Why does fractional SCALE cause linuxcnc to complain about a version update?
  • JetForMe
  • JetForMe's Avatar Topic Author
  • Elite Member
  • Elite Member
27 Sep 2020 02:30 #183913 by JetForMe
When I set the SCALE of my A-axis (JOINT_4) to 22.222, linuxcnc asks me to confirm autoupdate of my config. If I set it to 22, it runs without complaint.
My other axes have scales of varying fractional values.
I'm noticing this a lot, that certain parameter values make linuxcnc complain about the configuration file version.
File Name: router3_20...9-26.ini
File Size:7 KB
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
27 Sep 2020 02:56 #183917 by BeagleBrainz
Might be best to report this behaviour on the linuxcnc github. You'll probably get a better response from the devs.
  • JetForMe
  • Elite Member
  • Elite Member
27 Sep 2020 03:10 #183920 by JetForMe
The following user(s) said Thank You: BeagleBrainz
  • BeagleBrainz
  • Visitor
  • Visitor
27 Sep 2020 03:20 #183922 by BeagleBrainz
Should get a good response.
27 Sep 2020 09:33 #183953 by tommylight
Are you editing those files on Linux or Windows?
Never had such issues and i do a lot of hal and ini editing.
Will report back if i bump into something similar.
27 Sep 2020 14:02 #183981 by PCW
Sounds like the 2.7 --> 2.8 joints/axis patch script is being run every time
BTW your posted .ini file is corrupt
Time to create page: 0.090 seconds
