the spindle off
I have added my hal file. Thank you for any help
- BeagleBrainz
- Visitor
11 Sep 2020 21:52 #181800
by BeagleBrainz
Replied by BeagleBrainz on topic Control spindle with g code
No files have shown up.
Please attach hal & ini files.
- Thank you received: 2175
11 Sep 2020 21:54 #181802
Replied by cmorley on topic Control spindle with g code
did you set a S code with the M code?
m3 s1000
m3 s1000
- rotccapt
11 Sep 2020 22:01 #181803
by rotccapt
Replied by rotccapt on topic Control spindle with g code
No I did not set an s. ill go try that and report back
- rotccapt
11 Sep 2020 22:06 #181805
by rotccapt
I feel really dumb thank you for the help not having an S code was the problem.
11 Sep 2020 22:20 #181807
Don't feel dumb. Linuxcnc should allow you to have them on different lines.
It's a linuxcnc quirk (IFAIC)
Time to create page: 0.081 seconds
