How to change tandem (dual) homeing behavior?
5 years 9 months ago #194292 by Clive S
5 years 9 months ago #194298 by bbg
For clarification, this is the homing sequence I had in mind:
5 years 9 months ago #194314 by cmorley
your sequence makes perfect sense if you can't set the home switches close enough.
You would need to write c code to change linuxcnc's homing process.
Most people would work hard to find away to adjust the home switches position and use the standard homing sequence.
Chris
