- Configuring LinuxCNC
- Basic Configuration
- Help on where to start...Building a CNC Router with a MESA 7i96
- Guywith3006
30 Sep 2020 01:54 #184338
by Guywith3006
Help on where to start...Building a CNC Router with a MESA 7i96 was created by Guywith3006
Thank you in advance for the help, I am just starting with my build (hardware listed below) and have the basic concepts down. I finally got LinuxCNC running (along with Python 3 and Pip3 upgraded). I also have the 7i96 configuration tool downloaded and working. I think I have the basic wiring to the board figured out, but I am struggling to figure how to actually use the 7i96 configuration tool, and then the pnnconf tool. Where can I find out what each value needs to be and what it controls? Any other guidance would be greatly appreciated!
Hardware:
Mesa 7i96
(3) Leadshine DM556 Motor Drivers
20 AMP 48v power supply
(3) Nema 23 425oz steppers
350/650/1050mm supported linear rails and 5/8" ball screws
Spindle will be a Bosch 1617 router
Hardware:
Mesa 7i96
- Thank you received: 4652
02 Oct 2020 11:43 #184566
Replied by andypugh on topic Help on where to start...Building a CNC Router with a MESA 7i96
I think that you use _either_ the 7i96 tool (from Gnipsel / JT?) _or_ PNCConf (and then maybe edit manually for 7i96)
- Thank you received: 5321
02 Oct 2020 16:56 #184583
Replied by PCW on topic Help on where to start...Building a CNC Router with a MESA 7i96
pncconf (in LinuxCNC 2.8 or later) supports the 7I96
- Guywith3006
07 Oct 2020 17:52 #185286
by Guywith3006
Replied by Guywith3006 on topic Help on where to start...Building a CNC Router with a MESA 7i96
Guys,
Thanks for the replies, I have not had a chance to get back on here until now. I see that pncconf supports its, but my problem is at an even more basic level. I am trying to figure out what I need to enter in all the required fields/parameters. Kind of like set up dummies, were can I find the correct specs from my hardware to plug into the software so they pay nice? This is my first CNC project and it has been a while since I played with Linux in general, so I am basically starting from scratch.
