Millright Mega V Controller Change
30 Oct 2020 19:54 #187824 by emoseman
Millright Mega V Controller Change was created by emoseman
I recently purchased a Millright Mega V XL and the GRBL controller that comes with it drops out consistently during jobs so I swapped out the controller with a Mesa 7i96 and I'm trying to use LinuxCNC to control the 7i96 board. I initially used the Pncconf tool to generate the configuration for LinuxCNC. This machine has limit switches installed for the X, Y, and Z axes'. I've been able to get to the point where the machine is now jogging on all axes'. The problem is when I attempt to home the machine in any axis. When I try this I get the errors: "hit limit switch in home state 7" followed by "Joint 0 on limit switch error".
I've tried everything I can think including tracing the logic through the control.c and homing.c (software engineer) and I can't figure out why these errors are being generated.
I've attached my latest ini and hal files.
Any help is greatly appreciated!
Evan
30 Oct 2020 20:04 #187825 by PCW
Replied by PCW on topic Millright Mega V Controller Change
if you have a combined home/limit switch on a joint you need to have
HOME_IGNORE_LIMITS = YES
on that joint
linuxcnc.org/docs/html/config/ini-homing.html
30 Oct 2020 20:13 #187826 by emoseman
Replied by emoseman on topic Millright Mega V Controller Change
If I use that setting on that joint and try to home that axis it just crashes into the side of the machine ignoring the limit switch.
Is there another setting that I need in order to use that limit switch?
30 Oct 2020 20:20 - 30 Oct 2020 20:29 #187827 by PCW
I suspect you didn't tell pncconf that you have shared home/limit switches
(so LinuxCNCs joint home inputs are unconnected in the hal file)
That is:
net x-home-sw => joint.0.home-sw-in
net min-x => joint.0.neg-lim-sw-in
would need to change to
# net x-home-sw => joint.0.home-sw-in
net min-x => joint.0.neg-lim-sw-in joint.0.home-sw-in
etc
Last edit: 30 Oct 2020 20:29 by PCW. Reason: clarify
30 Oct 2020 20:43 #187831 by emoseman
With these changes my machine is finally homing correctly!
I just have to figure out how to reverse the direction of the Y axis according to LinuxCNC and it might actually be working!
30 Oct 2020 21:10 - 30 Oct 2020 22:48 #187836 by Clive S
Replied by Clive S on topic Millright Mega V Controller Change
Have you tried changing STEP_SCALE = -57.288 to 57.228 that should change the motor direction.
But then you would need to change the signs on the homing so they move in the correct direction
Last edit: 30 Oct 2020 22:48 by Clive S.
The following user(s) said Thank You: emoseman
31 Oct 2020 08:43 #187871 by Mike_Eitel
Replied by Mike_Eitel on topic Millright Mega V Controller Change
I would try to swap two wires between y motor and y driver. That way you do not have to remember those "inversions" over coming years. Or write good documentation in your hal file.
m5c
Mike
31 Oct 2020 14:02 #187910 by emoseman
This is what I ended up having to do to get the Y axis moving in the right direction.
Thanks for the tip!
Time to create page: 0.097 seconds
