DMM Servo spindle deceleration
  • The Feral Engineer
  • The Feral Engineer's Avatar Topic Author
  • Senior Member
  • Senior Member
06 Nov 2020 21:14 #188544 by The Feral Engineer
DMM Servo spindle deceleration was created by The Feral Engineer
hey guys,
I'm trying to set up a DMM 1kw servo in step/dir mode on a 7i76e to use as a spindle. The acceleration ramp works fine and gets me what I need, but when I command an M5, the motor comes to a screeching halt regardless of what speed it's running at. Is there a way to ramp down the spindle the same way it ramps up? I was thinking maybe connecting the drive to the encoder might help resolve this? It's currently just running under step/direction connection #4, nothing connected to the encoder pins.
Thanks in advance.
  • Senior Member
  • Senior Member
06 Nov 2020 21:36 #188546 by The Feral Engineer
Replied by The Feral Engineer on topic DMM Servo spindle deceleration
got it, nevermind!!! :)
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
06 Nov 2020 22:36 #188550 by BeagleBrainz
Replied by BeagleBrainz on topic DMM Servo spindle deceleration
So how did you solve it, someone else may run into a similar issue.
  • Senior Member
  • Senior Member
07 Nov 2020 05:30 #188572 by The Feral Engineer
Should've mentioned i wouldn't be home tonight but I'll post the fix when i am
The following user(s) said Thank You: BeagleBrainz
06 Dec 2020 07:51 #191211 by partec
Replied by partec on topic DMM Servo spindle deceleration
06 Dec 2020 11:00 #191214 by pippin88
The following user(s) said Thank You: partec
Time to create page: 0.161 seconds
