- Configuring LinuxCNC
- Basic Configuration
- Suggestions on Spindle control options? (Analog, Step/Dir, ModBus)
- Hakan
- Thank you received: 454
06 Oct 2020 06:08 #185036
by Hakan
Replied by Hakan on topic Suggestions on Spindle control options? (Analog, Step/Dir, ModBus)
I think you should use Modbus for controlling the spindle. There is a Modbus hal component you can use.
There is no need for super-precise control of the speed, at least normally. Rigid tapping and other synchronized moves don't require a super-precise spindle but they do require encoder output from the spindle and that you have it seems. It is the axis movement, not the spindle movement, that needs to be precise and that is normally the case.
Given that you almost have it working already with Modbus and that there are some issues with step/dir, and that it doesn't matter that much how the spindle is controlled, I would say go for Modbus.
- jhandel
- Thank you received: 7
06 Oct 2020 13:13 #185062
by jhandel
So yes I do have what seems is a very accurate encoder.. So when sync moves are happening its not the spindle that is having its speed modulated its the axis of movement that is having its movement adjusted... If that is the case, then yah, Modbus may be more reliable and take less fiddling given I am having to jump through some hoops to create soft start and soft start logic in the HAL.
Replied by jhandel on topic Suggestions on Spindle control options? (Analog, Step/Dir, ModBus)
- Thank you received: 2164
06 Oct 2020 13:30 #185069
Replied by Aciera on topic Suggestions on Spindle control options? (Analog, Step/Dir, ModBus)
Yes, the axis is moved according to the encoder feedback of the spindle.
- Thank you received: 5321
06 Oct 2020 13:34 #185071
Replied by PCW on topic Suggestions on Spindle control options? (Analog, Step/Dir, ModBus)
One disadvantage of modbus is that the reversal time for rigid tapping is indeterminate
so maybe not a good choice if you are doing blind tapping
- jhandel
06 Oct 2020 23:29 #185163
by jhandel
oh you mean you can't project a stop point/reverse because its not part of the servo thread which could crash the tap into the bottom of the hole PCW?
06 Oct 2020 23:45 #185168
I just mean that if the command to reverse comes from Modbus,
there is no timing guarantee on the PC sending this command
since its not done in real time.
- 0x2102
- Thank you received: 88
09 Oct 2020 22:19 #185516
by 0x2102
Replied by 0x2102 on topic Suggestions on Spindle control options? (Analog, Step/Dir, ModBus)
Here is an example config created by Talla83 (in German) but if you understand HAL, you should be able to adopt it to your system.
This includes M19 (Spindle orient) PID controlled, normal spindle operation via step/dir including ramp up/ramp down.
talla83.homepage.t-online.de/linuxcnc/20181124_Spindel_5i25.zip
As suggested, try not to use ModBus to control the spindle.
