Configure spindle enable
- Pro_El
- Thank you received: 3
02 Nov 2020 22:58 #188161
by Pro_El
Configure spindle enable was created by Pro_El
Hello
I am working with mesa 7i77 and Buster with 2.8 LCNC and need if it is possible to :
Enable spindle only when i give command M3 or M4 or when Spindle on is aktiv. I don't want spindle to be in enable state when i enable all axis. I have problem that spindle is spinning only a little when is in enable state. That is my zero offset not tuned correctly.. I do not have hooked up encoder to spindle.
I cannot find anything for this in this forum or manuals, or maybe i missed something..
Thanks to all
Thanks to all
- BeagleBrainz
- Visitor
03 Nov 2020 00:32 #188167
by BeagleBrainz
Replied by BeagleBrainz on topic Configure spindle enable
Should find some info here:
forum.linuxcnc.org/forum/search?query=7i...pindle&childforums=1
It also helps if you can throw up your hal & ini files so others can have a look & advise.
- Pro_El
03 Nov 2020 06:03 #188177
by Pro_El
Replied by Pro_El on topic Configure spindle enable
Thank you BeagleBrainz for quick replay.
Here are hal and ini.
- Thank you received: 5321
03 Nov 2020 14:01 #188222
Replied by PCW on topic Configure spindle enable
You should use analog out 5 for the spindle since it has a separate enable
HAL pin and enable output pins for that purpose.
The following user(s) said Thank You: Pro_El
- Pro_El
07 Nov 2020 17:29 #188595
by Pro_El
With analog out 5 working Great with spindle
Thanks PCW
Thanks PCW
Time to create page: 0.151 seconds
