[INPUTS] and [OUTPUTS] section?
- JetForMe
- Thank you received: 27
16 Oct 2020 04:15 #186244
by JetForMe
[INPUTS] and [OUTPUTS] section? was created by JetForMe
In my .ini, which I think was initially generated by the Mesa wizard, are two sections: [INPUTS] and [OUTPUTS]. The comment tells me not to change those, but I've since added some inputs, and think I need to. They look like this:
Are these used by anything? I can't seem to find documentation about them.
[INPUTS]
# DO NOT change the input text
INPUT_0 = Select
INPUT_JOINT_0 = False
INPUT_1 = Select
INPUT_JOINT_1 = False
INPUT_2 = Select
INPUT_JOINT_2 = False
INPUT_3 = Select
INPUT_JOINT_3 = False
INPUT_4 = Select
INPUT_JOINT_4 = False
INPUT_5 = Select
INPUT_JOINT_5 = False
INPUT_6 = Select
INPUT_JOINT_6 = False
INPUT_7 = Select
INPUT_JOINT_7 = False
INPUT_8 = Min Limit & Home
INPUT_JOINT_8 = 0
INPUT_9 = Max Limit
INPUT_JOINT_9 = 0
INPUT_10 = Max Limit & Home
INPUT_JOINT_10 = 1
INPUT_11 = Select
INPUT_JOINT_11 = False
INPUT_12 = Select
INPUT_JOINT_12 = False
INPUT_13 = Select
INPUT_JOINT_13 = False
INPUT_14 = Select
INPUT_JOINT_14 = False
...Are these used by anything? I can't seem to find documentation about them.
- Online
- Thank you received: 7462
24 Oct 2020 21:31 #187138
Replied by tommylight on topic [INPUTS] and [OUTPUTS] section?
Sorry but i have no idea how that got there or what it does inside the ini file.
Bump.
Bump.
- Clive S
- Thank you received: 486
24 Oct 2020 22:05 #187142
by Clive S
If I remember correctly. I think it is from Big John JT wizard for the 7i96 gnipsel.com/linuxcnc/7i96/index.html.
If I am wrong please delete.
Replied by Clive S on topic [INPUTS] and [OUTPUTS] section?
Bump.
- JetForMe
02 Mar 2021 10:20 #200770
by JetForMe
Yeah, I ran that tool. I can't tell if those are used or not.
Replied by JetForMe on topic [INPUTS] and [OUTPUTS] section?
Bump.
Time to create page: 0.221 seconds
