Joint following error
02 Nov 2020 17:16 #188125 by Jocman
Joint following error was created by Jocman
Hi all.
I started a drilling job (about 70 holes) but after about 20 minutes (15 holes) the machine stopped with 2 error messages:
- hm2/hm2_7i76e.0:error finishing read!
- joint 0 following error
I suppose is something related to ini or hal files, but honestly don't know ho to fix it (and more understand why it happens).
Andrea
02 Nov 2020 18:07 #188130 by PCW
Replied by PCW on topic Joint following error
Means that you have lost contact with the 7I76E
This may be an electrical issue or a problem with latency on the host PC
What do you get for times if you ping the 7I76E?
What Host hardware do you have?
What OS are you running (uname -a)?
The following user(s) said Thank You: Jocman
02 Nov 2020 20:45 #188151 by Jocman
Replied by Jocman on topic Joint following error
Ping results:
23 packages
Avg 0.069ms
Min 0.049ms
Max 0.113ms
0% loss
Hdware:
Asrock Q1900M
Intel celeron J1900 1.99Ghz
RAM 8Gb
Onboard lan port (for mesa) + additional lan port (web)
OS:
4.9.0-8-rt-amd64 #1 smp preempt rt debian 4.9.110-3+deb9u6 (2018-10-08) x86_64 GNU/LINUX
I run a latency test while retrieving the os data,getting this:
Max jitter 82864 (servo thread) - 62588 (base thread)
Running 10 instances of glxgears (and terminal windows):
82864 (servo thread) - 1555650 (base thread)
03 Nov 2020 01:50 #188168 by PCW
Are all power management/Turbo modes/Cstates > C1 disabled in BIOS?
03 Nov 2020 08:29 #188190 by Jocman
Sorry for late reply (time difference with the "old world").
Currently I'm at workplace, but as far as I remember everything is disabled (that's why when I installed the mesa board I got a good increase, or better a "decrease", of latency).
BTW, as soon as I'll back home in the late afternoon (about 8 hrs) I'll check the bios settings too.
03 Nov 2020 16:32 #188244 by Jocman
Well, I checked the bios settings.
This is a resume of some various settings:
- Intel Speedstep Technology (Disabled)
- CPU Cstates support (Disabled)
- Enhanced Halt State (C1E) (Disabled)
- No execute memory protection (Disabled)
- Intel virtualization technology (Disabled)
- IGPU multimonitor (Disabled)
- Onboard HD audio (Disabled)
- Deep S5 (Disabled)
- Sata aggressive link power management (Disabled)
- Hard Disk S.M.A.R.T. (Disabled)
- Intel smart connect technology (Disabled)
- Suspend to RAM (Auto)
- ACPI HPET Table (Enabled)
- PS2 Keyboard Power on (Disabled)
- PCIE Device Power on (Disabled)
- Ring-in Power on (Disabled)
- RTC Alarm Power on (Disabled)
- USB keyboard/remote Power on (Disabled)
- USB mouse Power on (Disabled)
- USB controller (Enabled)
- Intel USB 3.0 Mode (Auto)
- Legacy USB Support (Enabled)
I think everything unnecessary is disabled.....
03 Nov 2020 18:25 #188246 by PCW
This indicates a major latency issue but a better test would be to run
without a base thread:
latency-test 1ms 1ms
or
latency-histogram --nobase --sbinsize 1000
04 Nov 2020 08:13 #188296 by Jocman
I'll try this one too and let you know.
04 Nov 2020 16:41 #188321 by Jocman
I tried both commands
The first gave me a Max Jitter of 22845; then when I started the browser to write this post, the value raised up to 168149 (no glxgears instances)
The second command (with 10 instances of glxgears): 1st test without browser, 2nd test with browser, 3rd test only browser (no glxgears instances)
06 Nov 2020 11:59 #188493 by Jocman
Reading some posts in the forum about people with the same issue, I red the solution gaven to fix it: the parameter FERROR in the INI file.
In particular, to set this value as 1 (not higher).
I tried to set my values to 1 (they were 10), then started a .... fake job (spindle off and no bit). Everything was fine, so I risked to start a complete job.
The machine accomplished the task, without any issue.
My doubt: this was the solution to my problem or just a lucky strike / coincidence?
Reading the FERROR documentation, as I understood (?) it concerns the axis position control for open loop systems. My is a closed loop one. Does it matter?
Time to create page: 0.131 seconds
